Question about Thexton Door Buzzer Sanity Tool # 442
Im trying to set up a wire diagram for a series buzzer system with two buzzers and two push buttons, using 2/18 and a transformer?
    President:
  • 1,723 Answers
Here ya go:im trying to set up a wire diagram for a series - 1a50776.png
Posted on Oct 06, 2009
2 lights. 2 switches and a buzzer. how to connect them to make the buzzer sound when a light is turned on
Copy following links:
http://waterheatertimer.org/images/3-way-circuit-with-buzzer-300.jpg
http://waterheatertimer.org/How-to-wire-switches.html#3-way
Above illustration assumes that buzzer is rated for 120Volts.
If doorbell buzzer is rated for 12-24 Vac, then copy following links:
http://waterheatertimer.org/images/3-way-circuit-with-buzzer2-300.jpg
You need contactor with 120Volt coil. The light switches turn on light. At that moment, power goes to 12-24V doorbell transformer from hardware store. At same moment, power goes to magnetic coil on contactor. The contactor is a switch, and it connects wires between transformer and the doorbell buzzer. Buzzer turns ON.
When light turns off, buzzer turns off.
http://waterheatertimer.org/H230A.html
Apr 17, 2013 | Electrical Supplies
Can I make a water activated switch for a water detector alarm
Yes this is possible to do. If you have a radio shack near you the parts are not much to get. First you will need to get a water sensor. Next a pizo buzzer and a power transformer that matches the power input of the buzzer. You take one side of the wire from the transformer and cut it in half. Connect one of the cut wires to the common screw terminal on the water sensor. The other cut wire and connect to the normally open screw trminal. PLUG THE TRANSFORMER into the ac outlet. Push the sensor switch to see if the pizo sounds. then put back in orignal spot.
Apr 09, 2013 | Washing Machines
Frigidaire GLEH1642FS washer/dryer stacked unit: How do I disconnect the buzzer?
The buzzers (there are two, one for the washer, one for the dryer) are behind the control panel. 6 screws must be removed to access the back of the control panel: 2 for the service panel, the 2 outer screws at the base of the control panel, then the 2 much smaller-sized screws.
The buzzers, in my model, are small, un-buzzer-like-looking little black boxes stamped with the brand name 'Ark-less'.
The buzzer for the dryer is connected to 2 contacts on the back of the dryer timer, the contacts labeled 'H' and 'C'.
Once you've identified the buzzer for the dryer, you should be able to find the one for the washer. It's connected by one white and one grey wire.
You should be able to verify this info using the wiring diagram, which will be located behind the service panel. If I remember correctly, the buzzers were labeled 'signal' on the diagram.
Nov 07, 2010 | Frigidaire GLEH1642DS Front Load Stacked...
ADDING A BUZZER TO A CHAMBERLAIN BASE STATION
I have never worked with that unit beofre, but I can take a shot. Visit your local car audio dealer, and pick up a LVT (low volatage trip)..Open up the base station, and disconnect the signal wires to the buzzer/speaker. Use those wires to feed the low voltage turn on in the LVT. THe LVT acts just like a relay, but requires much less voltage to trigger. So in theory if you use the LVT it shopuld power up your external speaker properly when the station is triggered, and is a fairly simple install.
Aug 07, 2009 | Chamberlain Wireless Perimeter Alarm
Buzzer always on, drum won't start spinning
yes you lneed a motor 150.00 to 200.00
May 28, 2009 | Dryers
Turn the alarm off
Just push the button marked radio, sound or buzzer on the front right side of the face or panel - when you see radio, sound or buzzer light up on the screen alarm is on (to whichever you set it - radio sound or buzzer- if you push the button again it will go off. Took me a while to figure that one out too!
Oct 11, 2008 | Timex T309TT Clock Radio
Turn off buzzer
Assuming you mean the end of cycle alert. The only way to do this is to follow the wiring diagram and install a switch to cut it off.
Dec 20, 2007 | Kenmore 73952 Gas Dryer
Kenmore 70 series model # 96573220
Sounds like the push to start switch has gone bad. Not to expensive to fix, and pretty easy to do as well. You can remove the rear of the console, remove the push to start switch (lift the tab, then turn to unlock) and replace. Be sure to mark your wires so they go back in the right order. Jim
Nov 18, 2007 | Kenmore 60172 Electric Commercial Dryer
Thexton  Door Buzzer Sanity Tool # 442 Logo
41 people viewed this question
Top Thexton Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you a Thexton Electrical Supply Expert? Answer questions, earn points and help others
