Question about Kitchen Ranges
Where are the ''burner fuses'' on a Matag smooth top range
    President:
  • 1,304 Answers
Tghere are none the are wired directly from the robert shaws
the sensors are the tubes in the middle of the burners
Posted on Oct 06, 2009
How do I change a burner on a smooth top stove?
usually the top will tilt back so you can get to the elements .
Apr 09, 2016 | Kenmore Kitchen Ranges
Where are the fuses for the Sears Kenmore stove to elements located on Model C880 675080L0
Most likely no fuses. Either the element or the switch that turns it on is bad. If lighat comes on when you turn on burner the switch is probably ok and the burner went bad.
Jan 02, 2015 | Kenmore Sears Electric Range Surface...
Surface burner on electric smooth top range not heating. When turned on, the left rear burner does not light up at the dial or on the surface. How can we determine if replacement is necessary or there is a...
I have a GE Spectra smooth stove top and it has two burners in one, The problem is that the inside burner is not working. I need to find out how I can get into the stove to see how to fix it. Does anyone else have this problem and how did you fix it?
Jan 24, 2010 | Kenmore Kitchen Ranges
My smooth cook top is cracked, can I still use the burners?
using a cracked cooktop is highly dangerous. i have seen these cooktops shatter because of people using them with a crack. One shattered so bad that the glass was found all over the kitchen and the ajoining living room.
Please dont use it, for your safety, repair or replaced the unit
Apr 12, 2009 | Whirlpool Accubake RF362LXTT Electric...
Front right 8'' surface burner dose not light up period.
it could be your burner but most likely your infinite switch for that burner
Mar 21, 2009 | Kitchen Ranges
Glass top stove
you can try a flat blade rasor blade, cerama brite smooth top cleaner and some elbow grease
Feb 08, 2008 | Frigidaire FEF366 Electric Kitchen Range
Kenmore smooth top - cooking problems
Smooth tops take a little geting used to than a coil top range....Make sure you have good flat cookware. NO GLASS COOKWARE. (ie vision ware.) Once the burner is set to high, it has to heat the glass, then the pot, so it does take about 2 min loger to boil, If you want to simmer, then i suggest bringing the item to a rapid boil, and then cutting back the heat to below the 1 on the range. and adjusting from there. All smooth top glass ranges do work in this manner. Most people can adjust to the switch, but not everyone can. there really is no problem with your range. BTW i work at sears, and i am surprised that no one helped you.
Dec 20, 2006 | Kenmore 96412 / 96414 / 96419 Electric...
Kitchen Ranges Logo
274 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
