I HAVE A 50DX01B PROJECTION TV THAT HAS NO POWER. WHEN I TOOK OFF THE BACK PANEL AND TRIED TO PLUG IT BACK IN,SOME GREEN LIGHTS CAME ON IN SOME OF THE BOARDS BUT IT ONLY LASTED 3 SECONDS AND THEN THERE WAS NOTHING.THANKS DENNIS
  • dboftampa Oct 10, 2009
    THE POWER CORD AND THE FUSE IS OK BUT THE RED LED FLASHES NEAR THE TRANSFORMER ON THE HIGH VOLTAGE BOARD. WHAT DOES THIS MEAN AND WHAT DO I NEED TO DO NEXT OR DOES THIS RED LIGHT MEAN A CODE OF SOME SORT.THANKS DENNIS
  • 5,807 Answers
a) your 50DX01B TV might be having a component failure .
b) typical voltages and test points are stated in the service manual,
have someone helped you measure output voltages first on the
power supply unit.
c) if you intend to " DIY " the service manual can be accessed,
details
d) it doesn't necessarily mean to get it but if we ever have a hard
time pointing out, where the problem might be, we will be all
basing on the specs of the service manual.
e) if it is totally having no power then most probably , it is on the
power supply, a good visual and voltage measurement is
needed to complete the initial diagnosis of your TV.
f) one such example is having a burnt components, please
include the chassis number so that i can help you more.
or describe the components if you have saw it failed.
Posted on Oct 11, 2009
  • Rommel Cana
    Rommel Cana Oct 19, 2009
    can you tell me what part number is the blinking LED, it is indicated in the board.
  • 11,896 Answers
The power supply will have to be replaced. You can test it if you wish with a voltmeter and the wires from power supply to circuit board. Should be between 12-13.5. too high or too low is bad.
Posted on Oct 06, 2009
Tv will not turn on when tried on either tv or with remote green light flashes 3or 4 times then turns into red flashing light no picture or sound at all.Have tried changing batteries in the remote and fuse...
Hi.The signal lights red means the primary power of your tv is good and the signal lights green indicate the second power.If the green lights is flashing it means that they have shorted parts in the crt board.Maybe the problem is in the power section of the crt.Need for troubleshoot or repair the crt board.
Jul 03, 2011 | Panasonic Televison & Video
My colors are not blending correctly anymore. My green is giving me a double picture. I have tried to blend them on the front and back but not luck. I need help
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 11, 2011 | Hitachi 50DX01B 50" Rear Projection...
Picture will not come on
A few questions and a suggestion:
Do you get sound? Does power light stay on?
suggestion:
Unplug set and remove back cover---set will have several green led lights on board in power supply and one red one.
Red one should be on. While looking from the back have someone turn set on---note if all the green led lights come on and if one or more go off before the others you have located your problem.
The green LED's monitor voltage sources in the set's power supply.
I have more ideas but need more info from you.
If this helps rate this solution as very helpful as I do this here for free.
SD TECH
Aug 18, 2010 | Hitachi 50DX01B 50" Rear Projection...
We are seeing green and pink upper left corner and today it looks like double vision
There's a possibility that you place your tv set in a strong magnetic field. eg. large electric motor. speakers. try reposition your tv set
Jun 26, 2009 | Hitachi 50DX01B 50" Rear Projection...
Magnavox 32mf23id/37 wont tun on
Had the same issue, I replaced two 1200uf caps on the power supply board and now it works fine again. Remember to replace the caps with caps rated for at least 35wvdc.
Jan 29, 2009 | Philips 32MF231D Television
Hitachi ultravision 5oux58
hello it sound's like you have a bad fly back transformer . !!! that might need to be replaced.!!tell me is the set hdtv.? if not you might buy a new set. well hope this help's you "Good luck"
Jul 23, 2008 | Hitachi 50UX58B 50" Rear Projection...
No Power
Yes take it to a repair shop . unless you know how to repair it.tv has power supply problems shorted hori out put transistor.open pico fuse 5amp etc...ect,,,ect.....Its hard to say what might be wrong with your tv untill trouble shooted by techician.
Jan 27, 2008 | Hitachi 50DX01B 50" Rear Projection...
Hitachi 57F510 rear projection tv
Research at www.HitachiServiceUSA.com.........................T.
Oct 13, 2007 | Hitachi 57S715 57" Rear Projection HDTV
Televison & Video Logo
Top Televison & Video Experts
