Question about Generac 13,000 Watt / 13,000 Watt Home Standby Generator
I have a Generac 5000 Watt Power Plus Mod-00413-0 Series-pwr+5 Serial-1985932. Looking for the nut that is on the bottom of the carburetor sort of a twist on nut by hand not a wrench. Thanks
  • riverron May 11, 2010
    Need the nut for the float bowl on this model Need to order the part. The generator runs fine. Was just cleaning the carb and lost the part. Thanks
3 Suggested Answers
kel1guy2002
  • 3740 Answers
SOURCE: I have a Generac 5000 Power Plus 10HP Model
The original part number your looking for is 78298 (Plastic tank valve). It has been superseded by part number 080270 and it it available here:
http://www.ordertree.com/ARI.aspx?Mfg=36&Model=9856-0%20POWERPLUS,%205,000%20Watt
http://www.ordertree.com/AddtoCart.aspx?&ProductID=78298&ProductQlfr=GEN $5.34
Part Mfg: GENERAC Part Number: GEN 78298 This Part has been superseded arrowdown.gif Part Number: GEN 080270 Price: $5.34
When you do parts searches in the future for your generator use 9856-0 (Powerplus 5000Watt) for the model number.
You can also order the 080270 tank valve here:
http://www.jackssmallengines.com/searchdb2.cfm
If you enter the part number on the search page.
$4.60
Thanks for using FixYa.
Kelly
Posted on Jun 10, 2010
jeffshira
SOURCE: how do i flash my generac 5000 power plus generator
I had the same problem. The engine was running fine but there was only about 1.2 volts coming out of the generator on each leg. I decided to try flashing the field first since it doesn't cost any money. I used a 12 volt dc car battery, and a extension cord. You do not use the green ground wire. you hookup the male end of the cord to the female receptical of the generator outlet. With the generator running you then hookup first the white wire to the battery, now with the black wire you connect it to the battery for about 5 seconds. when I did this my circuit breaker popped and so I reset the breaker and checked the voltage and it actually worked I now get 120 volts ac. It actually worked but be carefull and hope this helps.
Posted on Jan 13, 2012
Why centurion 5000w generator has no spark
change the cdi on the motor sounds like it is fried
Jun 08, 2014 | Generac 5622R GP5000 GP Series 5000 Watt...
My Generac GP5000 generator runs great for about 4 minutes until it heats up then it starts cutting out and backfiring until it ultimately dies and wont restart until it cools down. the generator has...
If it is new and under warranty, talk to Generac about getting it fixed.
If it is old and unused, it probably needs fuel system cleaned out. Carb needs to be removed and cleaned inside and out, fuel lines need flushing, filter changed and if it has an automatic choke, it needs to be checked because it sounds like it is stuck on.
Oct 03, 2012 | Generac 5622R GP5000 GP Series 5000 Watt...
Can i use my welder with my generac 5000 generator? my welder is 220VAC.
probably but it may be a streck 1300 watts may do it but it depends on the draw of the welder and it will be maxed out thats 13 100 watt light bulbs running at the same time use common sence
Nov 29, 2010 | Generac 13,000 Watt / 13,000 Watt Home...
I have a Generac 5000 Power Plus 10HP Model 09856-0 Series 401 4891. It works fine but the gas tank petcock leaks. Where can I get a replacement and for reference I'd like to get a parts manual for future...
$4.60
Kelly
Jun 10, 2010 | Generac 13,000 Watt / 13,000 Watt Home...
How do i flash my generac 5000 power plus generator
well I have a special flasher unit but I believe you can put 12 volts to the brushes while it's running. That should do it.
Apr 09, 2009 | Generac 13,000 Watt / 13,000 Watt Home...
Generac 13,000 Watt  / 13,000 Watt  Home Standby Generator Logo
379 people viewed this question
Top Generac Electrical Supplies Experts
Craig Butler
Craig Butler
Ottoniel
dennys23601
Are you a Generac Electrical Supply Expert? Answer questions, earn points and help others
