Question about Home
The toilet handle keeps falling off. It is hard to get back on where it will flush.
  • 129 Answers
It must be broken, a new one will fit in correctly and stay in. Very cheap.
Posted on Oct 06, 2009
Toilet won't flush.
How modern is the toilet?
Sometimes the flush handle chain or strap falls off. This can easily be reattached or replaced.
On older toilets the flapper valve can easily be replaced.
Your local hardware or home centre store should be able to provide parts.
Apr 26, 2016 | Home
Tip
What to do if your toilet stops working
When a toilet stops working it can be a major inconvenience. If your toilet isn't working right, try the simple fixes below.
If the toilet doesn't flush:
When you jiggle the handle, nothing happens. Remove the lid from the toilet tank and peek inside. Most likely, either the chain came off at the lift rod or flapper end, or the rod broke in half. If the chain came off the rod, you can simply reattach it. (Finding the right amount of slack will take some trial and error.) Likewise, if it came off of the flapper, it can easily be reattached.
If the lift rod (the arm attached to the handle) is broken, you can purchase a new rod and handle assembly for a few bucks at just about any hardware store. A plastic nut holds the handle into the side of the tank and the whole assembly can be popped out and replaced. Once you've installed the new assembly, reattach the chain.
If the toilet keeps running:
Remove the tank lid and watch the toilet as it flushes. You'll probably see that the chain is too tight, causing the flapper to not close all the way, which results in water continuing to drain out and having to be replenished. Loosen the chain a little and see if it fixes the problem.
Another cause of a constantly-running toilet is an improper float height. The float is the balloon-looking thing that sits on the end of a shaft and falls and then rises when the toilet is flushed. When the float reaches a certain height, the fill valve is closed and the water stops flowing. If your toilet is running longer than it should, push down a tiny bit on the float and see if it stops running. If it does, the float just needs to be adjusted downward a little (by turning the screw at the other end of its shaft). You may need to try a few different heights to determine the optimal position of the float; adjust it slightly and flush the toilet, then adjust it again if necessary.
If there's not enough water pressure:
The chain may be too loose if there isn't enough pressure. With the tank lid off, watch the toilet flush. If there is too much slack in the chain, the flapper may close prematurely, reducing water pressure. Tighten the chain and see if that makes a difference.
Loss of water pressure can also be caused by the holes in the toilet bowl getting clogged up. There are little holes all around the side of the bowl, where water is forced into the bowl to refill it after a flush. If any of these holes get clogged, clean them out with a round file, a nail punch, or a similarly-shaped instrument. (Don't push too hard or hammer on the bowl.)
If the toilet overflows:
If your toilet overflows, the first thing to do is to turn off the water to the toilet. There is a valve on one side of the toilet, where the pipe runs from the wall to the toilet. Turn this valve clockwise to close it.
Once the water is off, use a plunger to try to clear the clog. If it works, you'll see the water drain out of the bowl. If the plunger can't clear it, try a simple drain-cleaning tool like a Zip-It or Turbo Snake. If you don't have anything that can remove the clog, or if the clog remains even after trying to clear it, you'll need to call a plumber (or buy yourself a closet auger or plumber's snake).
If you are able to remove the clog, turn the water back on and flush the toilet to make sure the clog is completely gone.
on Feb 06, 2011 | Plumbing
Toilet handle sticks
It sounds like the nylon nut which holds the handle in place is too tight. Try loosening that nylon nut just a little to see if the handle moves easier. Sometimes if they are over-tightened, the handle will be stiff and hard to operate.
Apr 10, 2014 | Home
Keeps on pumping out water from the bowl even when there is no water in the bowl
follow this steps and fix it.
Adjust or replace a flush handle:
  1. Remove the cover from the toilet tank (the higher part at the back of the toilet). If the handle is loose, tighten the locknut with a wrench. If the nut won't budge, apply penetrating oil and let it set before removing.
  2. Unhook the chain from the trip lever and slide the trip lever, with the handle attached, through the hole in the tank.
  3. Soak the handle threads in vinegar for an hour or so to remove mineral deposits, then scrub clean with an old toothbrush.
  4. Reinstall the assembly, tighten the locknut and adjust the lift chain (see below).
Adjust the lift chain:
  1. If the handle must be held down while the toilet is flushing, the chain may be too long. Shorten it by hooking the upper end through a different trip lever, or use long-nose pliers to open and remove some chain links. Alternately, replace the chain with a new one.
  2. Some flush assemblies have a lift wire instead of a chain. If the wire binds against its guide, flushing is impaired. Loosen the guide with a screwdriver, then adjust it so that the flush valve falls freely onto its seat.
Nov 24, 2013 | Home
It will not flush properly .rudy
How to Troubleshoot a Flushometer
A flushometer consists of a metal pipe extending from the back of a toilet with a slender handle on the side that is used to flush a toilet. This type of flush valve is commonly used for toilets in commercial facilities to provide a durable and accurate flush delivery system. If the flushometer does not work properly, troubleshoot it and perform minor repairs. Common issues are often resolved quickly. If troubleshooting does not correct the problem, call a plumber for repairs.
Does Not Flush
1 Inspect the handle assembly. A broken handle or assembly will prevent flushing. If damaged, unscrew and remove the handle assembly. Replace the handle or repair it with a handle repair kit
2 Open the main water supply valve to turn the water on fully. The water supply is normally turned on, but check to make sure it is turned on fully and has not been turned off inadvertently
3 Remove the flushometer's CP cover, the round cap on the very top of the pipe extending from the toilet. Then remove the inside cover directly underneath the cap. Inspect the relief valve. Replace it if it is visibly damaged.
Short Flush
1 Remove the CP cover and inside cover. The CP cover is located on the very top of the pipe extending from the back of the toilet. The inside cover is underneath the CP cover and the diaphragm assembly is located beneath the inside cover. Remove and inspect the diaphragm assembly. A damaged diaphragm assembly can cause a short and incomplete flush. Replace it if it is visibly damaged.
2 Replace or repair the handle assembly. A damaged handle can result in a short flush. If damaged, unscrew and remove the handle assembly. Replace the handle or repair it using a handle repair kit.
3 Remove the CP cover and inside cover to remove the diaphragm assembly. If a low consumption diaphragm is installed on a water-saver fixture or a urinal diaphragm is installed on a toilet fixture, replace it with an appropriate diaphragm.
Mar 04, 2011 | Sloan Regal Flushometer 111 Toilet 1.6 Gpf
Flush handle won't stay on-no specific instructions for installation, pops off when flushed
toilet handles are usually one piece and have to be replaced if fall off dont worry its a easy fix bring your old one to homedepot to match up install new one tighten nut hook up chain to flapper and you shuld be should be fine about $10 for handle good luck
Dec 09, 2010 | Kohler Home
Saniflow system keeps frequently flushing even when the system isn't being used. the system is working normally but it keeps flushing through the day and night.
Need to check the flapper inside the toilet tank. this is what opens when you press on the toilet handle. you may need to replace it or replace the whole flush valve assembly.
Nov 07, 2010 | Saniflo Home
Toilet flush valve is hard to flush....too much suction. Sometimes takes two hands to push the handle.
Hi, you need new Mansfield 210/211 flush valves. They can be found on amazon.. here: Amazon com Mansfield 210 211 seal. I hope this helped you. Cheers
Jun 27, 2010 | Mansfield Plumbing Products Mansfield...
Toilet flushing problem! I purchased an American Standard Cadet 3 High HET toilet (1.28 gallon). When I flush the toilet, the flap will not stay up to allow the water to drain from the tank. When handle is...
The siphon mechanism works on a vacuum principle. If there is the slightest damage to the siphon membrane you will experience the problem you describe. A new siphon is required.
Dec 31, 2009 | American Standard Cadet 3 Right Height...
Toilet stops flushing if you let go of the handle - the flapper just falls back into place. a new flapper did not help
Check to see if the chain that pulls the flapper up, is pulling the flapper up far enough. If it is not getting pulled up high enough, the water suction will pull it back down into the hole. You can adjust the length of the chain to remedy this if that is the problem.
Dec 22, 2009 | American Standard 2002.014 - Champion4...
Home Logo
220 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
