Question about Whirlpool Estate TAWS750PQ 27-Inch Washer
How do you take apart an agitator on a Whirlpool Estate Washing Machine
  • 5,911 Answers
The agitators on Whirlpool manufactured washers usually have a split design. The upper portion is known as the "auger", the lower portion is the agitator. To get the whole assembly apart just follow these steps:
1. Remove the auger center cap/dispenser by either pulling straight up or gently placing a flat blade screwdriver into a slot located in the cap.
2. If the agitator is equipped with an inner cap with a handle, remove this as well by pulling straight up.
3. Remove the center bolt of the agitator. You will have either a 7/16” hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8” to ½” ratchet adapter to remove.
4. Remove the auger by carefully pulling straight up. Try to keep all the cam assembly parts assembled while doing this, so do not pull too hard. This will make this reassembly much easier.
5. With the auger removed grab the agitator at the bottom flanges and pull straight up to remove from the gearcase shaft.
If you need an illustration of how the components go back together, refer to any of these websites for helpful exploded view diagrams:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
NOTE: When reassembling, make sure you get the auger seal seated properly. If it is not sealed, water will leak into the gearcase shaft and ruin it.
If you have any questions, or need further assistance, please let me know. I hope this helps you.
Posted on Oct 06, 2009
  • washlessnNC Feb 13, 2011
    Help!!!
    I can't separate the auger from the agitator on my Whirlpool Washer. I managed to remover the auger/ agitator from the crankshaft -but not from each other. Any suggestions (BTW - I pulled extremely hard while standing on the base).
    Thanks,
    Washless in NC
4 Suggested Answers
  • 1218 Answers
SOURCE: I have a Whirlpool Top Loader Estate Series
Good day,
Most models used a split agitator. If your describing the top part, then an Item called "dogs" has failed. Yes that's Whirlpool's name not mine.
Here's a link to get you up and running. Inexpensive repair.
http://www.youtube.com/watch?v=V5wIN1J70-Y&feature=player_embedded#
Posted on May 15, 2010
jsrock516
  • 5911 Answers
SOURCE: My Whirlpool Estate TAWB600EQ1 will not spin or agitate
If the washer does not agitate at all, does not spin, but will still drain, this is a symptom of a broken motor coupling.
The following link explains how to replace one:
http://www.fixya.com/support/r385250-replacing_motor_coupling_kenmore_top
This is a very simple repair that doesn't cost much. The repair is actually much easier than you think and requires no special tools. The part number is included in the link I provided. Appliancepartspros.com carries a replacement motor coupling for about $11.
NOTE: A broken motor coupling is usually accompanied by a loud rattling noise. You can hear the motor engaging and running, but there is no tub action.
If you need an illustration, you can refer to the website I mentioned and locate item 13 under the Brake/Clutch/Gearcase/Motor/Pump section.
The motor coupling is located between the drive motor and the gearcase (transmission). It takes the place of a drive belt and commonly fails on Whirlpool manufactured top loaders due to normal wear and tear. This configuration is known as a "direct-drive" system. The replacement motor couplings are more resilient and resist breaking better, because the manufacturer added a steel grommet.
If you have any questions about this repair, or if you need additional assistance, please let me know. I hope you find this information helpful.
Posted on Oct 11, 2009
  • 132 Answers
SOURCE: agitator for whirlpool washing machine
The plastic dogs are stripped inside the center of the agitator. To remove agitator pop off the top center cover(slot for screwdriver) There is a 7/16 inch bolt with standard thread, remove it and pull out agitator. Pull the agitator apart, you can stand on the bottom half and pull on the top, you have to reassemble it with the new dogs replaced(there are four in a package) Fairly simple, no special tools needed,
good luck.
Posted on May 27, 2010
I am trying to replace the agitator dogs on a Whirlpool Estate washing machine. I haveremoved the agitator assembly and am trying to take it apart. How do you get the agitator assembly apart when it...
NOT SURE HOW URS WORKS BUT SOME DO NOT REMOVE FROM THE TOP OR MIDDLE BUT INSTEAD HAVE A COUPLER ASSEMBLY AT THE BOTTOM THAT REPLACES THE CAM DOGS FUNCTION SEE PICS
May 08, 2014 | Estate TAWS850PQ
Agitator for whirlpool washing machine
good luck.
May 27, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
I have a Whirlpool Top Loader Estate Series Washing Machine and the agitator will not spin properly?
Good day,
May 15, 2010 | Whirlpool GSC9455 Top Load Washer
Estate by whirlpool/agitator will not turn
under the top half of the agitator there are 4 agitator dogs. these pieces have edges to them that catch the inside of the upper agitator and if they are worn down, and they do wear, it will not move the agitator for you. hope this helps.
Oct 14, 2009 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Not agitating
not really, the coupler should do the trick its the most commmon issue witht hose washers
Mar 25, 2009 | Whirlpool Washing Machines
Where is the fabric dispenser in my whirlpool estate washing machine?
Whirlpool will put their fabric softener dispensers in one of 2 places. Either in the top of the agitator there will be a cup or in one of the front right hand corners (far less often). If you do not have either of these options, likely, it a model that did not come with one (not uncommon at all)
Jan 12, 2009 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Not agitating
Check your drive coupler. Its the rubber piece between the motor and the transmission which makes the washer agitate and spin. the easiest way to check it is to lean the machine back and look for rubber on the floor. Then look behind the motor to see if it is still in tact. Next try wiggling it, If it wiggles a lot replace it. If that doesnt fix your problem, you probably have a bad transmission.
Nov 18, 2008 | Estate ETW4100SQ Top Load Washer
Washing Machines Logo
701 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
