Question about Fisher and Paykel Active Smart® E522BR Stainless Steel Bottom Freezer Refrigerator
F/P E402B fridge keeps beeping
I have the same problem it seems. I solved it only temporarily by deforsting the freezer compartment. A week later the problem re-emrged. I think that it might be the heater defroster and I've just ordered one for about $70.
5 Suggested Answers
  • 958 Answers
SOURCE: Fridge is defrosting
please take a look at the compressor if it is running.
if the evaporator fan is running, the compressor should be running as well to cool the fridge.
if the compressor is running, then you have a problem with refrigerant. there could be a leak in the system.
have a qualified technician check your unit for further repair.
tnx 4 using fixya,
drcool
Posted on Sep 13, 2008
  • 56 Answers
SOURCE: FREEZER NOT DEFROSTING AND ICING UP
Fridgedaire has a lot of defrost termination switches that are separating and not allowing the defrost cycle to heat up. The defrost termination switch is located behind the wall that is icing up, take out the screws that hold the back wall in place and use a hiar dryer or hot water to remove ice do not use an ice pick or sharp object of any kind. the def terminatin sw is small and round about 3/4 of and inch thick and has two wires coming off of it one goes to the defrost heater the other usually back into the wiring harness. check it to make sure it is not coming apart. Ohm it and the heater out it should have continuity when below 20 degress. the heater should have continuity all the time,.
Posted on May 30, 2009
SOURCE: defrost water is not draining into the evapataror pan
water not draining in pan in freezer
Posted on Sep 05, 2010
kel1guy2002
  • 3740 Answers
SOURCE: Hi, I have a Fisher and Paykel E402B
Your automatic defrosting circuit is not working. There are several components that can stop the defrosting process:
1. The defrost control
2. The defrost element
3. The defrost thermostat
Any one of the 3 can open cause the automatic defrosting process NOT to work.
If the defrost control fails, it just stops defrosting and ice builds up on the evaporator coils.
If the defrost element fails it will go into the defrost cycle and not cool again until the internal temps reach 60 Deg F.
If the defrost thermostat fails in the open position the heater will not heat up and the freezer will ice up.
There are 6 models of the R402B so I was not able to narrow down a source your exact parts data.
However, if the defrost control has failed the good news is the most expensive one is $18.95 AUD
Hopefully this gives you something to go on. I think it will either be the defrost control or the thermostat. If you can locate the defrost control turn it until it clicks ONCE and see if the unit shuts off and completes a defrost cycle. If it heats up but does not complete the defrost cycle again your looking at a problem with the defrost thermostat. If it does not heat at all then the problem is the heating element.
The defrost control will have 2 sloped tabs on it so that you can only turn the control one direction. The defrost control dial with the tabs will be no larger than 1/2 inch in diameter.
UK Parts: http://www.partmaster.co.uk/cgi-bin/search.pl?query=Fisher+%26Paykel+E402B
AU parts: https://www.statewideapp.com.au/shop
You most likely will have to make a "contact" enquiry at either site above. For the defrost tmer, heating element or the defrost thermostat.
Thanks for choosing FixYa,
Kelly
Posted on Jun 21, 2011
Testimonial: "Thanks heaps. You guys are great."
Fridge Freezer E402B not functioning properly.Solid red error light,with green light flashing up and dwn when push the = button.No air circulation to fridge,compressor seems to continious,also fridge
Natasha try this:
turn off the fridge's settings.
pull the power cord from the wall outlet
open the doors and keep them so for a few hours.
before these, take out the most perishable and keep in cool place.
after a few hours you may see a puddle of water under the fridge. clean the water and vaccum the fridge underneath and behind.
now reconnect power and set at recommended level. goodluck!
Mar 26, 2014 | Fisher and Paykel Active Smart E522B...
Keeps getting error code dh and the fridge isn't staying cold now
Your refrigerator is telling you that it is not sensing a current flow through the defrost heater circuit within a certain number of hours. Could be a bad defrost heater, or a thermostat / fuse package located in the upper right hand corner of the freezer, behind the back wall of the freezer compartment. The reason the refrig is getting warm is that the cooling coils (behind that back wall of the freezer) are blocked up with frost, preventing air flow across them and on up into the refrigerator compartment. It is a bit of a pain to get the back wall out inside the freezer, but it will have to be done. Melting the frost off the coils with a hair blower will temporarily solve your cooling problem, allowing a week or so to get the part(s) you need.
Feb 07, 2011 | LG LFX25960ST Stainless Steel French Door...
Freezer not working on ariston fridge freezer 2 orange lights on top of fridge keep beeping every two hours causing fridge not to work is there a reset button
freezer not working on ariston... Solve freezer not working on ariston fridge freezer 2 orange lights on top of fridge keep beeping every... (More) freezer not working on ariston fridge freezer 2 orange lights on top of fridge keep beeping every two hours causing fridge not to work is there a reset button
Sep 13, 2009 | Freezers
F&P E402B Active Smart Fridge Compartment not cool
You need to start with a clean totally defrosted unit. That means clean, vacuum and wipe as much as you can around the entire motor compressor area especially any coils you can reach. Then set temp around whatever normal is and see what happens. If still the same it's time to have a tech do pressure tests.
Mar 29, 2009 | Refrigerators
Inside Dsiplay Not Always on
Hi -
I haven't solved my problem, yet, but i have determined that it's beyond my scope and will require a pro's visit to my house.
thanks for the line.
b
Aug 17, 2008 | GE Profile PFS22 33" Artica French Door...
Fisher & Paykel Model number 402B S.Steel. Bottom frezer top Fridge.
My Fisher & Paykel Model E402B Stainless Steel Fridge/Freezer has a problem. Bottom Freezer is OK but Refrigerator will not work properly, somtimes it will freeze everything now it just warm inside i have checked the the fan and the rubber holding it up has broken also the ice is frozen in the vents can you help i got someone in to fix it but he said it will cost around $600 as there might be more wrong with it, what do you suggest thanks Clare
Jun 13, 2008 | Fisher E522BLX Stainless Steel
Frigidaire frige not getting cold but freezer working
my refridgerator is not getting cold but the freezer seems to be working fine. can anybody please give me some advice on what this could be. We had a new defrost element put in a few weeks ago and we now have moved house so fridge is cool but not really cold enough model E402B any help would be appreciated.
thanks pam
Apr 29, 2008 | Refrigerators
I have a zanussu fridge
Re. Zanussi ZK87/46EFS Fridge Freezer
The same symptom occurred in our fridge freezer. The fridge compartment warmed up whilst the freezer compartment continued to keep temperature.
The cause of our problem was diagnosed as a frozen sensor that controls a flap, that controls the flow of cold air from the freezer compartment up into the fridge compartment. We were advised to power off the fridge freezer (removing all food and trays from the freezer unit first), and to leave it to defrost for 24hrs. We needed to place a few towels on the floor of the freezer compartment to soak up the melt water. After 24hrs we followed the power up instructions in the manual (versions are available online if you have lost yours). Within a few minutes it was obvious that the fridge compartment was being cooled – Problem solved :)
Apr 13, 2008 | Zanussi Refrigerators
Fisher and Paykel Active Smart® E522BR Stainless Steel Bottom Freezer Refrigerator Logo
78 people viewed this question
Top Fisher and Paykel Refrigerators Experts
Brian Coughlan
Charles T Nevin
Charles T Nevin
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
