Unable to get full picture on TV -- can see Picture in Picture while in Menue, but when I escape from the menue, screen is either black or blue. We have cable TV with a box which has a remote and displays channels and programs. These can only be seen on the picture in picture while in menue mode.
snakehead
  • 1074 Answers
SOURCE: Black Square Covers 80% of screen on most channels on TV
have your tv checked by a tech.probably your chip the eprom needs to be reset by lifting it up from the board and resolder back.some one could have put in a code for those channel.good luck.
Posted on Mar 23, 2007
SOURCE: rear projection tv picture problem
I have a sony kp-48s65 projection tv. I have three lamps in back a red a green and a blue. when turned on the sound always works
timer standby light blinks steady at 1 pace Once in a while the picture will just come on and work fine it may work for 1 hour or 10h min then the picture goes out . What can i do. People say lamps but when the picture is on and working the three lights behind work fine . its like whatever powers the lights isnt working
Unplugging and plugging back in and waiting usually brings it back on. For so long . When it is on the screen I can see hard bright green and red the picture is really too red its ok but its hue is off or something Tv in good shape what do i do?
tv consumer
Posted on May 07, 2008
SOURCE: Panasonic T.V. "Picture Menu Lock Mode"
On my 27" you need to press action and the channel button at the same time to unlock. Hope that helps!
Posted on Dec 23, 2008
  • 65 Answers
SOURCE: picture is wider than the screean
There is a service menu that techs can use to adjust vertical and horizontal widths. If it is not an aspect ratio problem then it is likely that it needs to be adjusted.
Posted on Apr 23, 2009
  • 12 Answers
SOURCE: TV has gray screen...no picture... sound works, menu works
check the scart cable/adaptor
Posted on May 18, 2009
I have a toshiba 43ax60 has sound no picture and the power light stays on when powered
you need to explore menue for tv options and select the proper input as well as other options.
Sep 17, 2012 | Toshiba 43AX60 43" Rear Projection...
Some channels on my tv are dark and tinted orange, I used the menu button to display the menue and scrolled down to picture but I did not know how to select picture.
Hello
Adjust colour control to zero, and check for a pure black/white picture. Adjust contrast and brightness control to minimum and check whether the picture goes completly off or a slight picture prevails. If the picture goes out when you turn down brightness control to 1/3 position, that is about 20 points, your TVs screen voltage is very low, and it can be adjustable. If the picture does not go out and more brightness prevails, screen voltage is high. If the screen voltage is high, there will be some fine lines across the screen at about an inch apart; on the whole screen from top to bottom.
Screen voltage adjustment is critical for the clarity of the picture. If it is low, no proper colour will be dispayed. If it is high, it is harmful to both picture tube and your eyes.
Never try to adjust it without proper knowledge about it. The screen control can be located alongwith the LOT [Line Output Transformer], of your tv. There will have two adjustable controls there, one is for Focus, and the other is for Screen. Both are interactive, that is adjusting one will effect an other.
Oct 18, 2010 | Emerson TS2587D 25" TV
Picture on screen is narrow and I cannot select normal view
use menue button on tv if this does not work change main board in tv
Jun 05, 2010 | Panasonic Viera TH-42PZ80U Plasma TV
I am unable to make the screen full size when the
you need to go into the settings on the box and turn off letterbox on the picture setting.
Mar 29, 2010 | Sagem PVR 6280 Freeview DTV Receiver /...
It shows picture not in full screen like the movies black screen at top,in middle is the picture,black screen at bottom
If this happen on DVD's it is because the DVD is formated to Widescreen, 16x9 size, your TV is 4x3 size. Unless the Menu has an option of Picture size, or Format, to set to Full screen. there is nothing you can do other than be sure to check the DVD for picture format size before purchasing.
Sep 28, 2009 | Hitachi 43F300 43" Rear Projection...
Samsung HLN4365W picture not centered
turn the tv off, hit mute 1 8 2 power, the tv will come on in the service menue, look in that menue for vertival and horizontal adjust, after you adjust it, just turn the tv back off, it will save your changes
Jan 07, 2009 | Samsung HLN4365W 43" Rear Projection...
Picture has gone blank
Press menue to see if the menue pops up (yanno for sleep timer and stuff). If not, you need to have it repaired or need a new tv. You could try unplugging it from power for a bit, might help.
If you can see the menues then and your using HDMI, switch to a regular cable line and see if it comes in. Or just tune to channel 4 or somthing and you should get snow. Could just be the HDMI cable.
But if you cant get ANYTHING not even the Ch3 or Volume to show up on the screen, its the screen, a fuse or somthing else
Oct 13, 2008 | LG 42PX5D 42 in. Plasma HDTV
No picture
video board needs to be looked at...
Aug 17, 2008 | Sony KP-51HW40 51" Rear Projection...
Tv goes black
go to main menue,then go to captone menu, make selection captone off. black sqvare is supposed to be off.
Jan 16, 2008 | Sharp 25L-M100 25" TV
Televison & Video Logo
14 people viewed this question
Top Televison & Video Experts
Electro Med Services...
