Question about Cell Phones
What does the red light on a px-500 mean?
My pantech px-500, which i have had for 3 years , now does not work and dispalys its red light. i use the card in a linksys router.
does this mean my card is dead?
marked
  • 6487 Answers
SOURCE: Hi I'm using Linksys wireless
You can try first to reset the router, by pressing the reset button for 30 seconds using a pen while power is ON then after that just run the setup CD for it to reconfigure the router and if it failed to reconfigure the router, better for you to contact Linksys tech support and have teh router replace since it has 3 year warranty, this is the number 8003267114 they are open 24/7...
Posted on Dec 15, 2008
  • 68 Answers
SOURCE: will a linksys router work with a sprint air card
I don't think so, they are different protocols
Posted on Oct 04, 2009
rcxrbt
  • 84 Answers
SOURCE: My Linksys Router has been working fine for 3
Router can be misconfigured.
Try to reset to default.
Shutdown your computers.
On the back out the router there is a hole which you can insert a paperclip, toothpick etc, hold it for about 5 seconds then pull out the power plug.
After about 5 seconds plug it back in.
When the lights stabilize boot the computer.
Try to access to default ip: http://192.168.1.1 or http://192.168.1.101
username:admin
password:admin
Posted on Oct 20, 2009
lserni
  • 466 Answers
SOURCE: 500 GB Fantom Drive not recognized on either of my
The symptoms don't look too good. Looks like the host controller is querying the hard disk (blink) and not liking the answer - or lack thereof (red).
It looks like the internal disk is defective. Sometimes the disk can be (possibly partially) recovered by disassembling the enclosure and mounting it in another enclosure or directly inside a compatible desktop PC.
Posted on Oct 22, 2009
Ojelola
  • 22 Answers
SOURCE: I have Linksys - WRT54GS Wireless G Broadband
I held a successful career in computers and networking for 23 years. In my experience, I found that Linksys does make good routers. However, the power supplies tend to fail. Try replacing the power supply. That should do the trick. You don't have to shell out substantial cash for an original power supply from Linksys. A universal remote from Radio Shack, or other electronics retailer, will do just fine.
If replacing the power supply does not fix the problem, it is time for a new router. If you are going to buy a new one, I recommend Belkin or D-Link, over Linksys. The power supplies on these brands tend to be more reliable.
Posted on Jan 26, 2010
I have a Piano from Casio Named The PX830 BP.I also have a Sustain Pedal Model from Casio named the SP 33.Will connecting the SP 33 into the PX830 BP work?Please tell me if I have the wrong model.
Unfortunately, the SP33 pedal will not work with the PX-830BP. Casio lists that the SP33 will only work with the PX-150BK, PX-150WE, PX-160BK, PX-160GD, PX-350BK, PX-350WE, PX- 360, and PX-560 keyboards.
The PX-830 manual does not list the stand or the pedal unit as separate items if you need to replace them. The pedal unit has 3 pedals like a traditional piano. I wish that I had better news for you.
Feb 04, 2016 | Casio Music
We have refiled our lay z sap, after it dispaly shows 3 dashes
You probally just need to break an air lock in the pipes. You can ether force water down the skimmer pipe or find your drain valve and open it for a minute or two till it runs just water and no air. This will get water to the pump and the heater. This should fix you up.
Aug 02, 2010 | Pool & Spa
3 red flashing lights all cords are all hooked up properly just wont work
3 red lights on the Xbox 360 is the most common error and it means "General Hardware failure. To fix this you need to stop the amount of heat that the GPU and the CPU is taking.
To do this you can use the recommended guide that has been on the market for 3 years or you can send it in.
Jan 26, 2010 | Microsoft Xbox 360 Console
Power issue NEC PX-42VM5A
Most likely a transistor - NEC used FSM series for a while which are now discontinued. Let me know if you need info on how to find/tell which parts are bad.
Jun 22, 2009 | Emerson LC320EM8 32 in. LCD TV
I have nec plasma px-42vrjg dont know how to wire it with sky box cant get a signal at all
I think you mean sky as in sat service as we have this in Mexico whats going on here is this Tv has two tuners and hte reason for no signal is in some area channel 3 is and has programs on it causing htis interfearance so what you can do is this hook the sky box on the yellow red and whit plugs ( I hope you know what I mean) There call RCA for short and this will shore this up but make sure you put your TV on the channel with the inputs hope this helps you out
Jun 18, 2009 | NEC PlasmaSync PX-42VP2A 42 in. Television
Please help
When the red light flashes, it means that something has gone wrong wit h the set internally. The set will have to be taken to a service centre.
May 31, 2008 | Panasonic TH-42PHD8UK 42 in. Plasma...
Sony Wega 55" Replaced Bulb TV still does not work
Hello, please check how many times the red light flashes. If it is 3 times this means that the lamp cover is not fastened securely. If the red light flashes 5 times this means that the lamp driver is defect. If you need more help please advice
Apr 20, 2007 | Sony Grand WEGA KDF-55WF655 36" Rear...
DVD Timer not working
It usually means that if it doesn't record you don't have a blank DVD in the slot. Hope this helps =)
Nov 06, 2006 | Panasonic DMR-E95HS DVD Recorder
Cell Phones Logo
113 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
