Question about Dell Office Equipment & Supplies
Dell V505 USB connection won't work -- won't print, job hangs in queue
  • 3,153 Answers
You need to clear the queue first see below.
Microsoft has the help you need for this issue and I wont try to give you long and possibly misleading information on here.
It is a common problem but the answer is here
http://support.microsoft.com/kb/946737
You need to refer to method "D" about half way down the page
Once you clear the print job check you dont have any extra printers installed as quite often happens in these situations. If you have then delete your extra printer installations.
Posted on Oct 06, 2009
Testimonial: "the process that fixed it was your last comment - not the drivers(Windows), but the firmware from the Dell website - install and all was good. Thanks!"
  • Project NOMAD
    Project NOMAD Oct 06, 2009
    After you have done that see if any of the hints below apply to you
    One or more of the hints below will probably sort out most USB problems with most USB portable / external hard drives and OTHER devices (though not always)
    A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
    1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
    2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
    3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
    4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
    5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
    6. For FLASH DRIVES you should ensure that the device is set for "quick removal" using the drive control panel properties or use the USB "Safely Remove Hardware" option. If you dont do this there is a very strong chance that any files you transfer may not be there when you plug into another computer.
    If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
    Any exclamation marks by hardware need fixing before you investigate any further
    USB flash drives can fail for no apparent reason.
    Sandisk Cruzers are especially bad for this.
    USB hard drives should be treated with extreme care.
    This is a real hard drive ! and knocks and bumps can quite literally kill them.
    It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
    You should also do this to cheack the drives connections are not bad inside the enclosure
    Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
    Known as "The Click Of Death"
    If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
Only prints one page
Can you delete your printer from your pc and reload it? mine hangs up once in a while too. Just weird gremlins as sometimes it's perfect.
Jun 27, 2014 | Dell V313w AllInOne InkJet Printer
In Windows 7, items put in the print queue at home won't print when I get to the office.
I don't see how this can be done, because there are 2 different print queues in question. Not to mention the lag and buffer required by the printer. So when you disconnect communication the job hangs.
Besides the spooler at work my lie on a dedicated print server, especially if the printer is on a network and and not attached directly to you PC.
Feb 26, 2013 | Microsoft Windows 7 Professional for PC
Lexmark X1240 starts to print then stops and job gets stuck in print queue.
If you are printing wireless thru a D-Link adapter, you are going thru too many connections. Let me explain: I have worked on electronics most of my life and the old saying goes, "the more breaks you have in a connection, the more chances you have that something, somewhere in between the breaks, will cause you to have more problems".
Go thru your Uverse directly with a RJ45 or CAT5 cable, if possible. If not, then hard wire it using a USB switch. This allows multiple devices to use the same printer.
Hope this helps.
Apr 25, 2017 | Lexmark X1240 All-In-One InkJet Printer
On my home wireless network, my notebook computer's print jobs go to the correct printer but won't stop printing until it is canceled from the device manager. The PC that is on the network wor
sounds like the print job queue is overloading the wireless network, causing a hang on that side
big print jobs do that even on wired systems might consider adding more printer memory
May 26, 2012 | HP P2035n Laserjet Printer Monochrome
My Dell V510 printer will not print. I have checked the cables, I have checked the ink cartridges, I have unplugged the power supply, I have re-started the computer and nothing helps. Items in the print...
Try running Delete Print Jobs to remove any stuck print jobs in the queue.
Can you copy a document under the glass? B&W and color?
What is the correct model of the printer? V505 or V515? Dell does not have a V510.
You can try reinstalling the printer using the instructions located at...
Dell V505 & V505w All-In-One (PRODUCT) RED™ Printer owners thread (W7)
Dell V515w Wireless All In One Printer - (RED) owners thread
Virus programs and firewalls will block communications.
Rick
Apr 19, 2011 | Dell AllinOne Multifunctional (v515w)...
Key is flashing. Internet blue light is on. Printer gets signal for print job but won't print until I USB connect it to my Macbook OS 10.6.
Follow the steps below to resolve the issue
The print queue and Dock printer icon
When you start a print job, you will see your printer icon appear in your Dock. Click the Printer icon to open the print queue, which is a list of print jobs that are printing, on hold, or paused. The print queue will also display messages sent from the printer.
You can alternatively open the print queue from the Print & Fax pane of System Preferences.
printer%20queue.png In the Print Queue toolbar you have these buttons:
  1. Delete - Deletes the selected print job.
  2. Hold / Resume - Will hold / resume the selected print job.
  3. Job Info - Shows details of the selected print job, such as job name, status, Completed, Job Message, and so forth.
  4. Pause / Resume Printer - To Pause / Resume the Print Queue.
  5. Supply Levels - Will drop down the Supply Levels sheet showing you the levels of ink / toner your printer has.
  6. Printer Setup - Lets you configure the printer's name and location details.
  7. Printer - Sets the Print Queue window into Printer mode.
  8. Scanner - Visible if you have a multi-function printer connected via USB. Click it to set the Print Queue into Scanner mode.
You can see what your print job looks like with Quick Look. Click the arrow on the print job just to the left of the Status column or select the print job and press the Spacebar.
From the Print Queue menu bar, the "Printer" menu has these additional options:
  1. Customize Toolbar... - Used to add and remove item from the Print Queue's toolbar.
  2. Make Default - Will set the printer pertaining to this Print Queue your default printer.
  3. Print Test Page - Will send the CUPS Printer Test Page to your printer.
  4. Network Diagnostics - Will bring up the Network Diagnostics application, used to check each layer of your network connection.
  5. Log & History - Used to open the Console application and show you the log entries for your current and past print jobs.
  6. Show Printer List - Will open the Print & Fax System Preference showing you the list of Print Queues.
From the Print Queue menu bar, the "Jobs" menu has these additional options:
  1. Show / Hide Completed Jobs - Will alternate Show / Hide in the Print Queue all completed printer jobs and completed functions, like checking the supply levels of your printer.
  2. Show Everyone's / My jobs - Will alternate showing Everyone's / My print jobs.
You can control-click (or right-click) your printer icon in the Dock for this convenient menu:
printer%20proxy%20dock%20menu.png From the Dock menu you can see your printer's status, toggle Pause and Resume Printer, Auto Quit (once print job completes) on / off, and from the Options sub-menu you can toggle Keep in Dock on / off.
Feb 08, 2011 | HP DeskJet 6988 Printer
I just replaced the fuser unit on a dell MFP3115 cn. It now goes into clabration mode and then error to call support
The Print Diagnostic Utility diagnoses and resolves common printing problems and communication problems, including:
If you prefer, you can skip this information and go directly to downloading the tool .
  • Connectivity :
    • USB: Ensures that the USB connection from your computer to the HP product is working correctly.
    • Network: Ensures that the network connection between your computer and your network is working correctly. If the tool detects a network connectivity problem, you will be prompted to run the HP Network Diagnostic Utility for better results.
  • Spooler : Automatically restarts the print spooler, which sends print jobs from the computer to the product, if it has been stopped.
  • Online status : Checks if the product has been paused or set to offline, and then sets the status back to online if necessary.
  • Device manager : Checks for problems in Device Manager that would prevent printing.
  • Print queue : Checks for and clears pending print jobs in the print queue (a log of print jobs waiting to print).
  • Port : Checks the port settings for the HP product.
  • Driver : Checks for alternate-driver settings.
  • Conflicts : Checks for conflicts with other drivers, such as other printer brands.
  • Default printer : Checks the default printer setting and prompts to select the HP product as default (optional).
Oct 26, 2010 | Laser 3115cn All-In-One Printer
I need help with my dell printer. it wont print
Hi, Malcolm.
If there are no jobs in the queue, be certain that your USB cable is snug.
If still a problem and there are jobs in the print queue, go to Printers and Faxes and delete your Dell printer icon.
Disconnect the USB cable.
Restart your computer.
Reconnect the USB to your computer.
Your computer should see your printer. Install the printer driver.
If still a problem, let us know if any error messages and please provide more details including your printer model.
Hope that helps.
Oct 01, 2009 | Office Equipment & Supplies
Printer hangs up.
1. check the printer, make a copy
2. check connectivity, open device manager - USB Printing Support(under Universal Serial Bus Controllers) must be there - swap cable/port if it´s not
3. uninstall, reboot then re install printer driver
Jan 03, 2008 | Epson Stylus CX5800F All-In-One InkJet...
My print jobs hang up in the queue
Test pages are printer generated not from the computer. Have you checked Microsoft help on this? make sure you are on line. Go to My Computer /Help, then when the help pages comes up Type in print spooler See what you get Rephrase the question if the answer you seek is being missed.
Jun 21, 2007 | Dell Inkjet 720 Printer
413 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
