Question about Denon AVR-3803 Receiver
My Denon AVR-3803 will not go to on screen system setup
My 3803 will not go to the system setup for on screen programming. Just moved the receiver - unplugged for couple hours, all settings retained but can't view system setup on the TV. the S-video is connected as before from the Monitor jack on the Amp to the Monitor jack on the TV. The Component Video and Audio (optical) all work fine. Please Advise.
Struggling to get my tuner working on the AVR-3803 - not sure what is wrong. just not getting any sound from the speakers. everything else works
Perhaps you aren't tuning any stations. That would be a good first step toward audio. Install an antenna, too. "Tuned" and "stereo" are indicators there is a listenable station tuned in.
Dec 27, 2010 | Denon AVR-3803 Receiver
Hi Have Vizio Flat Screen and a Denon 3803 receiver. The Tv a Vizio 65 Inch flat screen was here. Out of the wall is a power cord and red,blue,green monster cable. Red and Blue is audio and green video I...
Red, Green and Blue cables together typically denotes a component video signal - an Analog, High Definition transportation for video. This cable does not carry audio, you need another cable to hook up audio between the DVR and receiver. You can use either an RCA stereo cable (red and white), optical-audio, HDMI, or a whole plethora of other audio cables. I would recommend optical or HDMI to get the most out of your system.
Jul 16, 2010 | Denon AVR-3803 Receiver
I just bought a I Pod dock ASD 11R and would like
Get a 3.5 plug with two RCA plugs and connect it to an aux imput via the headphone out of the dock.
Jan 24, 2010 | Denon AVR-3803 Receiver
Have a denon rc-921 remote that setup techs locked. how do I unlock it.
Remove the batteries. Press and release each button. (If you have slide switches, you must move it to each positon and then press and release each button for each of the switches selections.)
Install the batteries and try.
Dec 24, 2009 | Denon AVR-3803 Receiver
Hooking up an external audio source (IPOD) to the Denon AVR 3803
Yes it is.  You will need to pick up a mini plug to stereo rca adapter.
Jan 07, 2009 | Denon AVR-3803 Receiver
System: DENON AVR 3803 The TV is connected to the receiver, so both the audio and video components are fed through the receiver, I think. The image on the TV was present, but the TV/VCR button was pushed...
THERE ARE ONLY TWO WAYS THE TV SHOULD BE CONNECTED TO THE DENON,
1. MONITOR OUT OF THE DENON TO AN INPUT ON THE TV.
2. AUDIO OUT FROM THE TV TO AN INPUT ON THE DENON.
ALL YOU DEVICES CAN BE CONNECTED TO THE DENON IF #1 CONNECTION IS USED OR ALL DEVICES CONNECTED TO THE TV IF #2 IS USED
Nov 27, 2008 | Denon AVR-3803 Receiver
Unable to view setup menu on TV screen
I had this same experience and after hours of attepts to fix it (including the suggestions on this site) I found that the company that installed and set up my system literally disabled the "set up" on the remote so that it could not be changed. To fix this (and/or confirm that this may be your problem) reference page 39, "all reset functions" to reset your remote back to factory settings. As soon as I did this and hit "set-up" -- the set up menu popped up and worked appropriately. Hope this works for you!
Dec 16, 2007 | Denon AVR-3802 Receiver
Denon AVR-3803 Receiver Logo
226 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
