Question about Kenmore 53642 / 53644 Side by Side Refrigerator
Evaporator fan my fan that blows on the evaporator coil seems to be running all of the time. I noticed that I had water in the drain pan so I cleaned it and while I was doing that I cleaned the vacuumed the dust and such off the coils. Now the drain pan is empty but I have a fan running all of the time. Any suggestions?
    Scholar:
  • 146 Answers
Check and make sure that you didn't knock a piece of insulation down onto the condenser fan when you were vacuuming off the coil. When the fan is blocked it can cause the compressor to what is called short cycle and the refer will never get up to temp. Also check your door seals. Insert a dollar bill between the gasket and frame and gently pull on it. It should be fairly tight as you check all the way around the gaskets if not you may have to replace the gaskets or adjust the door. As for the pan underneath. It should have a little moisture in it every 8 to 12 hours as it is the capture pan for the self-defrost. If not you could have a problem with your defrost heater check for ice build up on the back panel of the freezer. If there is a build up then your refer is not going into defrost and you may have a problem with the defrost heater, defrost timer, defrost thermo., etc. Be sure and check all these areas as you don't want to throw money away needlessly.
Posted on Dec 26, 2007
Does a bosch fridge freezer always have water in the evaporation tray?
Hello Mary;
My name is Peter. I am a retired field service refrigeration technician.
It is normal to have water in your evaporator drain pan.
Your refrigerator goes through a defrost cycle every 8-10 hours, where your refrigerator will shut down for about 20 minutes and your defrost heater turns on.
You do not need to clean your drain pan. You have a condenser fan that blows across the drain pan to evaporate the condensate.
You drain pan will fill during the defrost cycles. the condenser fan blow across the drain pan and will evaporate the water.
The amount of water in your drain pan will depend on conditions such as high frost in the freezer.
Mary, you had just happened up the drain pan not completely evaporating the condensate.
Sounds to me like you are in good shape.
Peter, Baltimore, MD, USA
Nov 02, 2014 | Bosch KAN60A45G Inox 510 l Fridge Freezer...
Water collecting in the pan underneath the fridge.
it should do this but the water should evaporate from the heat from the condenser and compressor,when the machine goes into defrost a heater comes on and melts all the frost off of the coil,the water drains down into the pan where the water will evaporate,when was the last time you cleaned out the condenser coil?remove the front bottom kick panel and check the coil,if it's filled with dust it has to be cleaned out at least once a year especially if you have a cat or dog,then pull out the machine unplug it or shut off the control and remove the bottom back panel,the easiest way to do this is to vac up as much dust as you can with a shop vac,then set it for blow by putting the hose on the other end of the shop vac and blow the dust out of the coil,you can buy a condenser brush that will remove dust thats stuck inside the coil but the shop vac works great,through the condenser this is how the heat escapes out of the machine,also clean off the fan motor in the rear,also there are plastic water lines that come out of the water valve that could be cracked going to the ice maker and water dispenser or the valve itself could be cracked causing this problem or the pan could have a crack in it,very unusual for the pan to overflow,when you're done cleaning it plug it back in,make sure the fan is running fine and have someone fill a cup of water and check the plastic lines coming from the valve to see if it leaks,pull out the pan and check it for cracks,fill it up at the sink and check it,if everything looks good you can shut off the water valve that goes to the fridge for a few days and keep an eye on the pan,like i say it's unusual for the pan to overflow just from the defrost water,if the water is evaporating with the water shut off then you have a crack in one of the water lines going to the ice maker or dispenser
Aug 05, 2012 | Amana ASD2522WRS (251 cu ft) Side by Side...
Maytag side/side model MSD2754GR- Ice maker while filling overflows running out of freezer section onto floor.
Remove the back panal in the freezer compatment to reveal the evaporator. You will notice the drain pan frozen up with ice. pour hot water on it or blow hot air with a hair drier. If the fridge is turned off the ice will melt and clear the drain hole. When the ice is cleared the water will be alowed to flow out to the evaporating pan under the fridge. Be sure that the water runs freely out of the fridge and allow a few hours to dry. Good luck. Be careful not to damage the evaporating coils.
Dec 07, 2010 | Maytag MSD2756G Side by Side Refrigerator
Our A/C unit is leaking between the inside unit and the heating unit. We've had two repairmen out. Both seemed confident that the lines were clogged and both blew them out. The a/c is still leaking. It...
Could be the pan under the evaporator has holes in it. Did the technicians pull the coil to check for holes in the pan? At the very least, after blowing out the condensate lines they should have poured water into the pan to check for proper drainage and to ensure there were no leaks in the evaporator's drain pan.
It could also be an issue with not having a trap installed in the condensate line. On some sytems that have the condensate line and evaporator coil on the suction side of the fan, no trap installed will allow the water to be sucked back into the pan and eventually may cause the water to spill over the pan. Having the trap installed insures the water will drain properly. It could also be an improperly installed trap that allows air leakage. To give you an example, if the condensate comes off the pan and goes to a tee (used often as a port for blowing or cleaning out the line) and the tee is not capped off when not being used for cleaning purposes, this will allow air to be sucked back through the tee and prevents the water from flowing through the tee and onto the trap.25011e4.png You were correct in not running the unit as water can drip down into a fan motor below the pan and cause it to short out.
One other issue that comes up from time to time is the inability for water (condensate) to drain or trickle down the face of the evaporator coil. This is usually due to dirt blocking the fins of the coil and the condensate accumulates on other portions of the coil and when it hits the blockages of dirt or other debris, it doesn't perform its usual capillary action and follow the fins down into the drain pan, but instead stops, accumulates and then falls straight down into the lower sections. Check the coil's fin surfaces for dirt or other debris. If present, have the coil cleaned.
Sep 03, 2010 | Heating & Cooling
Water draining from my upstairs unit
It is normal to see water coming from the evaporator coil. This shows the humidity in the air crossing over it is being removed. I would be a little concerned about water standing in the pan. I recommend you blow the drain out and run a little bleach through the drain. The bleach will help eliminate slime, mold, and mildew. It is a good idea to repeat the bleach every time you change your filter. They also make tablets that you can put in the evaporator pan if you prefer. But a cup of bleach once a month is just as effective in my opinion.
Jun 29, 2010 | Carrier 38CKC036 Air Conditioner
I have a Maytag refrigerator model # MTB2156BEB that leaks water from the bottom of the refrigerator door> I think the drain plug is clogged. I need to know where it is and how do I clean it.
This is most likely drain off water from the automatic defrost cycle.
There is a removable drip pan under the refrigerator that can get filled with lint and mildew and keep the water from evaporating properly. There is also a fan which pulls air across the condenser coils but also serves to help evaporate the defrost water.
Remove the drip pan and clean it out, clean off the coils with a brush and vaccum, and be sure the bottom fan is running. That should solve your problem with ZERO dollars out of your pocket.
Good luck. Hope this helps.
Sep 11, 2009 | Maytag Refrigerators
Water dripping out of freezer into bottom of refrigator
It is normal for water to run from the freezer to the bottom of the refrigerator during the automatic defrost cycle. But it is supposed to run into a catch pan and be evaporated by the hot air being pulled over it by the small evaporator fan on the bottom of the unit.
If water is not going into the catch pan, and instead is running out of the evaporator down the side of the liner, it will most likely end up on the floor instead of in the catch pan. If this is the case, drain your line could be stopped up with an accumulation of algae. To clean it out, find the drain plug in your freezer and pour a cup of diluted bleach into it. Pour it very slowly, because if the line is completely stopped up, it will not seep out and thus cannot get to the point of blockage.
If the drain is completely blocked, try using a can of compressed air (like is used to blow off computers and such), forming as tight a seal as you can between the air tube and the drain. If this fails, it might be time to call the repairman.
There is one more thing that might give the appearance of water 'leaking' and that is if the condenser fan is not properly pulling air over the drain pan to dry up the water from a self-defrost cycle (which normally occurs every 24 hrs). In this case, cooling will also be severely affected, since insufficient air flow over the condenser coils will make the condenser far less efficient.
Finally, and maybe you shoud try this first if you're sure the drain line is not stopped up: CLEAN THE BOTTOM COILS of dirt and lint accumulation. I can't tell you how many refrigerators I've worked on that needed nothing more than to have the condenser coils in the bottom of the unit cleaned. Restricted air flow over these coils is THE number one cause of refrigerator inefficiency or failure. By a HUGE margin.
Jun 28, 2009 | Refrigerators
Draining condenser tray
normally the drain pan will evaperate the water as the compressor fan blows air across the pan along with the compressors heat
if you still want to rempve the water you can place a towell in the pan and let it soak up the water remove the towel and it will be gone
Apr 25, 2008 | Whirlpool GS6NBEXR Side by Side...
Drain Pan overflowing
Refrigerators use different methods to eliminate the water, but they all use evaporation of some sort.This works,as most of the water in the drain pan comes from melted ice on the evaporator coil during the defrost cycle, and this is not very much. It sounds like you have excessive water in the pan. You stated the freezer/fredge is working properly. The condenser fan is running, I assume. Cleaning the dust off the coil will help the air flow. Most residential units do not have heating element in the drain pan. Your problem sounds like you are getting too much water in the pan. Have you noticed excessive ice in the freezer? Are the door gaskets in good shape. Does the unit have water and ice in the door? If so, where does the drain to, and has there been high usage of this?
Nov 11, 2007 | Jenn-Air JCB2388G Side by Side...
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
51 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
