How and how often should the cvt trans fluid on a 08 escape hybrid be done?
Only 2 ways that I know of....
Easiest: Suction the fluid via the dip stick tube using a drill pump (about 4 bucks at Harbor Freight or on line).
Less Easy: Remove all but one of the transmission pan bolts. With a large container under the pan, loosen the last bolt until you can pry the pan loose.... let the fluid run into the container. When it is empty, retighten that last bolt and then reinsert the removed bolts. The pan gasket should not leak when new fluid is poured into the dip stick tube (check it after about a quart is added... and snug the bolts either side of any leak).
Testimonial: "thank's much"
