Question about Brother MFC 420CN All-In-One InkJet Printer
My scanner has never worked
When i installed the all in 1 on my computer all works except the scanner
  • 1 more comment
  • Anonymous Dec 27, 2007
    cannot communicate whit the device show this cc027
  • Anonymous Feb 13, 2008
    cant scan.say connecting to the Pc for a ong time then goes back to default mode.
  • Optic Feb 14, 2008
    that link doesnt help at all it is a faulty link and everything on my mfc420cn works except the scanner I get the message to hook up the usb and turn off machine and back on again. interesting when everything else sees the usb like the printer and fax but the scanning function???
The registry patch file suggested by "mistertee" is also available via the Brother site:
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000600/000037/faq000637_000.html?reg=us&prod=mfc7220_us_as&c=us&lang=en
If the link doesn't work try searching for the filename using Google (for example). I would hesitate to download anything from an anonymous website, but this file is available directly from Brother.
This patch solved my scanning problem after I had wasted several days struggling.
Posted on Apr 01, 2008
Your problem is probably due to a bit of faulty code in the installation CD. Point your browser to the following URL and download the patch.
http://209.215.81.199/download/mfc/BrWIARegRepair.exe
Extract and run the file (BrWIARegRepair.exe). Reboot your PC and attempt to scan an image through ControlCenter2. Hopefully this will solve the problem for you.
Good luck :-)
-Mike
Posted on Jan 22, 2008
  • 832 Answers
Can you do a normal copy in b/w and in color?
If yes, the scanner hardware is ok. In that case you have to uninstall and reinstall the mfl-pro suite. If you are working thru network instead of usb, check the firewall settings.
Posted on Dec 23, 2007
How to fix scanner error 6?
herewith 3 suggestions (try searching the HP forum or search engine 'scanner error 6'). Read all of them before you decide to do anything and only then decide which order if any to do them depending on ease vs likely effectiveness.
HP LaserJet 3055 Scanner Error 6
HP Laserjet 3055 Scanner Error 6
6.July.2015
Jul 06, 2015 | HP LaserJet 3052 All-In-One Printer
CanoScan N650U TWAIN problem
ok two possibilities...
1. try this quick faq
2. try downloading vuescan... it works but for it to work perfectly you need to register it... otherwise it shows dollar signs over everything...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Dec 21, 2009 | Canon CanoScan N650U Flatbed Scanner
Scanner not detected by Microsoft Office Document Scanning
1) Install the Microsoft Office Document Imaging feature by following the steps
given below:
1) Go to Start -> Control Panel.
2) Click the Add or Remove Programs.
3) Select the Microsoft Office Professional Edition 2003 and click the Change
button.
4) Click the Add or Remove Features and click on Next.
5) Select the Choose advanced customization of applications checkbox and click
Next.
6) Click on the Office Tools -> Microsoft Office Document Imaging -> Scanning, OCR
and Indexing Service Filter.
7) Select Run all from My Computer, insert the Office installation CD, and the
feature is installed.
Jan 24, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Scanjet 3690 problem
I reformatted my computer with Windows XP home addition and re install all programs except IE 7.
I then re install the scanner driver and HP director that was distributed with the scanner, and after that Director was working fine
Thanks
Dirk
Jan 14, 2009 | HP ScanJet 3690 Flatbed Scanner
Loading HP scanjet 4800 onto vista
Hi there from Germany - English isn't the best but got the same problem solved so give it a try:
- first connect scanner to computer without having the drivers already installed
- next computer claims driver cd put in yours from XP or select downloaded XP-driver
- reboot
- try if scanner works - sometimes they do already
- if not head over to System management or system control what it's called in english
- choose add device and choose scanner
- now Windows tries to install a xerox-driver - allow this
- reboot
- and now it should work - if not sue hp! (But buttons for direct printing etc. might not be working anymore - except via the software itself - no more via the buttons
Hope I could help
Dec 20, 2008 | HP Scanjet 4400c Flatbed Scanner
Win vista doesn't accept hp scanjet 4400c downloaded driver
- reboot
- reboot
Hope I could help
Oct 21, 2008 | HP Scanjet 4400c Flatbed Scanner
Canon pixma MX310 scanner not working
I read somewhere that the printer/scanner must be plugged directly into the computer in order to scan.  I tried it, and it works.  Printing can be done wirelessly, but apparently not scanning!
Oct 09, 2008 | Canon PIXMA MX310 All-In-One Printer
Scanner
1. try to print a test page.
2. if test page ok, turn of all of your firewall application, then check if panasonic communication utility is running as seen
on task bar (blue colored icon near at the volume control)
3. if it is running, double click it (PCU). scanner configuration must appear
4. the scanner configuration details about how you receive the document (popup or etc), program to open (you may even use adobe pdf reader), and the display name of your computer that will be seen on scanner directory of the machine.
May 22, 2008 | Panasonic Workio DP-3530 Copier
All in One Scanner/Printer problems
Go to this link and type "cannot communicate with scanner" in the search box. Click Search. Then select the "ERROR: Cannot communicate with scanner" link. You will see several things to try to correct your problem. Usually, this error shows up if there is another USB device connected which prevents the computer from "seeing" the scanner, even though it can print without problem. So do try to disconnect any other USB device (except mouse or keyboard) and reboot the system.
May 20, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Install my scanner with winXP
how to install my scanner acer Prisa 340p with winXP because the installation CD support only win95, win98, winNT,and when I connect the scanner to the computer ,the computer can see the new hardware but the installation failled, and the scanner doesn't work with the pc, what can...
Dec 02, 2007 | AcerScan Prisa 340P Flatbed Scanner
Brother MFC 420CN All-In-One InkJet Printer Logo
313 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
