Question about Sta Rite Sr400na Max E Therm Pool & Spa Heater Dual Electronic Ignition Lo Nox 400,000 Btu Natural Gas
My heater turns on then has a r 6 reading then shuts off?? Help!!
    Champion:
  • 246 Answers
You must open the heater to get the code on the back of the board
Posted on Oct 16, 2009
I reset the heater by shutting it off for about
sounds like temp sensor is bad
Sep 27, 2014 | Pool & Spa
Jamdy RS Shuts off heater too soon
when using the aqualink make sure heater is in tstat mode if not for your heater then turn heater all the way up make sure the wires are connected to pool and com then make sure the wires 5and 6 are connected to the heater then the aqualink will command heat if the red light is lit on controller
Feb 10, 2014 | Jandy 7953 AquaLink RS One Touch Control...
I have a Laars LX250 pool heater. The pump and heater are tied in with a timer that has a fireman switch. When operating properly the switch disables the heater for cool down before the pump shuts off. I...
If this answer does not fix your problem, pleasecomment with additional details prior to rating the answer. Positive feedbackis appreciated once your problem is solved! Thank you.
Aug 17, 2011 | Jandy LAARS LX250 - NATURAL GAS, DIGITAL...
How to replace water heater element will water cme out when you remove element does tank have to be drained
Safest method:
Shut off electricity to heater.
Shut the water valve.
Drain heater to below the level of the element, open hot water valve in house to vent heater to speed draining.
If the element is on top, you don't have to empty the heater.
Remove old element, install new element.
Leave hot water valve open somewhere in the house.
Turn water on.
Once air is removed at hot water valve, turn electric on.
Shut water valve.
Gary
Aug 13, 2011 | Reliance /State Ind. 9002450 Element For...
I have a everdure 6 burner gas heater. its pretty old and works sometimes. the problem is that it take a while to turn on and once it started it just turns its self off with in minutes. this happens...
Your flue-less gas heater may simply need a a good interior cleaning and servicing. From what you described it sounds like the Oxygen Depletion Sensor (ODS) may be clogged with dust, lint etc. The ODS is part of the pilot assembly and constantly reads the oxygen level in the room, when the heater is in use.If the oxygen level drops to 25% the ODS shuts the unit OFF by closing the gas valve. This can occur if the ODS is dirty, because it's falsely reading the oxygen level.
One other thing that can mimic this problem is a faulty Thermocouple. With age, they wear out. It's also a safety feature that controls the gas flow to the pilot.
Everything I have mentioned is repairable. But, if you want to make it a DIY project, it will require some dismantling of the heater cabinet to access everything and replace parts. If the heater is as you say "pretty old", you may want to consider buying a new heater. Sometimes, it's just not worth the time and effort to repair an old heater.
Hope this helped you to troubleshoot and solve the problem.
May 27, 2011 | Heating & Cooling
My hayward fires up for about 6 minutes then shuts off with a LO alert blinking
You problems could be in any of the following areas per the Hayward owner's manual. If you need help with continuing the diagnosis please comment with what specific help you need.
john224.jpg If you can not enlarge this enough to read it, please contact me thru our site at www.arrowpools.net and I'll email the manual to you. If you have the manual that came with the heater, your troubleshooting info is on page 38.
John
Nov 08, 2010 | Hayward H Series Pool & Spa Heater 400k...
KSRS25ILSS02 The Freezer is
Select the "defrost" mode, if available. Otherwise, just shut it off for several hours and let the frost melt.
The frost is fooling the fridge into thinking it is still too warm inside the refridgerated comparments.
Aug 25, 2009 | Refrigerators
Same Issue
the pump stop so will not drain spa dip # 4 may turn off for the delay but not sure if the pump will still turn off since this is new tech. good luck
Jul 05, 2009 | Jandy Aqualink Rs4 One Touch Control...
I have an atwood water heater that won't stay light
I am having the same problem. Is your water heater a power vent?
May 02, 2009 | RTO Atwood DSI-RV Water Heater-6 Gallon
Sta Rite Sr400na Max E Therm Pool & Spa Heater Dual Electronic Ignition Lo Nox 400,000 Btu Natural Gas Logo
147 people viewed this question
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
john h
Jim Goldsmith
Jim Goldsmith
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
