10-fa11-0450 for vista
10-fa11-0450 for toshiba vista recovery
    Guru:
  • 161 Answers
An option is a cute free little program called EasyBCD.
It repairs most Windows based Boot problems so very simply, amongst other things and also configures multiboot systems. Give it a try if you can get into your OS.
This will also work using a secondary PC to access your Vista to fix the Bootloader, but it is difficult to start again in the original PC, but it will work.
If you can't fix it or get in to your OS, well, that's it. You just need to keep trying with your Restore disks until you've succeeded or had enough and then just reinstall.
Posted on Jan 14, 2010
I don't have the windows vista disc for my toshiba satellite A205-S5804 notebook and now my sistem is collapsed. and system recovery not working,what can i do?
You can buy a Vista disc to any computer store or Request a recovery disc from Toshiba. TOSHIBA : (800) 457-7777 (toll-free) or (949) 859-4273
Jan 23, 2011 | Toshiba Satellite A205-S5804 PC Notebook
Error : 10-FC12-0570 when i try to reinstall with the cds
Error 10-FC12-0570 on Toshiba satellite This error message means that the recovery utility was not able to read the data from the disc correctly, or wasn't able to write it to the hard drive.
The problem could be with the disc, the CD/DVD drive or the hard drive.
Solution:
Try copying the second disc using another system. If it's impossible: order for a new disc. If you can copy it, try using the copy to do the restore.
Try using a third party disk checker to verify the problem, is or is not, with the hard drive.
The best way would be to load the Windonws Vista discs, format the pc and reinstall.
(Vista Recovery Boot Cd is available free by Microsoft). Download it burn the Image .iso and run that disc. That disc will not restore the OS: run diagnostics on the HDD; once disk check is completed and repaired, proceed with the Recovery disks that you have.
Nov 22, 2010 | Toshiba Satellite A215-S7422 Notebook
Ok, here it goes. I have a Toshiba satellite L300 Series. It shutdown and has these errors..10-FC06-000D and 10-FC12-045D. I installed recovery disk 1 and then it ask for disk 2. After 15min of disk 2 the...
Hi
Thank you for your query
From what you are describing the recovery disks are faulty, and as things stand you have no operating system.
The only thing you can do about it, is to contact Toshiba to obtain replacement discs
If this has been useful please leave positive feedback/vote/testimonial - Thank you again
Feb 14, 2010 | Toshiba Satellite Pro L300-EZ1004X...
I lost vista software
If you still have your license key sticker then you can use any Vista disk. A friend's one for example.
Or if you want to use recovery:
1. Turn on Computer
2. Hold F11 for 10-20 (or F10 if nothing comes up, restart first!!)
3. Once it loads if it comes up with system restore, put "no" on that.
4. Next system recovery, put yes and your on your way!
Recovery - Restores original factory settings just like you bought it
Jan 16, 2010 | Toshiba Satellite A100-S8111TD Notebook
Toshiba Satellite L305-S5875; Recovery Error 10-fc12-045d HELP!!
no it is not fried. you just need to find a vista disk and use that instead of the recovery disks. Once you reinstall Vista you should be able to go online for the Toshiba drivers. Make sure you have the windows Vista Key which should be located under the laptop. the vista software install will ask for it.
Jan 10, 2010 | Compaq Deskpro EP PIII-650MHz/ 128MB/...
Need a toshiba portege R500 vista recovery disk
Toshiba Factory Reset
a couple of ways to do that 1) if you have the recovery CDs supplied with the PC - then you can use these - put the CD into the drive and when it boots follow the instructions 2) If you have a recovery partition on the laptop - have a read here to see if you have one http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/outFrm.jsp?ofId=AskIris&searchString=recovery+to+factory 3) This link shows you how to use the partition http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/bulletinDetail.jsp?soid=2291088&pf=true basically as the PC boots TAP F8 key - from the menu that appears choose "repair your computer"
If that option is NOT available then you will need to Order CDs from Toshiba - http://laptopforums.toshiba.com/t5/System-Recovery-and-Recovery/Recovery-media/m-p/9148#U9148
Oct 18, 2009 | Toshiba PORTEGE R500-S5006X Notebook
I am coming up with error 10-fc12-0570 on the toshiba satellite a215-s7422 i used the both recovery disk and this was the error code
The error message is telling you that the recovery utility was not able to read the data from the disc correctly, or wasn't able to write it to the hard drive. The problem could be with the disc, the CD/DVD drive or the hard drive.
but usually error 10-FC12-0570 is pertaining to a bad HDD or memory
First, try copying the second disc using another system. If you can't copy it, order replacements from Toshiba Customer Assistance: 1-800-457-7777. If you can copy it, try using the copy to do the restore.
You can try using a third party disk checker to verify the problem is or is not with the hard drive. But since the system is under warranty, you're going to have to arrange to have it repaired anyhow, so it may not be worth the effort to verify whether it's the hard drive or CD/DVD drive. It's probably not the CD/DVD drive since you got all the way through the first disc. Contact a Premier (not regular) ASP for service from here: http://pcrepair.toshiba.com
The best way would be to load the Win Vista discs n format the pc...and reinstall...iam telling this because u have a tried the recovery disk as well....
I know most users will not have the Vista CD with you but the Vista Recovery Boot Cd is available free by Microsoft just google...
Download it burn the Image .iso and run that disc. Since that disc will not restore the OS all it does it lets u run diagnostics on ur HDD and allows u to install the OS. Once disk check is completed and repaired, proceed with the Recovery disks that you have.
thank you
have a nice day
Jul 08, 2009 | Toshiba Satellite A215-S7422 Notebook
How to recovery the system from recovery partition
Did you know you only get ONE shot at creating a recovery disc? And most of the time it is garbage, just like Vista.
He tried to put XP on it and failed? weird.
A couple things you can do...
1. Get your hands on a Vista disk. If you know anyone that works in IT, you can borrow a Vista disk. Do a complete fresh install. Use your "Product Key" and you will have your own Licensed, perfectly legal version of Vista.
2. Get yourself a copy of XP. Delete all partitions, then create a new one. Don't try to save that Vista recovery partition...it's toast. I recommend XP, but I'm a dinosaur.
Apr 07, 2009 | Toshiba Fusion Satellite U405-S2833...
System Recovery Media error 10-FA11-045D
This error comes up if the toshiba recovery cannot recognise the file system and partitions. try removing all partitions using the fdisk utility or a windows XP CD and then run the recovery.
Mar 09, 2009 | Computers & Internet
Computers & Internet Logo
193 people viewed this question
David Payne
David Payne
