Question about Sewing Machines
As I'm sewing a straight line, my bobbin thread skips several stitches at a time every few inches. It just started doing this. What can I do to stop it from skipping? Thank you.
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 152 Answers
When a machine skips stitches like you described either the needle is in backwards, the machine's thread could have jumped out of a guide, the needle is the wrong style for the fabric being sewed or you need to take it to a technician. So try a new needle first, they can be bent without looking bent and skip just like you described. Then double check your threading. If the fabric your sewing is a stretch fabric then a ball point needle should be used. A sharp type point needle will not sew on stretch fabric. If your machine has a drop in bobbin or a bobbin that loads from the front of your machine, the flat part of your needle faces the rear of the machine. Good Luck, I hope this helps.
Posted on Oct 08, 2009
  • 3 Answers
Try adjusting the bobbin case tension
Posted on Oct 06, 2009
Skipped stitches
Skipped stitches could result from several different origins. First, easiest, and least expensive thing, try a brand new needle. However, if it is failing to pick up the bobbin thread all together, then it is probably out of time (search for sewing machine timing or take it for service).
Here are other suggestions for intermittent skipping:
What to Do If Your Sewing Machine Is Skipping Stitches
10 reasons for skipped stitches
Basic Maintenance Tension Skipped Stitches
http://www.sewingreviews.org/what-to-do-when-your-machine-starts-skipping-stitches
Jan 03, 2017 | Sewing Machines
When sewing...my bobbin thread is not catching all the time.
YOUR TIMING SOUNDS LIKE IT IS NEEDING TO BE SET. TO TEST THIS TRY YOUR NEEDLE WITH A STRAIGHT STITCH ALL THE WAY TO THE LEFT AND THEN ALL THE WAY TO THE RIGHT. IF YOU CAN NOTICE ONE BETTER THAN THE OTHER IT IS OBVIOUS THE TIMING IS NEEDING TO BE ADJUSTED. THERE ARE PLACES ON YOU TUBE THAT GIVES INSTRUCTION HOW TO DO THIS IF YOU''RE NOT AFRAID OF TACKLING THIS YOURSELF.
Jan 29, 2015 | Sewing Machines
Why does my thread knot on the back when stitching in place?
Several things to try:
Pull thread tails (both bobbin thread and upper thread) straight back and when you lower the presser foot, make sure they are held down straight back. This may or may not be enough to solve the problem, but it is simple to try, and often works. You might want to hold the thread tails while you start sewing.
Use a starter--folded piece of fabric scrap about an inch long--and begin sewing oink middle of starter. Push the fabric you want to see right up to the starter and keep sewing from the starter right onto your project without lifting the presser foot or cutting the thread. When you finish sewing, cut the little piece of thread between the starter and your project.
Before lowering presser foot, use wheel to lower your needle once and then pull up bobbin thread to top surface of your project. Then hold both bobbin and upper thread tails, lower your presser foot, and begin sewing. Release the thread tails after a few stitches.
Hope this helps. Those nasty "thread nests" are a real pain.
Jul 13, 2014 | Janome Sewing Machines
Skipped stitches
lower your needle. If up to high can't catch the bobbin thread.
Aug 31, 2017 | PfaFF Tiptronic 2040
Bernina activa 210 won't zigzag and has bobbin issues on straight stitch
it's very possible that the machine is slightly out of time & needs to be service at a sewing machine shop
is the fabric & thread & needle compatable with each other?
did you use every thread guide when threading the machine?
is the bobbin in correctly?
is the bobbin warped?
Mar 20, 2012 | Bernina Sewing Machines
I think the timing is out on my janome 2039 sewing machine
It is very possible that the timing is off, which often occurs with broken needles. A common symptom is that the needle will not pick up the bobbin thread. Missed stitches aren't necessarily timing related--be sure to install brand needles often and use the correct needle for the fabric & thread you are using. Using the wrong needle will often cause skipped stitches.
Here What to Do if Your Sewing Machine is Skipping Stitches
You can search for sewing machine timing or take it for service.
Apr 12, 2017 | Janome Harmony 2039 Mechanical Sewing...
Sewing machine not stitching
Sounds like you need to retime the machine, if you email me I can attach instructions drivewithken@blueyonder.co.uk
Jun 26, 2010 | Kenmore 15212 Mechanical Sewing Machine
Sewing Machines Logo
291 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
