Question about GE Spectra JGBP35 Gas Kitchen Range
My oven won't heat
My oven was working fine last week. I used the self clean for the first time after baking last week and it appeared to function fine. The door locked and the timer began the 4 hour countdown. I have not used it since until I tried to use it tonight and the oven will not work. The broil function works fine, as do all the burners. The digital display also seems to work fine as well as the oven light. When I press the bake key, it shows 100 degrees but the oven doesn't fire up and it doesn't heat up. Can you help?
    President:
  • 1,015 Answers
First you will need to verify if the igniter is coming on for the oven burner when the oven is turned on. You will need to remove the oven bottom cover. There is usually two screws at the back bottom of the oven compartment that holds the bottom on. If there are no screws then it should just lift out. You may need to slide the bottom away from you then lift from the back. You will need to remove the oven racks to make enough room to lif the bottom out. Once removed you should be able to see the burner(you may also need to remove a heat spreader on the burner). Now turn on the oven and watch for the hot surface igniter to start to glow. If it does then you will need to make sure the gas orfice and venturri for the burner are not plugged with debris. You can use a small can of compressed air to try and dislodge any debris. Then give the oven gas valve a light tap with a screwdriver or a wrench. Oven gas valve is usually located at the bottom of the oven. Remove the bottom storage compartment to reach it. If you tap it and the burner comes on there may have just been debris in the valve and you may have cleared it. Then turn the oven off and back on completely several times. If the burner comes back on you should be ok if it does not then it could be a weak hot surface igniter or a bad olven gas control valve. Now going back to the start if the igniter does not come on you will need to verify if the igniter is getting voltage. If it is then test the igniter with a ohm meter. The reading should usually be between 500 to 700 ohms. A common problem with hot surface igniters is that they will crack. Examine the igniter for any visible cracks. If the igniter is not getting voltage then you will need to verify that all wires are properly connected and none have come loose. Look for any melted wires from the self cleaning process. You may need to dis-assemble the back of the range to see if any wires have come loose or melted. Now I need to stress to you that safety is important. Be very careful performing these procedures. You can get shocked or possible burned.
Posted on Oct 06, 2009
4 Suggested Answers
fridgetech
  • 473 Answers
SOURCE: ge spectra xl44 stove
Most likely the oven ignitor is bad or weak.  You can look at it and see how it compares to the broil ignitor.  If you see a whitish color on the ignitor and if it doesn't fully glow then it needs to be replaced.
Posted on Oct 22, 2007
aborcass
  • 2651 Answers
SOURCE: MAYTAG GAS RANGE MODEL # MGR5765QDW
sounds like a bad bake ignitor, common issue with all gas stoves.
Posted on Nov 11, 2008
housejess
  • 317 Answers
SOURCE: Bake element for Maytag MER5765RAS did not work.
look inside the breaker box..find the 220 breaker to the range...make sure both sides are in the on possition....if not then only 110 volts are going to the range instead of 220...hope this helps..thanks
Posted on Nov 08, 2009
RBS305 replaced thermal cutoff twice and again it won't come on bake or broil
Good Evening!
The self clean feature is causing your thermal fuses to fail or open. This is a safety mechanism that when open (bad) won't allow electricity to pass through any longer. The temperature in your oven exceeds what the components in your appliance can handle. If you want your oven to last it's longest, I would discontinue using that feature. If ever the control board or keypad on your oven by way of the self clean feature, we can help you with that. Fixyourboard.com can help. Send all inquiries to info@fixyourboard.com . Thank you!
Jun 05, 2017 | Whirlpool RBS305PD Electric Single Oven
We purchased our Frigidare Double Oven, Model Number FPET3085KFA, October 2009 (15 months ago). We ran the self-clean process for the first time yesterday on the top oven using the 4 hr option and it...
try turning your breaker off for 20 minutes, then try it again,, if this does not help it could have burnt out a element or the main board has went out,,, also make for sere you are getting the full 220 volts to the unit,, this will involve taking the unit out
Jan 19, 2011 | Frigidaire 30 in. Electric Gallery Series...
I have a 30 inch Frigidaire self cleaning oven. The oven will no longer heat up in a normal amount of time using the bake function. Sometimes I can smell gas when using bake. It cant reach the desired...
Sorry to read about your problem, I hope this helps you out.
Bad gas control valve or oven temp control
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 22, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Model FEFL78CBC frigidaire oven bottom (bake) burner won't work everything else works fine --even broiler element works fine. Just used self-cleaning cycle, which did work. Next morning oven won't heat ....
We had the same thing happen and now they came and said it was the clock that needs to be replaced. They said that controls the oven. Even though clock is on and working the function for turning on the oven is not
Nov 28, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Bottom oven doesn't heat after running self-clean cycle
Usually, when an oven won't heat, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
Aug 17, 2009 | GE Profile JTP56 Electric Double Oven
How do I use the self cleaning functions - kitchenaid oven
Please allow me to help you first with some background of self cleaning functions:
Self-cleaning ovens use an approximately 900 degrees Fahrenheit (482 degrees Celsius) temperature cycle to burn off spills leftover from baking, without the use of any chemicals. A self-cleaning oven is designed with a mechanical interlock (patented in 1982) to keep the oven door locked and closed during and soon after the high-temperature cleaning cycle, which can be approximately three hours. The door stays locked to prevent burn injuries. You can open the oven door after the oven cools to approximately 600 F (315 C).
If baking spills are not wiped up after baking, there may be some smoke during an oven cleaning cycle. It is a good idea to remove any pets from the area when running the oven's self-cleaning cycle. There have been reports of oven-heated Teflon-coated items releasing odorless fumes deadly to birds.
Self-cleaning ovens have the added benefit of more insulation, which helps the energy efficiency for regular baking. This is similar in concept to an increased R-factor for home insulation.
You will also save energy costs by using the self-cleaning cycle right after baking, to make use of the already partially heated oven.
Please check this website mentioned bellow which would give you a detailed method of how to perform it:
http://cleaning.lovetoknow.com/Self_Cleaning_Oven_Instructions
Hope this would help you .
God Bless.
Jul 05, 2009 | KitchenAid Kitchen Ranges
Self-clean not cleaning
I was wrong (I think).  the baking element probably was burnt out as the repairman said.  He replaced it and I thought selfclean still wasn't working.  In fact, I think I just had to give the self-clean function more time.  Also, I was judging by smell.  We have become used to a bad odor during self clean which was missing when it was broken and still missing after the repair.  Bottom line, the oven was clean after the baking element was replaced, sans smell.
Apr 19, 2008 | GE Profile JTP18 Electric Single Oven
Whirlpool oven issue
Usually, when an oven won't bake, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
Oct 26, 2007 | Whirlpool RBS305PDS Electric Single Oven
After self cleaning, Range trips circuit breaker when using convection
self cleaning ovens use super hot seting to bake the oven clean and it sounds like it melted a wire and it is shorting out the oven on that setting. look at the wires you can see or easy to remove panels
Dec 22, 2006 | GE Profile JGS968 Gas Kitchen Range
GE Spectra JGBP35 Gas Kitchen Range Logo
501 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
