Question about Sony Memory Stick PRO Duo (2GB) for PSP
Kid removed the memory stick duo card while psp was updating. Now there's nothing on screen. What to do?
    Sergeant:
  • 236 Answers
I think you have to reset the psp on original factory settings.
Posted on Oct 09, 2009
My psp memory card dont let me put stuff in
you may have to format the card. Also make sure your card is not placed in the lock position.
    How to Fix a PSP Memory Stick
  1. Step 1 Upgrade your PSP's Firmware (its operating system) before doing anything else. Firmware 5.0 solves many software problems that are encountered with older memory sticks. You can upgrade it by simply connecting your PSP to any wireless connection through its WiFi. Once a connection is established, the PSP will update itself automatically.
  2. Step 2 Check to see that your memory stick's plastic tongs, the small sticks that separate each connection, are straight. If one is bent, your PSP will not recognize the stick.
  3. Step 3 Remove your memory stick if it still does not work. Insert it into a PC with a memory stick slot. You will most likely be able to see all of your saved files. If so, continue to the next step. If you still cannot see your files, then your memory stick is defective, and it is not the PSP's fault.
  4. Step 4 Copy your files from the memory stick to the hard drive.
  5. Step 5 Format your memory stick using the "Format Disk" option in Windows. Open Windows Explorer, and find your memory stick listed in the "Drives" section. Right-click on the memory stick, and click "Format." Follow the on-screen instructions in the windows that pop up.
  6. Step 6 Insert your memory stick into your PSP. It should recognize the disk now. However, you now need to format the memory disk again with the PSP.
  7. Step 7 Go the PSP main menu, and select "Settings." Then select "Format Memory Disk."
  8. Step 8 Put your memory stick back in your PC, and return the files you removed earlier. When you reinsert the stick into your PSP, it should now see all the files.
Mar 25, 2010 | Sony Memory Stick PRO Duo (2GB) for PSP
Cant find the memory stick duo in
lol well dude make sure it has nothing on it... go to format memory card in system settings option in the psp
Jun 28, 2009 | Sony PlayStation Portable (PSP) Console
Memory stick unreadable by psp
try formatting the memory card via a card reader..
thats all i can think of
good luck!
May 30, 2009 | Sony 1GB Memory Stick PRO Duo Memory Card
Memory Stick won't load on PC
tyr looking for a firmware or an update on the net for your memory card reader.  It should be easy to find.  And update. Since the flash memory card isn't the problem it's either your card reader is too old and can't support that size of card or the reader need an update.
May 12, 2009 | Sony 4GB Memory Stick PRO Duo Memory Card
How to i update my psp & my psp not suported the video....give an
you can go to the nearest gaming store to update a new firmware. pls remember not to download any firmware update from the internet, this will corrupt your console. Mostly, internet firmware update are not safe.
Dec 25, 2008 | Sony PlayStation Portable (PSP) Slim...
Psp illiterate
Yes there is a way. What you will need is a PC, Some form of Memory stick Duo card Reader, And a PSP Compatible Memory stick Duo/Pro Duo.
If you havent already used the memory stick inside the PSP it will not have the correct Formatted file System for use in the PSP. but you can create the file system using your computer.
heres how to do it ! :
1) plug your Memory stick Duo/Pro Duo into the card reader on your computer.
2) open my computer, locate the Memory stick usually found under the "devices with removable storage" area.
3) once inside the memory stick, create 2 seperate folders. One called "PSP" and the other one called "MP_ROOT".
4) Navigate into the "PSP" Folder and create 3 Folders, "MUSIC", "PICTURE" & "VIDEO"
5) Copy & Paste the Necessary files into each Subsequent Sub-Folder within the "PSP" Folder.
Note : The PSP Can only handle Certain File types for Pictures, Music, And Video. i would suggest Navigating to http://psp.about.com/od/hardwarefirmware/p/compformat.htm before you transfer your files to ensure that you are adding files which are Viewable/Readable by The PSP's software.
Hope this helps !?
Oct 27, 2008 | Sony PlayStation Portable (PSP) Console
Memory stick problem!
go to system settings and click format memory stick but dont try it strait away because when you for mat your memory stick it deletes all the things you've saved
Sep 15, 2007 | Sony PlayStation Portable (PSP) Console
Can you use the PSP Memory Stick Pro Duo cards on your DC?
Yes! The Memory Stick Pro Duo's are one in the same. (Just out of curiosity, where are you finding them cheaper?) One note, however; as strange as this is, though the PSP plays mp4s, they will not play mp4s from a memory stick pro duo that comes directly out of your M1 camera... I've tried it, I have both a PSP and an M1. (The PSP will show off your M1 still photos, though.) Hope this helps! Susan
Sep 08, 2005 | Sony Cyber-Shot DSC-M1 Digital Camera
Sony Memory Stick PRO Duo (2GB) for PSP Logo
118 people viewed this question
Top Sony Electronics - Others Experts
Sandy Moore
Sandy Moore
 Grubhead
Grubhead
Computer Links
Are you a Sony Electronics - Other Expert? Answer questions, earn points and help others
