Question about Bosch RS15 1 1/4 Reciprocating Saw
Locking device will not reset and lock blade in holder on a Bosch RS 15 Saw. .The locking device is up against the pin and will not rotate.
I do not know details. A friend cleaned steel dust from the device and got it to working. Apparently a sock needs to be over the device when sawing steel over head to keep the steel dust out.
Posted on Oct 07, 2009
  • 2,176 Answers
Try using compressed air to blow out the area and then some WD-40 to loosen it up. They sell the holder as an assembly, You can go to Boschtools.com and download a breakdown for this tool. It is usually some debris or rust that makes them stick.
Posted on Oct 06, 2009
Where is the blade lock on the skilsaw 5155
Hi Emory:
Your question made me think................
None of the skil saws that I have owned, or still have, came with a blade lock. Maybe yours has one, but if I needed to pin the blade while undoing the bolt, I'd do like I always did......... Unplug the saw....... and slip a carpenters pencil between the teeth and rotate the blade until the pencil came up against the deck.
There is also usually a hole in the blade, and a nail slipped through the hole makes a perfect blade lock.
Oct 03, 2015 | Saws
How do you fit a blade into a dw933 jigsaw
hi, sorry if the text is a bit small :P Full instructions available here: http://service.dewalt.co.uk/PDMSDocuments/EU/Docs//docpdf/dw933_eur.pdf
Fitting and removing a saw blade (fig. A, B & I)
The DEWALT tool-free system ensures quick and easy changing of saw blades.
• Pull the rotating handle (10) up completely. • Unlock the handle by rotating it as shown. • Insert the saw blade into the blade holder (8)
guiding the back of the blade into the groove of
the guide roller (6). • Turn the rotating handle (10) towards locked
position until a click is heard. • Press the rotating handle halfway down
(freewheeling position) and continue rotating the
handle towards locked position. • Press the handle (10) down completely. • To remove the saw blade proceed in reverse order.
Jan 14, 2011 | Saws
To remove the blade, is the nut right or left-hand threads? Is there a blade lock?
With any circular saw, table saw, metal cut off saw, mitre saw etc the nut always tightens against the direction of rotation and loosens the opposite way
Nov 12, 2010 | Delta Saws
How do I change the blade on a dewalt compound (12 in) miter saw?
With the saw unplugged - The blade needs to be locked in place so it will not turn when you put a wrench on the nut located on the left side of the blade that holds the blade on. This is done with a locking pin on the right side of the blade. Push the pin in and rotate the blade by hand until the pin locks into the blade and prevents it from moving. With the pin pushed in put a wrench on the large nut on the left side of the blade and turn it. This may be reversed threaded, so you may have to turn the nut clockwise in order to loosen it. When tightening the nut after replacing the blade, you will have to once again lock the blade with the same pin.
Perhaps this video will help you locate the locking pin.
http://www.youtube.com/watch?v=oKmIB-0AE1w&feature=related
Aug 28, 2010 | Dewalt Saws
How do I remove the blade from a Makita MK470 tile saw? I can't figure out how to hold the saw blade so that I can turn the nut hodling it on. The nut is on pretty tight and I need to lock the blade so I...
There is not a lock on this saw. If the blade is to tight to hold by hand you need to use an impact wrench. It will loosen the nut before the blade has time to start spinning.
Nov 11, 2009 | Saws
How I change the blades in the Rs 15 saw machine bosch
To lock a blade in just push the blade in until you hear it click. This is what engages the blade. To disengage just turn the blade clamp until the blade pops out. This will lock it open until you insert a new blade.
Sep 08, 2009 | Bosch Saws
Changing circular saw blade
near the guard should be a button u hold and rotate blade(unplug first)until it locks, some old and cheap saws have no lock pin, so lock blade with vise grips and let rest against base plate and loosen nut.
Jul 16, 2009 | Saws
How does one remove a broken blade from a Bosch rs20 blade holder
twist the collar around where the blade fits in the saw. It will lock in the open position. When you insert the new blade, do so firmly until the collar releases locking the new blade in place. Give a tug at the blade to make sure it is locked in.
Nov 27, 2008 | Bosch RS20 13 Amp Reciprocating Saw
How to lock blade on older circular saw
ONE WAY IS TO TAKE A PAIR OF VISE-GRIP PLIERS ,LOCK THEM ONTO THE BLADE VERY TIGHT WHEN THEY TURN UP AGAINST THE BED OF THE SAW YOU SHOULD BE ABLE TO REMOVE THE BOLT THAT HOLDS THE BLADE WORKS WELL DID IT LOTS ( bear in mind some of the bolts are left hand threaded so if does not go one way try the other )
Nov 23, 2008 | Bosch 12" Dual - Bevel Compound Miter Saw...
Blade replacement on mk-170 tile saw.
take a pair of good vise grips and hook onto blade tightly, slide uo against back braket. that will hold the blade from spinning while you remove the nut, try bumping your ratchet/ wrench w/ a rubber mallet or hammer. hope this helps
Oct 29, 2008 | Mk Diamond MK - 170 Wet Cutting Tile Saw
Bosch RS15 1 1/4 Reciprocating Saw Logo
345 people viewed this question
Top Bosch Saws Experts
Parson's Repair...
Parson's Repair...
Jim London
Jim London
Are you a Bosch Saw Expert? Answer questions, earn points and help others
