Question about Sony Cyber-Shot DSC-F1 Digital Camera
I need to get a replacement cable thats fits the digital output serial port on the camera to download images to my computer. HARD TO FIND!!
4 Suggested Answers
jackboy
  • 2985 Answers
SOURCE: I can't seem to send images from my camera via cable or infrared
Simply get a cable that fits. The camera cable should be a standard USB A for the Computer- assuming the computer has USB or is it Sony and fitted with Fire-wire in which you will need an adaptor Fire-wire to USB
Posted on Jul 14, 2007
fblock
  • 289 Answers
SOURCE: download images
You may want to try this approach:
http://www.howtogeek.com/howto/windows/find-your-missing-usb-drive-on-windows-xp/
Posted on Apr 27, 2009
  • 14 Answers
SOURCE: Inability to download photos from camera to laptop
The easiest way is through using the CD that came with your camera that contains a view and print program for the Sony Cyber-shot. If you don't have this disk, another method can be used to access your photos as follows: When Windows recognizes the hardware, a pop up widow will ask how you want to use the memory...select open file to view contents (file folder icon). The pictures are not immediately visible. This will open the camera memory in Windows Explorer and you will find a file called DCIM. Open the DCIM file and also the next file that is displayed. This file folder will contain teh .jpg images that you can view or copy and paste into a different folder on your computer.
Posted on Sep 15, 2009
I cannot load images from the camera to the
Go get a card reader and transfer your images thru that. That's the only way I ever transfer my images from camera to computer. You can get one relatively inexpensive...that is...if your computer doesn't already have a card slot in it.
Apr 16, 2009 | Canon PowerShot S5 IS Digital Camera
Download of Pictures to a computer without a serial port
how do i download pictures from my motarola v3 to my pc.(windows vista) using a USB cable.
Jan 11, 2008 | Philips ESP2 Digital Camera
S-video port
Fist of all I like to inform in computer S-Video output of the camera usually does not fit to computer. Only if the computer has S-Video Input card it will be possible. However logic is simple. Digital Camera or Camcorders uses 1394 or USB connection to connect to the computer. You havent indicate what model of JVC you use, almost all JVC Digital Cameras come with USB connection option. All you need to put USB cable in between. If it asks driver, use the CD comes with the Camera or download from JVC's support website.
http://support.jvc.com/
Good Luck
Dec 30, 2007 | Microsoft Windows XP Professional With...
Jul 14, 2007 | Sony Cyber-Shot DSC-F1 Digital Camera
Downloading Images
Downloading images from a digital camera can be very easy if you keep these basic steps in mind. After loading the PhotoMax software on your computer: 1. Make sure that both the camera and computer are turned off. 2. Confirm that the camera has adequate power (using the AC adapter is recommended; otherwise, make sure that there are fresh batteries in the camera). 3. Plug the serial cable that came with your camera into the serial output of the camera. 4. Plug the wide end of the serial cable into the COM port (serial connection) of the computer. 5. Turn the camera on and start the computer. 6. Launch the PhotoMax software (double-click the icon) from the desktop. 7. Click on Get Photo. 8. Click on Album or Camera. 9. Select Twain device from the Acquire From box and click OK. 10. Select your camera from the Select Source box. 11. Click the Acquire icon: (Thumbnails will be displayed). 12. Select images you wish to save from the thumbnails and click on Get Photos. Your images will now be saved to the album you choose.
Sep 21, 2005 | Polaroid PhotoMax Fun Flash 640 Digital...
Fun! Digital 320: "Camera not connected." -- Serial connection
The "Camera not connected" error message indicates a communications problem in the serial port connection between the camera and the computer. Simply put, the computer cannot find the camera it is being asked to connect with. Whenever an external device (digital camera, scanner, Palm Pilot, etc.) is connected to a computer through its serial port, a communications error is possible. There is usually no single "most likely" reason for the conflict -- it could be a hardware issue as easily as it could be a software issue. Fortunately, the most common causes of this error message are also the most easily rectified: 1.Make sure that the camera power is on. 2.Make sure that the camera cable has not been damaged. 3.Make sure that the camera cable is properly connected to both the camera and the computer. 4.Clean out the computer's Temp file.
Sep 14, 2005 | Polaroid PhotoMax Fun 320 Digital Camera
Download images
Yes and no. Although you cannot directly attach the camera to a USB port, you can purchase an Olympus USB SmartMedia Reader that will facilitate the transfer of images via a USB port. For details and system requirements visit our webpage at: http://www.olympusamerica.com/cpg_section/cpg_digital_acc.asp?val1=1&accessory=4
Aug 31, 2005 | Olympus D-490 Zoom Digital Camera
Download images
Aug 31, 2005 | Olympus D-460 Zoom Digital Camera
Download images
Aug 31, 2005 | Olympus D-400 Zoom Digital Camera
General USB Troubleshooting
While USB connections are significantly faster and easier to set up than older serial or SCSI connections they are not foolproof. Here are some tips: Be sure to connect the cable properly One side of the cable is "keyed" so it will only fit properly one way. Do not force it in if it does not smoothly connect. Notice how the USB plug is "keyed" and will only fit properly in one direction. The USB connector on the back of the computer. Connect directly to a USB port on the computer. While USB hubs allow many devices to connect to a computer they are not always reliable for high-speed connections like digital cameras. Connect to a port on the back of the computer. Many computers have extra USB ports on the front or on the keyboard. These are generally built-in hubs which may cause problems as described above. Connect to an AC adapter or use a freshly charged battery To prevent problems during transfer be sure that the camera has enough power to complete image transfers. Remove other devices To troubleshoot problems, remove any other USB devices and connect just the Nikon product for testing.
Aug 29, 2005 | Nikon Coolpix 5700 Digital Camera
Sony Cyber-Shot DSC-F1 Digital Camera Logo
24 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
