One For All URC-3021 Remote Control Logo
Posted on Oct 06, 2009
I need codes for a rca tv and a rca vcr - One For All URC-3021 Remote Control
1 Related Answer
Anonymous
  • 7191 Answers
  • Posted on Sep 02, 2009
SOURCE: I need One for All URC 3300 Codes to a Toshiba TV
You can download the required manual with the codes from: http://www.rockabilly.net/files/manuals/URC-3300.pdf
You'll require Adobe PDF Reader installed on your PC to view this manual. If it is not already installed on your PC, download it free from: http://get.adobe.com/reader/
Hope this solves your problem. For more help and clarifications, please reply to this post. Thanks
I have a sony bravia tv and and rca universal remote need the code numbers
TV/VCR Combo.
For power on, these products require programming TV
codes on the remote control. For Sony, use TV code 0000
and VCR code 0032
tip
Dish Network Combo TV/DVD Remote Codes
CODE Broksonic TV/VCR 748 Goldstar TV/VCR 747 Panasonic TV/VCR 747 Quasar TV/VCR 747 Samsung TV/VCR 738, 755 Sylvania TV/VCR 756 Zenith TV/VCR 747 Aiwa TV/DVD 751 Apex TV/DVD 757 Broksonic TV/DVD 752 Konka TV/DVD 753 Panasonic TV/DVD 734, 765 RCA TV/DVD 749 Sansui TV/DVD 754 Sylvania TV/DVD 764 Toshiba TV/DVD 750 Go Video DVD/VCR 692, 693 JVC DVD/VCR 689 RCA DVD/VCR 690 Samsung DVD/VCR 738, 667, 691 Sony DVD/VCR 768
Need instructions for codes for jumbo remote for symphonic tv with vcr
Hello
Setup code for Symphonic TV/VCR with Jumbo remote control is: [002].
There is no setup codes for TV/VCR combo with RCA RCU600M remote control. OK.
I need a code to to turn my tv combo vcr its RCA and so is the the universal remote
An RCA 4-device Universal Remote codes for an RCA tv/vcr combo are 1000, 1003, 1004, 1005, 1006, 1007, 1019, 1054, 1055, 1082, 1096, 1098, 1099, 1100, 1101, 1102, 1103, 1129, 1179, 1181, 1188, 1190, 1196, 1202, 1203, 1212, 1215, 1233, 1257, 1258, 1266, 1278, 1279, 1281, 1286, 1352 . These are the possible codes that RCA gives.
1helpful
I want to use rcr311w remote for rca t25208 tv but couldn't
This remote does not handle combination TV/VCR devices. You will need a different remote. You can get an exact replacement remote here: http://remotes.com/store/rca/t25208.html .
It will control the TV with the code 1000 (most likely). Other RCA TV codes are 11447, 10051, 10093, 10679, 11047, 11147, 11247, 11347, 11781, 12002, 12187. The manual and code list for the remote are available here: http://www.rcaaudiovideo.com/support/?kw=RCR311W . The VCR part uses a code that isn't programmed into the remote. (Remotes generally only have codes for devices released 6 months or more before the remote was programmed. Many of the older RCA universal remotes never had their coding lists updated to include combination units.)
BTW, the manual for your TV is here: http://www.managemylife.com/mmh/owner_manuals/14623/RCA-TV-VCR-or-DVD-Combo-L0109139?brand_name_search=entertainment .
I wish that I had better news.
I need codes for a rca universeal remote model #rca404 no code book
You need to know what you are trying to control. If it is an RCA TV I have 25 seperate codes just for RCA TV's and 19 codes for RCA VCR's etc. Let me know your TV, VCR, DVD, CD and I will try to help... here are the first few codes for the RCA TV... maybe you will be lucky? (0031 or 0004 or 0048 or 0054 or 0094.......)
1helpful
Need to know how to code search for a rca universal remote modelRCR412SI
these are the codes:
Code :1000/3160/2000 for RCA TV/VCR/DVD Code :1000/3408/2000 for RCA TV/VCR/DVD
but bear in mind these codes depend on the device in question.You can go to http://remotefinder.rca.com/default.aspx?site=rca there are codes listed here for rca universal remote control where you can narrow your search by device type,model and other categories. good luck
Need to program my TV-VCR 9" combo using the RCA remote RCC311w
Try pressing the VCR button and see if that works.
Alternatively use one of these codes (For RCA VCR):
2000, 2003, 2007, 2013, 2021, 2022, 2055, 2056, 2082, 2083, 2084, 2085, 2086, 2087, 2088, 2089, 2090, 2091, 2100, 2107, 2115, 2120, 2125, 2133
Two methods of programming RCA remotes:
A: If your remote has a "Code Search" button:
Press and hold the button until the light comes on and stays on, then release and press "VCR", Enter the last 3 numbers of the code (no using the first number 2).
B: No code search button:
Press and hold the device key, while holding it put in all 4 numbers of the code, then release the device key, the light should go out.
1helpful
Need a code for an RCA RCR312w universal remote-Emerson TV/VCR
To see RCA's code list you probably need their website but Emerson is one of several names now owned and built by Funai, who also builds Symphonic & Sylvania.
You might want to try those codes with your set.
7helpful
3answers
RCA Universal Remote set to my Emerson TV
RCA Universal Remote Control Programming Codes Programming Your Universal Remote.
The remote may already be set up to operate your brand of TV, VCR, or Cable Box. It is pre-programmed with following codes:
  • TV-000
  • VCR-000
  • Cable Box-000
  • AUX is programmed with VCR code 037
For brands that require programming, there are two ways to program: Using Code Lists or Code Search. Use Code Search if the code lists are not available or if the codes from the lists do not operate a device.
Programming a Device using Code Search:
  1. Manually turn ON your device (TV, VCR, Cable Box)
  2. Press and "HOLD" CODE SEARCH
  3. Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once.
  4. Release CODE SEARCH.
  5. Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second).
  6. Once the device turns off, press and release ENTER.
  7. With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Programming a device using the Code Lists:
  1. Find codes for each device and brand below.
  2. Press and "HOLD" CODE SEARCH.
  3. Press and release the TV, VCR or Cable button you want to set up. If programming AUX for a device, press and release AUX first and then the device to be programmed (TV, VCR or Cable). When the selected device button flashes proceed to the next step.
  4. Enter the three digit code from the TV, VCR or Cable Box code lists.
  5. Release CODE SEARCH.
  6. With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-5 using another code number from the lists.
Emerson CODES 011,026,027,028,029,030 031,032,037,042,053,064 065,067,075,076,079
Top One For All Televison & Video Experts
ExpressFiX
ExpressFiX
ZJ Limited
ZJ Limited
Are you an One For All Televison and Video Expert? Answer questions, earn points and help others
