Question about GE WBSR3140DW Top Load Washer
How do I get into the washing machine (GE) to reach the hose to check to see if there is anything in the hose that is stopping the machine from recognizing when the tub is full? Regardless of where I set the water level to, it is overflowing.
    President:
  • 2,976 Answers
Pop the top and look for a small hose goint to a switch. To pop the top, use a putty knife. About 2" from the sides, push it in, into the crack along the front. You will depress spring catches and the top will lift.
Posted on Oct 06, 2009
I have a GE washing machine that the water does not turn off once it reaches the appropriate level. Last night it overflowed and flooded 3 rooms.
You have a bad water level sensor.
Look inside washer and check if anything is holding a float sensor down. If not, the sensor is bad or its connection to the control board is loose or not connected.
Jul 04, 2016 | GE Washing Machines
Ge washing machine will not drain
Drain by lowering main drain hose below pump into shallow bucket, remove front lower panel , take large hose off back of pump clean out hose, may have to take 2 screws out of pump mount to look in pump mine was being stopped by a nail,the$6.75 in change was still in the hose
Jan 23, 2013 | GE Wsxh208a1ww Front Load Washer Washing...
I have a ge profile washer machine washes and spins but wont drain
Hi.
Disconnect power, then locate the access to drain pump. On GE top loader the pump access is usually at the back, sometimes at the bottom. Disconnect the hose from the pump and remove any blockage in there.
Check also the height of the drain hose at the back and ensure that the hose is set according to manual. An drain hose set incorrectly will result in drain problems.
If that does not fix the problem, clean or replace the pressure switch and pressure hose that detects water level determining when to start and stop draining.
Regards.
Ginko
Jul 08, 2011 | GE Profile WPRE8100G
Washing maohine doesn't take water '
If you have established that the water is reaching the washer, then either there is ni power to the valves, or the valves are faulty.
Hope this helps.
Jan 27, 2010 | GE Washing Machines
Washing machine does NOT stop filling w/ water!
If the m/c keeps filling, where is the water going ??? if the m/c doesnt reach the required water level it will not start, check the drain hose at the back, make sure its at least 24" above floor level, if it lower then it will just empty as quick as you fill it on gravity.
Nov 19, 2009 | GE Washing Machines
Ge washer M#: wjre5500g1ww will not fill
First, make sure there's water getting to the washing machine. if the hoses are not kinked and, the water is reaching the unit, replace the water valve assembly.
Jun 19, 2009 | GE WBSE2090A Top Load Washer
Ge front load washer won't go into rinse cycle.
Check the cold water hose. My brand new machine had this behavior until I discovered a kink in the cold water hose - works great now.
Jun 03, 2009 | GE WSXH208A Front Load Washer
GE wcxr1070a washing machine. fills with water
Check the water level switch and the plastic tubing to the switch.
Sometimes soap scum stops up the plastic hose and the water level switch does not close to send power to the timer.
If the plastic hose is good and the water level fills and stops replace the water level switch.
Mar 21, 2009 | GE WCXR1070A
Washing machine won't drain
i think you can fix it , does it stops when it reaches RINSE cycle ?? if yes , your gonna open the front panel or back panel so you can see inside machine . follow the DRAIN HOSE thats attached to SMALL DRAIN PUMP MOTOR , YOU NEED TO TAKE OUT and check for anything thats blocking the impellers and causing it to stop ( pins , buttons , etc ) let me know by your smile . . . . . .
Apr 22, 2008 | Washing Machines
GE WBSR3140DW Top Load Washer Logo
110 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
