Question about Kenmore Refrigerators
Kenmore Model 106.54619300
Ice maker just stopped working. Still fills with water and makes ice, but ice doesnt drop into ice bucket
    President:
  • 1,304 Answers
Not knowing your ice maker model
if you have a white box like cove on the end,
pop that off
you will be looking at the ejection moter wheel
to the botom right, you should see two holes
one T one H jumps those out with a small peice of wire, you may need to hold the door switch on the freezer,,,,
if you jumped it out correctly, yo will hear a definitive click,
take out the jumper
watch the whole cycle 3=mins
keeping an eye on the ice machine the whole time
if it does everything but eject your motor is stipped
and you will need a new one
Posted on Oct 06, 2009
My icemaker stopped working but the water on the door still works what can the problem be model number 106.51552104
02fd7a9b-9a65-43a6-ae76-6bf68d211304.jpgThanks for the model number. If the ice slots inside the ice maker are empty try pouring tap water in and allow the water to freeze. If after the water freezes the ice drops into the ice bucket and the ice maker does not refill this would indicate that the side of the=> W10408179 Water Inlet Valve is defective on the side that controls ice maker water supply. If the ice maker just sits there and does nothing this would point to a defective ice maker. Depending what is wrong with the ice maker will determine what parts are replaced. Here is a list of those parts here=> Kenmore Refrigerator Model 106.51552104 Ice Maker Parts and if need you may be able to find a complete ice maker replacement by asking. Most people don't like replacing ice maker parts. I am here should you have questions or comments, Sea Breeze
Aug 30, 2013 | Kenmore Refrigerators
I have a Kenmore model number 106.51552104 my ice maker stopped making ice.. The water on the door still works but no ice what should I do??
I believe I answered this one on another page of unsolved problems HERE. Thanks for the model number. If the ice slots inside the ice maker are empty try pouring tap water in the slots and allow the water to freeze. If after the water freezes the ice drops into the ice bucket and the ice maker does not refill this would indicate that the side of the=> W10408179 Water Inlet Valve is defective on the side that controls ice maker water supply. If the ice maker just sits there and does nothing this would point to a defective ice maker. Depending what is wrong with the ice maker will determine what parts are replaced. Here is a list of those parts here=> Kenmore Refrigerator Model 106.51552104 Ice Maker Parts and if need you may be able to find a complete ice maker replacement by asking. Most people don't like replacing ice maker parts. I am here should you have questions or comments, Sea Breeze
Aug 30, 2013 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice maker stopped working...water works, ice tray has water, ice maker is turned on. curious if I should just replace the motor or if it could be something else
If your ice maker is not making ice and you poured water into the ice maker, that would indicate the ice maker is not cycling. If you have any make or model except a whirlpool, kitchenaid or sears kenmore, if you replace the ice maker, you will be making ice in no time. If you have one of the aforementioned brands, AND the ice BUCKET is mounted on the door, you will have to replace the electric eye boards on either side wall as well, as these often short, damaging the icemaker electronics in the process.
Nov 09, 2010 | Kenmore Refrigerators
I am not sure this is the right refrig. I have a model 253.78259800 top freezer with a model JD-21 ice maker. The ice bucket keeps filling up with a solid piece of ice. It makes and drops cubes, then water...
there s a adjustment but it only controls /like 1 to 2 oz of water . its prbably the ice mker unit or the water valve . .. ice mker tell water how long to let water in and if valve is bak it might not shop off causing water fill . change water valve first . then ice maker if needed .. icemker might have a bad tray and some cubes do not drop / if so next fill will over fill causing problem . mm
Dec 07, 2009 | Kenmore 21.7 cu. ft. Top Freezer...
Ice maker won't stop producing ice, even when bucket is full.
the arm that swing up and down maybe able to be ajst by bending arm and the water leaking down the icemaker. is it unlevel when if fills if not unlevel is it hooked up to an r/o system if it is when was the last time filter were replaced if not, does it have a water filter has it been changed lately.
Aug 20, 2009 | Kenmore 57029 Side by Side Refrigerator
Kenmore Ice Maker not dropping ice
Sounds like the arm which determines if ice bucket is full is hanging up on something. Does this arm move up and down freely? If not, you just need to replace the complete ice maker.
Nov 06, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kemore coldspot no ice?
no you ice it is on a separate valve as the water in the door so the water flow don't mean a lot in this case remove the front plastic cover on the icemaker and you will see a bunch of little holes make a jumper wire out #10 or 12 house wire strip about 1/4 inch off the ends an insert in the holes marked t&h this will start a test cycle make sure you hold the plastic insulation so you don't get bit if the ice maker starts cycling remove the wire and watch for it to stop listen for the icemaker valve to open if the ice maker finishes and the valve didn’t fill replace the water valves if the icemaker doesnt cycle and you may have to kind of twist the jumper back and forth to get it to make contact depending on the gauge you used then replace the ice maker motor module if you hear the valve open and the ice maker doesnt fill check for a frozen ice fill tube that should do it
Mar 28, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore Refrigerator stopped dispensing water
Look up through the ice despencer on the front door of the freezer. Is the flapper door open? If so it needs to be fixed. If its not then try leaving the freezer door open for 3+ hours to defrost the frozen line in the door. If that doesnt work, the water valve must be changed.(located behind fridge, take off back cord board panel at bottom, the valve is blue)... GOODLUCK!
Dec 31, 2007 | Refrigerators
Ice maker not making ice
you need a module cant remember the part number off the top of my head but go to repair clinic .com or your local appliance parts dealer with model and serial # in hand it may be quicker for you to get a new ice maker and easier
Dec 03, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
152 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
