Question about EA - Electronic Arts skate for Xbox 360
I need help because every time i put in skate 2 in the place where it says start it just goes and says your disc is unreadable
  • 87 Answers
Hi there buddy! This also happens in one of my XBOX 360 games. First thing to check is you need to try other CD of XBOX games. If this works fine, then good! You console is still okay. It is time to check now your Skate 2 CD. Check for any physical damage on the disc, like scratch, crack or even warping. If any of these were found, it is time to buy for a replacement on the game.
Posted on Oct 06, 2009
I dropped my skate 2 on the concrete while letting a friend borrow it and it has a small chip on the edge and it also has like rings on it
thats because the rings damage the data and the chip is like taking a chunk out with a pair of scissors. it garbage now, u have to buy a new one
Aug 05, 2012 | Electronic Arts Skate 2: Platinum Hits...
The consul keeps stopping mid-game & the screen says 'disc unreadable' although disc is perfect
2 things to try here. The simplest is to put a disc drive cleaner into the dvd drive and run it a few times. If this doesn't solve your problem, consider installing the game to the harddrive. Sometimes this helps especially if the error occurs during loading or cutscenes.
Dec 23, 2009 | Microsoft Xbox 360 Console
My disc keeps on saying its unreadable,when i clean it and restart the console,and put it back in the xbox it will play for a while and then it will say its unreadable again
The glass laser eye is what needs to be cleaned or just open the cd/disc drawer and blow inside real hard 2 times and you should be good. Rubbing alcohol and cotton swab.
Nov 12, 2009 | Microsoft Xbox Console
Skate 2 disc
dont play the game then
Sep 30, 2009 | Microsoft Xbox 360 Console
It will read some disks but not all disks and the ones it readds i try to play latter and it dont read
i had this problem with my xbox and its due to either the laser or the magnet within the disc drive that holds the disc in place. the magnet may have come loose which mean u can either open the drive up to try and reposition it, or replace the drive all together. my suggestion would be to send the xbox to microsoft if under warranty or send it to a third party company to see if they can fix it. buying a new drive for your xbox involves some very complex firmware flashing which is not advised
Jun 02, 2009 | Microsoft Xbox 360 Console
Random unreadable disc errors
I had the same problem but i sent it in. They said it was the eye reader error. Or the thing that reads the disc. Try buying a brand new game and try playing it. Alot of times when i have disc read errors i put the disc in where the xbox 360 part at the top goes in facing the xbox. Try that to see if it helps.
Mar 15, 2009 | Microsoft Xbox 360 Console
Well on my technics MK2 1210's, the little anti sketch settings and all the others probably arent set to what they are supposed to be, because my needle arm keeps jumping :P could someone tell me what all...
There are two main things that will influence the anti skate settings.
1) The Headshell Weight and Balance
Firstly, check the data sheet for the cartridge and stylus you are using. It should tell you the correct weight setting which will vary from one cartridge and stylus to another. If the stylus is set too light, it can skate across the disc. This can damage the disc and the stylus. The sound will also be thin and it is likely to distort on high frequencies. If the weight is too heavy, it will not jump but will definitely damage the disc.
If you are a serious vinyl user, get yourself a tone arm balance. This is a device that you place on the turntable and you rest the stylus on a plate which is marked in micrograms. You place the stylus exactly at the correct weight marking and then make adjustments to the turntable settings until the tone arm is balanced. It's easier than it sounds!
If you don't have the data sheet for your cartridge and stylus and cannot find it online, use an old disc that you don't mind damaging, set the weight on the light side and gradually increase the weight until it stops skating.
2) Platter Levelling
Secondly, you need to make sure your turntable us on a level surface. If you are a purist, use a spirit level. to do this.
There are other things that can cause skating and jumping, especially if you use the turntable as a DJ. For example, vibration (caused hopefully by dozens rocking to your music). DJs will often increase the headshell weight very slightly to overcome this and I have sometimes placed the turntables on a thick rubber sheet such as carpet underlay to improve shock absorption.
Mar 26, 2008 | Technics SL-1200MK2 Turntable
PS3 wont read disks
ts a problem with the latest download update. sorry to say but its a job for sony as long as its still under warranty. just phone them up explain the probs your having and they will send you a new (normally reconditioned) unit out. sony's replacement service is very good.
Feb 09, 2008 | Sony Playstation 3 (PS3) Console
Disc unreadable
sounds like dvd rom m8 try it on another console or try anther rom on yours first b4 buying 1
Nov 26, 2007 | Microsoft Xbox 360 Console
EA - Electronic Arts skate for Xbox 360 Logo
82 people viewed this question
Top EA - Electronic Arts Video Game Consoles & Games Experts
James Wishart
 Shayaan Tanwir
Shayaan Tanwir
Person On the...
Level 1 Expert
Are you an EA - Electronic Arts Video Game Console and Game Expert? Answer questions, earn points and help others
