Question about HP 12c Calculator
How do I convert .1111111111 to a fraction?
How do I convert .1111111111 (or any other decimal) to a fraction?
  • HP Master
  • 7,993 Answers
In addition to 1/2 =0.5, 1/3=0.33333333 , 1/4=0.25, 1/5=0.20 , 1/6=0.66666666666, 1/8= 0.125, 1/10 =0.1, there are two decimal numbers that are worth remembering because they are so easy to remember. These are
1/9 =0.111111111111111111111 ...
1/11 =0.099999999999999999999 .....
Your fraction is therefore equal to 1/9
I skimmed the whole manual but could not find a way to convert a decimal number to a fraction on the calculator. There are however two functions, one to extract the integer part [g][INTG], and the other [g][FRAC] to extract the fractiona part of a number.
Sorry. Hope it helps.
Posted on Oct 06, 2009
Testimonial: "Thank you!"
  • k24674 Oct 15, 2009
    Sorry but 1/6 =-0.16666666666666666666666 not 0.6666666666666
    OPPS again. There is no minus sign.
How do I convert decimals to fractions on the TI Math Explorer (No numbers associated with it - i.e. TI - 15)?
The way it works is as follow. If a result is displayed as a fraction you can convert it to its decimal representation. If you do nothing after the conversion, you can revert the decimal representation to the fraction.
Apr 29, 2014 | Texas Instruments Office Equipment &...
F-D key in Polynomial
The F-D key converts a displayed result from fraction to decimal and vice-versa.
If in the polynomial expression a numerical coefficient is a fraction just enter it as a fraction, possibly enclosed in parentheses. If it is a decimal number just enter it as a decimal number. Converting it to a fraction is not going to generate any more precision in the result. You lose precision when you go from fraction to decimal, but you do not make a number more precise by converting it from a decimal representation to a fraction.
Nov 16, 2013 | Casio FX9750GII Graphic Calculator
How do I convert from decimals to fraction with my TI-30X IIS calculator? I need the step by step process
The following examples will demonstrate how to convert decimals into fractions using the TI-30Xa and TI-30Xa Solar. Please be aware that TI-30Xa Solar School Edition calculators do not have this functionality.
Example: Convert .25 to 1/4
- Input .25, press [2nd][<--] (says F<>D above it).
** F<>D means fraction to decimal, decimal to fraction.
Example: Convert 1.38 to 1_19/50
- Input 1.38, press [2nd][<--].
Example: Convert 9.75 to 9_3/4
- Input 9.75, press [2nd]{<--].
Mar 08, 2011 | Texas Instruments TI-30XA Calculator
Can you convert a decimal to a fration on the fx-300MS scientific calculator? If so how?
To convert a fraction to a decimal or a decimal to fraction you use the [a b/c] key.
While converting a fraction to a decimal number is always possible, converting a decimal to a fraction may, at times, not be possible.
Sep 10, 2010 | Casio FX-300MS Calculator
How to convert fractions to decimals
To convert fractions to decimals, and decimals to fractions use the [a b/c] key. If the total number of symbols (num, denom, fraction bar) to display a fraction exceeds 10, the fraction is automatically converted to decimal format.
Jul 19, 2010 | Casio FX-300MS Calculator
I can't get the answer to display in decimals only fractions.
For converting answers in decimal to fraction or fraction to decimal there is a S<->D key above delete key.If the answers is in fractional form press this key and it will be converted to decimal form.
Jun 04, 2010 | Casio FX-115ES Scientific Calculator
Conversion of decimals to fractions 0.1666666666666666666666666 = 1/6
You can always convert a fraction to a decimal. The reverse may not always be possible. Look at the example on the screen capture.
You may be lucky and recover a fraction you have just converted into decimal format, but you cannot just write 0.333333333333 and expect the calculator to convert it to 1/3: The true fraction 1/3 has an infinite number of 3's after the decimal mark.
May 26, 2010 | Casio FX-260 Calculator
How do you change decimals to fractions on a casio
If you enter an improper fraction or a mixed fraction with the the [a b/c] key it will be displayed as a fraction. This result being displayed you can press the [F-D] key to convert the fraction to decimal. If you do nothing else and you press the [F-D] key again, the original fraction will be restored.
However, it seems that you cannot enter an arbitrary decimal number and convert it to a fraction. The [F-D] key seems to work one way : from a fraction to a decimal number. You will only recover a fraction if the original number was a fraction.
Jan 19, 2010 | Casio FX-9750GPlus Calculator
I need to convert decimals to fractions
Press [MATH][1:ToFrac] to convert an aswer to fraction.
If you enter 18.52[ToFrac] [ENTER gives 463/25
[MATH][2:ToDEC] converts a fraction to a decimal number.
Hope it helps.
Sep 22, 2009 | Texas Instruments TI-84 Plus Silver...
HOW TO INTER FRACTION ON A TI-83
Once you enter a fraction the calculator calculates it and displays a decimal result.So basically you cannot do fraction manipulations. However you can convert a decimal result into a fraction. To do the conversion, you enter the decimal number then you Press [MATH] and [1]. ( -->Frac) The number will be converted.
Similarly you can enter a fraction to a decimal number (-->Dec)
[MATH] [2:] [ENTER]. But I see no point in doing that, because any fraction entered is displayed as a decimal number.
Hope it helps
Sep 03, 2009 | Texas Instruments Office Equipment &...
HP 12c Calculator Logo
5,298 people viewed this question
Ben Johnson
