I have a pro-99 pioneer elite tv, and have adj. the convergence through the menu, but the screen has a green hue to everything (goes from lighter to darker green sometimes). you can still see the other colors but they are effected by the green contrast. I was given the tv and don't want to put alot of money in it (over $200) what could cause this problem and is it expensive?
techman
  • 3130 Answers
SOURCE: T.V. Convergence
John, im sorry to have to tell you, you have the normal convergence break down, and any adjustment is not going to fix the problem. The Convergence ICs are bad in this set, and both should be replaced at once, as you do not want to pay another repair price 6 months down the road. In these sets there are no user replaceable parts, unless you know how to work on solid state printed circuit boards and understand about the TV safety factors involved. Good Luck Please do not forget to rate this thread.
Posted on Dec 10, 2006
SOURCE: Convergence Problem Pioneer Elite 60"
It sounds like the convergence IC's are bad unless someone has got inside the set and tampered with some adjustments or the set has had a recent rough move. Other possibilities would include defective capacitors/resistors or connections in the convergence circuits or power supply area.
Posted on Feb 11, 2007
SOURCE: color convergence?
Can anyone give me the resistor values for location RK 42, RK 46 and RK 62? Hitachi 46F500 TV. Or can I be pointed to the location of a service manual?
Tony
Posted on Jun 06, 2008
  • 175 Answers
SOURCE: I have a pioneer elite pro 100 projection tv. the
hi..first check it out the brightness.It is available in the
menu button,available on the top of the tv.If it still doesnt
work Projection TVs have a high intensity lamp as the light
source. They wear out and gradually get dim.You probably
need to replace it.
check it out..
thank u..
rate my response..
Posted on May 05, 2009
  • 108 Answers
SOURCE: Pioneer Elite Plasma TV 2-yrs old loses color randomly.
Would need model number to search properly. On some sets a capacitor "C2601" of Y-Drive assembly contacts the audio bracket and it is damaged, can cause a abnormal picture.
Posted on Sep 08, 2009
Testimonial: "Very quick response and they asked for the right sort of clarifying detail that would help get to the bottom of the problem. "
Hello how do i set the convergence manualy on a pioneer elite pro-710hd projection tv i dont have the remote and dont know how to bring the menue up on the tv
You MUST have the remote to perform service operations on the Elites. Look on ebay or do a google search for Pioneer 710 remote.
There is no way to manually do convergence without a remote, and no way to call up the convergence menu.
Feb 05, 2014 | Pioneer PRO-710HD 64" Rear Projection...
I have multiple colors on the screen of my 530hd pioneer elite TV when it warms up. When I try to adjust the convergence I am unable to move the red line far enough to converge on the blue or green line.
The convergence of your tv is defective try to replace it. You will find the convergence chip inside your tv, try to open the back cover of your tv but be sure to unplug the tv first. Try to look the large aluminum plate it is the heat sink, your convergence chip is attached to that heat sink it has a marking of stk-*** followed by a number you should remove it from the pcb using a soldering iron, and soldering pump but be very careful you might damage the pcb and may caused another fault to your unit. Or you can contact a service technician to save you from stress. Good day and best regards.
Jul 19, 2011 | Pioneer PRO-530HD 53" Rear Projection...
Pioneer PRO 510HD - 53"
Boards can run 250 - 400.00 on average. You may be better off just repairing the board parts for around 65.00
See below
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 29, 2011 | Pioneer PRO-530HD 53" Rear Projection...
Multi-point convergence -- Lower left quadrant of screen distorted. Red ok. Blue arched up and then done to normal in Lower right quadrant; left-right adj moves vertical gridline but is s-shaped. Blue...
Look in users manual or internet you should find how to access service mode, this is different from regular setup CONVERGENCE, this involves getting into changing parameters to tweek convergence, even after amps are changed. These projection tv's are known for loosing convergence if bumped, moved and amps go bad in time.
Jan 03, 2010 | Pioneer PRO-520HD 53" Rear Projection...
Adjust color, need service manual
On controlls the foucus...the other the brightness. I would not mess with them. 99% of the time the problems is one of the two listed below...
You have one of two problems. Sometimes both.
Problem #1) CRT Fluid is Cloudy
2c07611.pngSolution #1
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Problem #2)
Your TV may have a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSolution # 2
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Jun 05, 2009 | Philips 9P5544C 55" Rear Projection...
Problem with pioneer elite pro-99
We are having the same problem of the Pioneer Elite Pro-99 turning itself off all of a sudden. The red 'non' power button comes on as if we had turned it off remotely.
We would love to resolve this. If you can help let us know.
Jun 30, 2008 | Pioneer PRO-99 TV
PRO-100 Pioneer Elite
convergence can not go all a suddenly it might be due to magnetic affact.if it is so remove it very near to tv or you must have tilted tv due to some reason. if it is due to ckt near e/w correction.
Sep 14, 2007 | Pioneer PRO-100 TV
Pro 99
Sounds like convergence outputs. Possibly some biasing resistors.
Mar 19, 2007 | Pioneer PRO-99 TV
T.V. Convergence
Dec 09, 2006 | Pioneer PRO-99 TV
Televison & Video Logo
67 people viewed this question
Top Televison & Video Experts
Electro Med Services...
