Question about Dell A940 All-In-One InkJet Printer
The computer recognizes the printer and goes through the steps of printing, says there is plenty of ink but the page still comes out blank
2 Suggested Answers
  • 98 Answers
SOURCE: the computer recognizes the printer and goes
Your solution is to dial and call DELL so that they can replace your printer as it was.
Posted on Oct 06, 2009
Printing blank page
Open the top and make sure the carrier is not stuck to one side and also check that the drive belt is on.
Jan 27, 2014 | Canon PIXMA MP600 all-In-One InkJet...
Hi.. I have a Lexmark X6180 printer and it stopped printing. The paper goes through, and it sounds like it's printing but the paper is blank when it comes out of the printer. There's plenty of...
It could be that your cartridge needs cleaning. On your computer, go to Start menu > Programs / All Programs > Lexmark 6100 Series > Lexmark Solution Center. Go to Maintenance tab > select Clean to fix horizontal streaks. Your printer will then print a page forcing ink through the cartridge nozzles and clean them. Try to print your document again and determine if the problem is fixed.
Jun 24, 2011 | Lexmark X6180 Printer
Does everything as if it is printing but the page comes out blank. Plenty of ink in the cartridges
Try to do the Deep Clean Printhead function on the printer. Press Setup button > Maintenance > Deep Clean Printhead. Your printer will then print a page forcing ink through the cartridge nozzles and clean them. Try to print again.
Jun 01, 2011 | Lexmark S305 IMPACT LEXS All-In-One...
No printing is made only blank paper is coming out
Hello
1 Clean Print Head
The print head gets clogged due to frequent usage. Therefore, the ink will not be able to get out of the cartridge. Hence, the printer only prints blank pages. The solution to this problem will be to clean the print head. This can be done by cleaning it with a damp cloth or with an Iso Propyl Solution.
2 Check if Cartridge is Empty
If this does not work, your next step would be to check if there is any ink in the printer cartridge. You might be giving a command for a high resolution printout, but the ink might not be enough for such a purpose. Look out for the printer prompts that will tell you about the low levels of ink.
3 Install the Correct Printer Driver
Many a times if you are downloading a printer driver from the internet, you might download the wrong driver. This will result in the computer not recognizing the printer. The result is blank pages.
4 Check for Appropriate Paper Size
Another facet to be taken care of is the paper size. You must check the Page Setup Dialog box whether you have selected the settings that are in tune with the paper size that is being used for the printing.
5 Check the Operations
If nothing works for you, then a printer operations checks is in order.
THANK YOU FOR VISITING FIXYA
Jan 30, 2011 | Office Equipment & Supplies
When I print only a white page comes out, with no text. Do you know why this happens? It just started 2 days ago. It's not an inc problem.
STEP 1: Clean Print Head
STEP2: Check if Cartridge is Empty
STEP 3: Install the Correct Printer Driver
STEP 4: Check for Appropriate Paper Size
Another facet to be taken care of is the printer size. You must check the Page Setup Dialog box whether you have selected the settings that are in tune with the paper size that is being used for the printing.
Jan 13, 2010 | HP DeskJet 9800 InkJet Printer
HP 400 Printing a blank page
You could try the following Steps from HP's Homepage :
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=au&docname=bud09143&dlc=en&product=58649
Nov 24, 2008 | HP DeskJet 400 InkJet Printer
Printer wont print the paper goes through the motion but no print
even when you change your ink sometimes you get dried up ink in the feeder lines take your ink cartridges out, take a damp cloth and wipe over the tiny holes were cartrides go, replace cartridges and press down several times firmly about 5-6 times on each cartridge that should start ink flowing
Nov 20, 2008 | Epson Stylus C46 InkJet Printer
Lexmark z640 has stopped printing - goes through the motions but no ink on page
Some third party cartridges will not work with your printer as they are remanufactured from used cartridges.
It is more expensive to buy genuine Lexmark ink, but atleast you know it will work.
You may try reinstalling the driver before buying new ink.
I hope this helps.
Good Luck.
Oct 18, 2008 | Lexmark Z640 InkJet Printer
My Epson 680 Printer only gives me blank pages
First of all, there is the seller's liability here. If it's from eBay, there's some protection feature for you to use. The "prints blank pages" problem is believed to be caused by a clogged purge tube. Here is a guide I found that exlpains the problem, and how to solve it: Recently, after changing out the blank ink tank on my finacee's Epson CX5400 multifunction inkjet printer, the printer began printing nothing but blank pages. Even after doing multiple head cleanings and test prints, pages would emerge from the printer completely blank. After some research, a number of fellow CX5400 owners have reported having the same problems, to the extent that the term "design flaw" became a common theme. I've owned several Epson printers and have had, generally, good luck with them. I was always somewhat suspicious of Epson's philosophy of making the print heads a permanent part of the printer and having the only replaceable part be the ink tanks, but it produced good-looking prints so it didn't bother me. Now I know, unfortunately, that this system is both a blessing and a curse. Before we delve into how to fix your blank-page-printing problem, a quick explanation on how Epson's ink delivery system works (or, rather, how it appears Epson's ink delivery system works, because Epson isn't exactly willing to divulge its trade secrets) is in order. There are a few components to the delivery system. First, you have the ink tanks. Early Epson tanks were just that; plastic boxes with a sponge inside saturated with ink. Newer tanks have a small PCB with a flash chip on it, so the printer can tell if a tank is new or used, or if it's an Epson brand cartridge or a generic replacement. In either case, the basic functionality is that it's a holder for the ink. Next in the chain are the ink tubes and primer. I've heard conflicting reports on how Epson printers get the ink out of the tanks; some believe that the tanks are positively pressurized when first installed, so that ink shoots out of the tank when the printer needs it. Other reports say that the printer puts negative pressure on the cartridge to draw ink out of it. Once the printer has the ink out of the cartridge, there are two places it can go, to either the print heads or to the purge tube. The print heads are what makes the ink spray onto the paper; the purge tube is where the ink goes when the printer primes new cartridges and cleans dirty print heads. Many cases of the "prints blank pages" problem occur right after installing new ink tanks. People have literally removed empty tanks from printers that work perfectly, and installed new tanks to find that the printer delivers blank pages (this happened to me). Since it's highly unlikely that the print heads have become clogged during the 5 minutes it takes to swap out the cartridges, the problem has to be elsewhere in the ink delivery system. So here's what happens when you install a new ink tank: 1. The new tank is installed, the printer recognizes that it's a new tank, and begins the priming sequence. 2. The printer starts to prime the tank. Ink comes out of each tank and is directed to the purge tube. 3. The ink flows through the purge tube into the internal absorbent pad. 4. After a couple seconds, the printer stops the priming sequence and probably does a quick print head cleaning. Now, a few people have done some in-depth troubleshooting and found that the "prints blank pages" problem is actually caused by a clogged purge tube. While this may not immediately make sense (you may be thinking, "so what if the tube is clogged, the ink will just spill inside the printer elsewhere"), here's what my research suggests happens when the problem occurs: 1. The new tank is installed, the printer recognizes that it's a new tank, and begins the priming sequence. 2. The printer starts to prime the tank. Ink comes out of each tank and is directed to the purge tube. 3. The tube is blocked, so the ink has nowhere to go. 4. After a couple seconds, the printer stops the priming sequence. Epson's ink delivery system appears to be a sealed system, so when the ink has nowhere to go in step 3, little ink has actually escaped the new ink tanks. This means they're not primed correctly, and won't deliver ink as they need to when the printer goes to print. So unless the purge tube gets cleaned out, you can swap tanks and perform head cleanings until the cows come home and it won't do any good. Now that there's a basic understanding of what's going on, here's how to try to fix the problem. This guide is meant to be model-agnostic; I did this procedure to a Stylus CX5400 multifunction, but it should be similar for most Epson inkjets made in the past few years. It's unknown if new Epsons still have this problem, as it usually takes a year or more to surface. The first thing you need to do is prepare your work surface. You'll need a big table, preferably one you don't care too much about. If all you have is your good kitchen table, then it's a good idea to slice open a tall kitchen garbage bag to make one large sheet, and tape it to the table to protect it. Next, you'll need the following tools and supplies: (View attached picture)
Jun 21, 2006 | Epson Stylus 680 InkJet Color Printer
Dell A940 All-In-One InkJet Printer Logo
16 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
