Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
I have a whirlpool LSN20000JQ2 washer, how do I get the top and front off
  • 5,911 Answers
To remove the exterior washer case and console, follow these steps:
1. Unplug washing machine.
2. Remove console. This can be accomplished in one of two ways depending on which type of console you have.
a. If the console has removable end caps, the caps lift off by prying on the top from the back of the washer. The cap will pull off towards you as you are facing the unit from the front of the washer. There will be a screw under each end cap that you will need to remove.
b. If the console does not have removable end caps, you will need to slide a putty knife under the front corner of each side and push in while lifting up. There is a retaining clip under each side that has to be released.
3. Once the console has been released it will lift up and fold back over the back of the washer in its resting position. Use care not to stress the small plastic hinges that hold it on. They can break easily.
4. Under the console will be two large brass colored clips. Take a large flat blade screwdriver and place it in the groove of the clip on the washer top. With the screwdriver firmly in the groove, push away from you towards the back of the washer. This will release the clips.
5. Disconnect the lid switch connector plug. This is the white colored plug on the washer top under the console.
6. Remove the washer casing. Open the lid of the washer. Using one hand, grip under the front rim of the washer opening. Do not grab the wash tub, just the casing. Tilt the washer case from the back first towards you, slide forward slightly, and then lift up. The entire case comes off exposing the wash tub and components.
If you need an illustration of your washer and components, searspartsdirect.com, appliancepartspros.com, or pcappliancerepair.com usually has some excellent exploded view diagrams that you can refer to.
To reinstall the washer casing, follow these steps to ensure you get the case correctly placed and secure on the frame:
1. With the lid of the washer open, grasp case under front rim and place it on the washer frame. While looking down through the washer lid opening, make sure the front lip of the case is placed UNDER the washer frame and rocked back onto the frame to ensure that the small cleats on the frame fit into the slotted grooves on the washer case base. If you do not get the case seated correctly it will rattle and vibrate while the washer is in operation.
2. Make sure the back of the washer fits into the washer casing on each side by leaning over the front of the washer and grasping the back panel and pull towards you. Reinsert the brass clips by placing the clips into the slot on the back of the washer first, and then forcefully push then down into the opening on top of the washer.
3. REINSTALL LID SWITCH CONNECTOR. It is easy to forget. If you do not reconnect it, the washer will not work correctly.
4. Reinstall console.
Read through everything thoroughly before beginning any repairs. If you have any questions, or require additional assistance, please let me know. I hope this information is helpful.
Posted on Oct 06, 2009
My LTE5243D top load stacked washer is about 10 years old. How do you take the front panel off to access the washer's motor coupling?
To gain access to the washer components, the front panel between washer and dryer must be removed first.
Remove the two top screws securing thethis panel to the unit.Tilt the transition panel down and pull itstraight out.Remove the two screws located behind the washer top.Pull the washer top forward to disengage the top locks. Disconnect the washer lid switch harness. Lift the washer top off the unit.Remove the two screws from inside the top of the washer front panel.Lift up on the front panel to release the catches near the bottom of the panel andremove the front panel.
Apr 24, 2012 | Whirlpool LTE5243D Top Load Stacked...
Tip
How to Level a Whirlpool Top Loading Washer.
If you are experiencing consistent off-balance load issues with your Whirlpool top loading washer, it may be caused by a simple problem of needing to reset the auto-level mechanism and making sure the front feet are properly level. This advice may save you a service call and restore an unbalanced washer to running condition.
The rear feet on Whirlpool manufactured top loaders have an auto-leveling mechanism that you can easily reset yourself. Just follow these steps:
1. With the wash tub empty, open the washer lid and grasp the rim of the tub opening (do not grab the tub).
2. Now place one of your feet at the base of the washer along the front of the washer to keep it from moving.
3. Now pull the washer towards you so the rear feet lift off the floor a couple of inches. You should hear a clicking sound as the rear feet auto-level.
4. Carefully set the washer back down (do not slam it) and the rear of the washer should now be level.
Using a level, check the washer front to back and side to side to make sure it is level in all directions.
If you need to adjust the washer washer front feet, carefully lift the front of the washer and turn the feet to either adjust them up or down. The slightest difference can cause excessive vibration on the final spin. Check by placing your hands at opposite corners on top of the washer (diagonally - one on the rear, one on the front) and try rocking the washer to see if it moves. If the washer wobbles, you need to readjust.
This advice is for all Whirlpool manufactured top loaders with a direct-drive system such as Kenmore, Estate, Kelvinator, Roper, and Frigidaire. If in doubt, please post your MODEL NUMBER when submitting questions, so that I can determine if your washer is configured with this feature.
This does NOT include the Oasis, Cabrio or Calypso models.
I hope everyone finds this information helpful.
on Jan 12, 2010 | Washing Machines
I have a whirlpool stackable washer and dryer.Model Lte6234Dt3 Serial Ms2102958. I need to replace the water pump. Do I need to remove the washer skin to do this?
To replace the pump you need to remove the front panel of the washer to do that. To do that remove the diagoal panel between the control panel and and washer top. Usea flat blade screwdriver and pop up the brass clips in the rear of washer top,slide top out and off,the their will be screws on the side panels that hold the front panel on the left side must remove the hose asm. to fill spout to get to screw for front panel thats under fill tube asm.
Good luck, i hope this helps and if it does please give me 4 thumbs up
Gene
Jul 29, 2011 | Whirlpool LTE6234D Top Load Stacked...
I have been given a Whirlpool AWM 312 by friends moving overseas and don't know how to operate it and would like to get a manual. My main problem is what drawer (front the left facing the machine) do I...
The manuals for most Whirlpool appliances are available here: http://www.whirlpool.com/custserv/index.jsp . Look for the full model number under the lid on the rim of the washer. AWM 312 is not a complete model number. Next is the washer a top loading or front loading machine? This is actually indicated in the model number - most Whirlpool models start WFW (front-load) or WTW (top-load). The exception is the compact washers (LCE4332PQ is the current model).
For the front-loading washers, the detergent goes into the largest compartment (usually the left-most part of the drawer). Top-loading washers that have a detergent compartment usually have it positioned at the top center back of the tub. Use HE detergent for high efficiency washers and do not use more detergent than recommended (using less is okay).
I hope this helps.
Mar 03, 2011 | Washing Machines
Replacing water inlet valve for Whirlpool Duet
Thats a two man job that you are trying to do yourself. The top of the washer has to be removed to replace the valve. Get some help to remove the dryer from the top.
Mar 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool front load washer wont drain or spin
Sounds like the pump quit working and needs replaced
Jun 15, 2009 | Whirlpool CAM2752KQ Top Load Washer
Washer vibrates during spin cycle
Front loaders have to be situated on solid flooring such as a basement or they will vibrate.
http://tclaundryrepair.com/
Feb 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Need to get into the water mixing valves on Whirlpool washer
with putty knife press in clips at each corner of console and lift up ..also press same type clips at front edge of top about 2-3 ins in from each corner
Nov 29, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Repair washer
hi thanks for the question the front panel comes off 2 screws at the bottom remove 3 screws at back of top remove top pull towards you 2 screws at the bottom of front this should take the front off thanks please accept and a positive feedback please thanks the appliance doc
Sep 23, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
70 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
