Question about Texas Instruments TI-36 X Solar Calculator
How to display 10 to the 23rd power so i can multiply it later
  • Texas Instru... Master
  • 7,993 Answers
1. Use the [Y to the x ] key on 5th line
10[Y to the x] 23 [=].
2. there is amore efficient way to do it, Use the [EE] key
1[EE] 23. Screen displays 1. -65 where -65 is in smaller size.
Hope it helps.
Posted on Oct 21, 2009
  • k24674 Oct 27, 2009
    Sorry. 1[EE]23 displays as 1. 23, where 23 is in smaller size.
No speed is displayed when the trigger is pulled and aimed at the baseball. Just mph and the radar icon. It has new batteries. What could be causing it not to detect speed.
You can add up to 25 miles an hour and more to your swing speed by taking advantage of your hidden, built-in swing speed multiplier. The top pros have always taken advantage of their hidden swing speed multiplier. It's why they drive the ball 280-300 yards The average golfer does not know he has a swing speed multiplier built into his own body-and drives the ball 210-220.
What is the swing speed multiplier built into every golfer? And how does it affect swing speed? It is a hidden lever system that multiplies any increase in hip speed 25 times.
Jun 30, 2015 | Bushnell Velocity Radar Gun Speed...
Casio fx-991MS M+ button multiplies the answer then stores the value.
Whys use the M+ button? Every time you press it it adds the content of the display to the content of the running memory. Degree mode has on influence on the content of the memory.
Mar 11, 2015 | Casio Office Equipment & Supplies
Area
A hexagonal based prism has a lateral area that is made up of 6 rectangular faces. If the hexagon at the base is regular, all the lateral rectangles are congruent (identical).
To calculate the lateral area of one of the rectangular faces you need to multiply the length of a side (s) of the regular hexagon by the height (h).
For the lateral area of the prism use A_l=6*s*h=P_b*h, where P_b is the perimeter of the base.
Sorry I cannot proceed further, because "using the area and the height?" is not clear enough for me.
May 22, 2013 | Computers & Internet
Square
Multiplying by 2 is different from raising a number to power 2 (squaring).
To raise a number to power 2, you enter the number then press the [X^2] key.
To multiply a number by 2, you type in the number, you press the multiplication sign (x) then you enter 2. Press = or EXE.
Jul 14, 2012 | Canon Office Equipment & Supplies
@yahoo.comcreate a flowchart that will increase the value of the number by 5 if it is greater than 10 and display thae result. otherwise multiply the value by 5 and display the result
create a flowchart that will increase the value of the number by 5 if it is greater than 10 and display the result. otherwise multiply the value by 5 and display the result.
Jun 23, 2011 | Audio Players & Recorders
I have a TI30XA calculator and want to know how to multiply numbers using scientific notation. I have learned how to enter a number (e.g., 1.5 x 10 -6), but when I try to multiply it by something (e.g.,...
Press 2nd [SCI] to switch the calculator to display all results in scientific notation. The results are the same whether you do it in scientific notation or not, it's just how the number is displayed.
Feb 13, 2011 | Texas Instruments TI-30XA Calculator
Anytime I try to multiply .001X.001, any decimal beginning with a zero, I get an error. For example, .001X.001=1 E-6...My mode is set in normal, and I reset it to default, what am I missing?
This is not an error. .001 multiplied by .001 is 1E-6.
If the absolute value of a number is less than .001, the calculator will always display it in scientific notation. 1E-6 is interpreted as 1 times 10 to the minus sixth power.
Oct 11, 2010 | Texas Instruments TI-84 Plus Calculator
NOt exactly a problem as my Casio SL-1100TV calculator works fine. What I am trying to find out more about is the 'K' function, when you can press the + button twice and it carries over the number that...
If you have say to multiply 100 numbers by one single multiplier ( you have 100 multiplications to perfom) you use the Constant function abbreviated to K.
This is how you go about it
in a*b , a is called multilpicand, b is the multiplier.
You enter the multiplier (6) then you press twice on the multiplication key. You are ready to repeated the some operation but with a different multiplicand
You enter the first mutiplicand then you press = (or enter) the result is displayed.
Every number you are going to enter will be multiplied by 6
[6][*][*] -------constant multiplication with 6 as multiplier, Then
[5][=/ENTER/EXE] yields 30
[6][=] yields 36
[0.5][=] yields 3.
Be careful!! If you do not enter a new multiplier and just press [=] the calculator uses the last calculated result as the multiplicand. (On certain calculators, the last result is stored in a register called Ans (short for answer.)
What I described for the multiplication is valid for any arithmetic operation. Thus
[6][+][+] is constant addition with 6
[18][/][/] is constant division with 18 as divisor.
Hope it helps
Sep 02, 2009 | Casio Office Equipment & Supplies
E shows on display screen and my 5045 SVC calculator won't work n
Mine did the exact same thing, only when I would multiply or add 5 and 5, when I hit = it showed up 555. I just put it on POWER IC for about 15 minutes. Then hit the clear button at the same time as I turned off the power. When I turned the POWER ON there was no longer an E or the crazy triple digits. Hope yours does the same. GOOD LUCK!!!!!!
Mar 25, 2009 | Texas Instruments TI-5045 SVC Calculator
Texas Instruments TI-36 X Solar Calculator Logo
448 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
