Question about Samsung (DSSM522452OEM) CD-RW Burner
No support drive detected" on NTI CD and DVD maker version 7. Please help!!
  • 53 Answers
The driver needed to run this version is not installed or loaded.
have to installed the driver in oerder to run the cd and dvd maker version
Posted on Oct 06, 2009
How do i uninstall cd dvd maker 7 plat
( In Xp) Go to Start menu> Control panel > classic view on left side.
Add/remove programs
select the Cd Dvd maker 7 and click on remove.
This must take a while and uninstall the software.
If you get any error it will not be removed, there are other procedures to remove if you get error.
If you get error while uninstall contact me I will guide you.
I hope this helps you.
Rate my solution.
Regards
May 25, 2010 | Newtech NTI Media Maker 8 Suite for...
I THAVE TRYED TO COPY A DVD WITH MY NTI CD&DVD MAKER, BUT I'AM UNABLE TO COPY THE DVD? ANY HELP WOULD BE GREAT!! THE PROGRAM IS ''NTI'' 7 GOLD; IF THAT HELPS ANY...
I would suggest that you should try out NERO Burning software instead. I have been using it for years and it works like magic.
Even if you just need something very urgent, you can download and use the trial version with the trial key.
It is a very self-explanatory software and shouldn't give you any problem when install it.
The link to the trial version is:
http://www.brothersoft.com/nero-7-ultra-edition-download-45110.html
Kindly let me know how it goes.
Good luck.
Nov 05, 2009 | Newtech NTI CD-MAKER DELUXE V6 (3692)
The drive database cdrw32.bdb cannot be found i tied to replace file still didnt work now also says nti has stopped working
The following is installation instructions for CD-Maker Professional. For Backup Now, the instructions are the same, however, you will install it in the NTI Backup Now directory, rather than the NTI CD-Maker directory.
To install, please copy the "cdrw32.bdb" file use Windows Explorer or My Computer to copy the database file into the main folder for CD-Maker 2000 Professional. If you installed our software in a different directory then you will need to copy the file into your alternate location.
Example where database file is located:
C:\Program Files\NewTech Infosystems\NTI CD-Maker 2000 Professional
You can also use the find feature in Windows to find the exact location of the database file. Click "Start", the "Search", then "for Files and Folder", then type in cdrw32.bdb and click "Search Now". After it finds the file then you can read under the "In Folder" heading for the correct path where the database file is located. Use Windows Explorer or My computer to copy the database file into this location.
NOTE:
(1) It works only on full retail versions of NTI software
(2) For CD-Maker, it works for Version 5.1.1 or later.
(3) For NTI Backup Now, it works for Version 2.2.33 or later.
(4) For supported DVD burner models, CD-Maker V5.1.XX and Backup NOW! (and DriveBackup!) V2.X will support only the CD burning function of these models, not DVD burning. DVD burning is supported starting from Version 6.0 of CD&DVD-Maker, and Version 3.0 of Backup NOW! and DriveBackup!, respectively.
Thanks for using Fixya
Sep 13, 2009 | NTI Computers & Internet
NTI CD & DVD-MAKER 1% was not installed properly, or it was alter
1 Close all programs and applications
2 Press Alt+F10 Simultaneously
3 If prompted create a personal password and continue
4 Click Restore located at the bottom of the eRecovery utility
5 Click Reinstall Application/Driver
6 Wait for the system to load then left click on Install
7 Select your version of Windows from the left page
8 Click on Applications from the drop down list
9 Click on the Application you wish to reinstall
10 Click on the Install Now link to run the setup
11 Follow the screen prompts
I hope that this resolves your issue.
Aug 19, 2009 | Acer Computers & Internet
NTI CD&DVD maker no longer works
Dont worry about this..
1st :just open ur CPU and change IDE cable...
2nd:use CD cleaner with IPA...
3rd :Check Ur CDs and DVDs...
Thanks & regards
TENNISON J
tennison_2006@rediffmail.com
Apr 06, 2009 | Acer Aspire M5100 AM5100-U5313A AMD...
Dvd maker on aspire 3690
Hi Artmovements,
Well first off you need to get Acer to send you the disk... you are entitled by law to have it as it is not pre-installed.
However, I think the point here is not if you have the software, but if you have the right hardware.
You see, all computers can burn CD/DVD IF they have a DVD burner fitted. It sounds to me like you have a CD/DVD Combi-reader fitted which will let you listen to CD/DVD and will also burn CDs....but WILL NOT let you burn a DVD.
I checked the web for specs for your computer and all I could find seemed to back this up.... however if you can tell me what the computer says is fitted that would help.
You can find that info out by either looking in the manual it came with or by looking in your device manager and that will tell you what the CD/DVD is.
let me know ok... but I really do believe that you will find you have a combi unit and not a DVD burner. If so you need to buy one... and may I suggest you look at an external USB one, like the LG Super Multi...its good for price and is a nice fast and well made unit.
Good Luck and I hope this has helped you.
Nov 06, 2008 | Acer Aspire 3690-2196 Notebook
Sony DVD RW AW-Q170A Burning Problem Plzzz.....Help me out: i have two drives, 1) Sony DVD RW AW-Q170A 1.70 Ver 2) Sony DVD/CD-RW Combo RYK4 Ver My "Sony DVD RW...
Check that the writable DVDs you are using are compatible (+/-) with your Sony DVD-RAM.
Go to Windows Explorer and check to see if the Sony drive is visible. It may not be connected or the Jumper switch may be set incorrectly.
Check you have drivers installed, take a look in Hardware manager.
Sometimes, it's a little difficult to copy CDs and DVDs when you have more than one burning suite installed - for some reason, they 'just don't get along'. Try uninstalling any suites other than Nero.
Or it may just be that your Sony CD-RW drive is just that, and your DVD-RW drive is just that. So it wouldn't be possible to write DVDs on the CD-RW and CDs on the DVD-RW? Though I would assume Nero would detect that and use your hard-drive as temporary storage.
In Nero SmartStart, have you selected the CD or DVD tab to correspond to the project you're burning?
Jan 07, 2008 | Sony AW-Q170A-B2 DVD RW Dual Layer Burner
Nti cd & dvd maker 7
try with other dvd writeing software like nero or roxio or you can try your own nti cd & dvd maker by re-installing bye
Sep 23, 2007 | Acer Aspire 5003WLMi Notebook
Samsung (DSSM522452OEM) CD-RW Burner Logo
144 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
phoenix chi
phoenix chi
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
