Question about Memorex MVD2028 DVD Player
I do not have original remote how do i access parental screen without one
  • 11,896 Answers
This is not possible without remote. You can get an ORIGIONAL remote from ebay or
Remotes.com
or
www.PartStore.com
or
www.replacementremotes.com
or
remotes.com/store/main_faq.htm
or get a universal remote from amazon.com or ebay
Posted on Oct 06, 2009
Magnavox #MWC13D5 no remote have converter box Two channels are blocked Parent controll Can TV be reset or can any of the buttons on the front bring up the Menu
Without a remote control, you can't access its menu. If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
Electrohelponline
Jul 29, 2014 | Televison & Video
What is FPA lock on mean
FPA locks the front buttons so children can not access programs without the remote. Use the remote to access the main menu then parental controls. On some models you might have to select special or chanell menu first. If FPA is on it will ask for a password. Turn off parental controls and all should work. This will require the original remote or a universal.
Jul 02, 2012 | Televison & Video
How do i reset the parental controls without a remote?
If the TV has a menu button at its front panel, you can access the parential control window and set the control to OFF. If the TV has no Menu button on its front panel control, you must have its original remote control to access this window. Contact the nearest authorised service center for Vizio at your town, to get an orginal remote control to your Vizio TV.
Mar 01, 2012 | Televison & Video
I bought an insignia tv at my local Future Shop as an out of box item. My problem is that is didn't have a hand held remote and there is a parental lock in place that will not allow me to watch 14+...
Acessing personal secrect codes is not possible,could be anythings,tries call Insignia tv customer service 1-800... telephone line in ur manual ask them how to reset personal screct codes.Must have the original tv remote to do this,like entering numbers.Try website like Remotes.com to buy an exact remote to ur original tv remote.
Nov 15, 2010 | Insignia Televison & Video
How to reset the parental control code - I forgot the code and want to reset with a new one
This is what I found in the instruction manual on this and I posted it here for you. Try using 3355 for the code and everything else listed here. If that doesn't work, try the very last tip which tells you how to do a factory reset and repeat the first step using the 3355 as the code.
Here's the instructions from manual:
Parental Control
Parental Control allows you to block certain channels or programs so children cannot view
programs that are not age appropriate.
To enter the Parental Control menu, you need an
access code. The first time you enter, use access
code 3355. See "Setting an Access Code" on
page 33 for information on creating a new access
code.
You can set the following options to block
content:
• Channel Lock — Blocks selected channels
• Movie Rating — Blocks movies based on their rating (G, PG, PG-13, R, NC-17, and X)
• TV Ratings — Blocks TV shows based on their rating
• Block Options — Turns on or off all your parental control settings
NOTE: You can use Clear All to unblock the channels and programs that you have set.
NOTE: If the Block Control in the Parental Control menu is enabled, all the sub screens in POP (POP1,
POP3 and POP12) mode will be blank
Setting an Access Code m
After you enter the Parental Control menu for the first time, you can set your own four-digit access
code. If for any reason you lose or forget your access code, you can use the default code.
1 In the Parental Control menu, select Change Code.
2 Using the number pad on the remote control, enter a new access code.
3 Select Exit.
Reset the original factory defaults. Press Menu on the remote
control, select Setup, and then select Factory Reset
Jul 28, 2010 | Dell W4201C 42 in. Plasma HDTV
I wnat to unlock my tv without the remote control
If you are referring to a parental block you are able to over ride that. It usually requires having the access code that came with your set and the original remote control. The universals won't normally allow access to the menus required.
I suspect that you may have the ability to do that from the front panel also. You will find that information in the owners manual... You will need to contact the manufacturer online to see if an owners manual is available online. Most of them are if the set is new enough. You will need the complete model number from the back of the set for that.
This is assuming that there is not a defect in the television itself that is always a possibility but less likely than it's a parental block situation and you will need the specific access code to override that.
Mar 30, 2010 | Televison & Video
Original xbox parental controls
You need to have the DVD dongle that plugs into the front of the Xbox in order to play DVD's. If you do have that, any universal remote should work on it, I use a GE AllinOne universal with mine, I think the program code is 000 or 0000.
Or, if its the lock thats getting you down...
Here is the procedure to reset the parental lock code:
  1. From the XBOX dashboard screen, go to settings and then parental control.
  2. When prompted for the password, perform the following sequence using the XBOX controller: X, Y, Left Trigger, X.
  3. Enter in a new password, or disable parental control entirely.
Hope this helps!
Jan 09, 2009 | Microsoft Xbox Console
Have 27' Apex tv, model #2702S. A red key is in the lower left corner of a blue screen. No direct or remote response. Have tried unplugging it.
parental control is on, need original remote to turn off parental control, something like push F key down and something else at the same time, I need original remote, cannot find one to buy
good luck with your problem
Sep 16, 2008 | Televison & Video
Parental Lock
Without an original remote, I'm afraid my friend, not much
Feb 11, 2008 | RCA TruFlat 27F520T 27" TV
Memorex MVD2028 DVD Player Logo
Top Memorex Televison & Video Experts
 Grubhead
Grubhead
Radames Pagan
Radames Pagan
Are you a Memorex Televison and Video Expert? Answer questions, earn points and help others
