Question about GE Dryers
Dryer gets too hot, so hot you cannot touch outside top of thr dryer. drum sizzle if you sprinkle water on it.
  • 23 Answers
Inside back panel on the outside of the heater element enclosure there are over heat thermostats..round with two screws...
Posted on Oct 06, 2009
Why is the outside top so hot to touch. It is 2 weeks old and Vents were cleaned before using.
DRYER OVERHEATING:
Heating Element
A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal
Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel
A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
https://www.youtube.com/watch?v=3m5NZvY9V5Q
GOD IS still GOOD !!!!
Apr 30, 2015 | Hotpoint Hot Point HTDX100EMWW Electric...
Stackable kenmore washer dryer
could be a clogged pump or drain hose causing the water to spin over the top
Jan 15, 2013 | Washing Machines
Hot water out of telltail
the real test is to sprinkle water on the powerhead an see if it sizzles.
Nov 18, 2012 | RTO Outboard Motor Bass Fishing Boat Rod...
Hot Point Dryer won't dry, gets hot on top.
An educated guess would be either the lint tube or the tube that exhausts the air outside is blocked with lint----no airflow or greatly reduced flow will cause this symptom.
Nov 06, 2012 | Hotpoint Dryers
Cmd146 dryer heating top chamber but not in drum
It sounds as though the fan motor is faulty, usually these motors distribute the heat from the heater box into the drum. Because the heater box is getting hot I doubt if the fault is the thermostat so it may well be the motor or associated wiring
Mar 29, 2017 | Candy CN146 Front Load Washer
The dryer is hot to the touch inside the drum
two issues the heat thermal relay or the fan motor quit working you can go to www.appliancepros.com and look up the parts list for your model.
Apr 14, 2010 | Amana DLE330RAW Electric Dryer
Dyer really hot, not drying clothes
Is the dryer tumbling? If not, you may have a broken belt or some other drive assembly issue.
Also, turn the dryer on and go outside to the vent discharge - you should feel air coming out at a pretty good clip. If not, the vent line is obstructed and will need to be cleaned out.
Jan 07, 2010 | Dryers
Dryer gets hot but wont dry clothes
Do you know if the dryer vent is free of obstructions?Check outside where the dryer vents outside ,and see if the air is weak or flowing freely.If it is not clogged the air should be pretty strong from the vent outside.If it has blockage it will definitly take longer to dry your clothes.
May 17, 2009 | Roper RGX4634KQ Gas Dryer
Very hot to touch on top
Sounds like you have a clogged vent hose or clogged duct work leading to the outside of the home. Make sure you have no obstructions in the exhaust system including a functioning flap on the outside wall cap.
Jan 03, 2009 | Frigidaire GLER341A Electric Dryer
The top is too hot to touch.
You may have a blocked vent, check your vent all the way to outside. if there are any droops in the vent there may be accumulation of water in it. just drain it out and then you should be all set.
Nov 03, 2008 | Frigidaire FEQ1442ES Electric Dryer
Dryers Logo
225 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
