Question about Cameras
Sometimes when I turn on my camera dsct20 it is shaking I turn it off and back on and it still shaking and it is real hot
Its japanese version! do you have manual on this camera in english?
Assuming you're asking about the same Sony DSC-T20 as in your other question, you can download the manual and more from the manufacturer's web site at
http://esupport.sony.com/US/perl/model-documents.pl?mdl=DSCT20
Jun 23, 2011 | Cameras
I've got a '71 ford custom w/305.The battery overcharges to the point where it boils the water out.The alt. & voltage reg. have gone out twice since this started.The back of the ammeter looks like it...
while it is acting like a faulty voltage regulator, have you been able to monitor the voltage when overcharging? Are the grounds all in good condition? I seem to recall this many years ago. I'll shake the cobwebs loose if you contact me back and see what help I may be.
Feb 17, 2011 | Ford F Cars & Trucks
Is not making ice and is very warm from middle to top on both sides of my side by side kenmore 106.56932600
Greetings,
is there any ice frozen on back wall of freezer panel..if not, check to see if all the fans are operating..does the divider between the refrig and freezer doors seem real hot? if so, look for a stopped condenser fan motor....now, does the compressor run? sometimes you hear the condensor fan running and think the compressor is running...these things will click every fives minutes if not running..So, listen carefully, touch the compressor..is it hot? is it hot and clicking? if clicking, UNPLUG and remove the relay off compressor..shake it and if bad..it will rattle. Replace the relay if bad. The compressor could be bad and be clicking as well..anyway, let me know if it isn't it
Bruce Denton
Jan 24, 2011 | Refrigerators
The camera is shaking whilst taking picture
This Camera has a known issue with it.
I'll forward a link to a page where you can view the detailed information about this known issue with the Camera.
Please click on the link below to view the information.
http://esupport.sony.com/US/perl/news-item.pl?&news_id=269&mdl=DSCT20
Please go through all the insructions mentioned on the page.
Thank You!
Mar 30, 2010 | Sony Cyber-shot DSC-T20 Digital Camera
The lens refuse to close on my Olympus stylus 850 sw.  It seems jammed. The camera make a warning sound when i turn it off. Can't use it.
same thing happens to mine. olympus wants to charge me more than the camera cost to fix it. It started doing it one month after the warranty expired. The problem does go away for weeks at a time sometimes but always comes back so camera is not dependable. If you shake/hit the camera repeatedly it sometimes fixes itself. Olympus sucks.
Feb 11, 2010 | Olympus Stylus 850SW Digital Camera
Audiosource amp two intermittent distortion in monoblock mode
Good question, well constructed, a real fault report.
I would say from you fault description that maybe there is a dry joint / loose connection somewhere in the system.
So check all your wiring / connections.
Put the amp back into 2 ch mode and check each ch with the same source and load, do it both cold, and then drive the amp and do it hot do the shake test on both ch, cold and hot.
maybe this will help id the faulty area, if both ch have fault the it might be the psu as this is common to both sides.
If you can track down the fault to a or b then you can resolder all the connections on the board, if you are not happy with taking the lid off then take your amp with your test report to a tech, the test results may save you time and money.
Hope this helps, thanks for using FixYa.
Sep 24, 2009 | AudioSource Amp Two 2-Channel Amplifier
My 87 civic sedan shakes real bad, the brake pedal wont go down, the front end shakes real bad, and the car sometimes idles low to were i cant go over 25 mph. what is wrong
SOUNDS LIKE WORP ROTORS I REPLACE ROTOR AND BRAKE PADS SEE IF THAT HELP AND CHECK WORN PARS IN FRONT END LIKE TIE RODS
Aug 20, 2009 | 1987 Honda Civic
Camera turns on with a bit of a tremble but shutter locks
I have an 5D with the same problem, It looks like the Anti shake does not initialize properly, The only bypass I found that worked (except for a real repair) is to set the display light timeout for 5 seconds, The standby timout for 1 minute, Turn the camera off, and on again, Wait for 5 sec then the display goes blank, wait for 1 minute then the camera goes in standby, (light from CF card flashed red 1 time) Then touch any button to re-activate the camera and... voila... everything works, including taking normal pictures and the anti-shake !!! So it only takes a minute everytime to startup..
Jun 05, 2009 | Konica Minolta Maxxum 7D / Dynax 7D...
Cameras Logo
23 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
