Question about Kenmore Elite 45986 Front Load Washer
Water running out the botton
As soon as the water begins to run into the machine, it immediately runs out the bottom kenmore elite HE 3T 11042922200
    President:
  • 1,304 Answers
Sounds like you have lost your sump
take off the back of the machine
watch the bottom of the tub and turn on the water
you will get a much beeter idea of where its comming from
Posted on Oct 06, 2009
Kenmore Elite HE 3t motor runs but does't spin or drain
SOUNDS LIKE BAD CLUTCH OR MOTOR COUPLER IF ITS BELT DRIVEN MAY HAVE BAD BELT OR LOOSE BELT. i DOUBT ITS IN UR DRAIN PUMP AS UR NOT GETTING A SPIN WHICH IS WHY NO DRAIN.
Oct 17, 2014 | Kenmore Washing Machines
How do i fix the FH error code on a kenmore elite he 3t washer?
This indicates a water problem. Make sure you have both hot and cold water turned on and running to the machine. If pressure is to low on either hot or cold you will also get this reading
Jun 23, 2014 | Kenmore 24032\24036 Top Load Washer
I am getting an F2 error constantly on every wash. Any ideas what this F2 code means or how I can fix it. Thanks
1 check the drain hose to make sure its not kinked.
2 unplug the machine
3 check the electrical plug at the pump and make sure that the pump runs
4 check the drain pump filter for foreign objects
5 plug washer back in
6 if the above does not fix the problem go to #7
7 unplug machine
8 Replace the pump
Part #8181684 http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-elite-Parts/Washer-Parts/Model-11042922200/0583/0153200/P0309046/00006?blt=06&prst=&shdMod=
Dec 22, 2010 | Kenmore Elite 45986 Front Load Washer
Got an F02 code on my Kenmore ELite HE3 washer. How do I unlock the door to get the water out?
Try pushing the start/pau botton several times,this causes the drain to start drining, when it stops and starts flashing again,push the botton again.The water needs to come down a level and sometimes it may start to spin.I've had several problems with this type of washer,But all machines do this.After you get the clothes to spin,remove them and put,draino-max gel or Rooto-rooter drain opener in drum and let it sit 1-3hrs.then run machine heavy-duty hot-water no clothes,you may have to run it several times to get all the cleaner out.the pump may be clogged with animal-hair or strings from clothes.good luck
Jul 10, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE3t 11042922200 Front Loading. F02 drain Problem
We experienced the same thing. I was able to restart and locate the noise to the water pump. After disassembling the water pump found the impeller shaft sliding out. For some reason this shaft will not stay in place. Had to order a complete pump assembly as the electric motor is not available.
Jan 15, 2010 | Kenmore Elite 45986 Front Load Washer
Water trickles into Kenmore front load while machine is off and door is open
sounds like a bad water inlet valve stuck open and permitting watertto enter even though not on, untill you replace the valve turn off water between uses part number 8181694
Oct 31, 2008 | Kenmore Elite 45986 Front Load Washer
F 11 Error Code
The door will stay locked if the machine did not drain properly. Try running a Drain & Spin cycle.
Mar 17, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
71 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
