Question about GE Refrigerators
Freezer works, fridge at 58 deg - GE Refrigerators
    President:
  • 744 Answers
Hi, With the information you supplied i'm going to assume there is an ice build up at the rear of the freezer. Your problem is going to be with your defrost system. I will also assume you have the ability to repair this yourself. This is going to be one of three problems with your refridgerator, 1st thing to do is remove shelfs and panel in the back of the freezer...you should see ice build up on the evaporator...don't worry get a hair dryer and melt the ice. Next locate the wires for the heater...using a multi meter test the heater for condinuity...if the heater is bad replace it, If the heater is good replace the defrost thermostat..the stat normally is a barrel looking part clipped onto the evaporator pipe. The last possible problem could be the evaporator fan, have you heard the fan running in the past few hours?..if you are not sure pull the panel out to where you can see fan and watch it over an hour to see if it turns. I have included links with pictures of what the parts you need to check are: http://romulusappliance.com/manufacturers/maytag/refrigerators/575432.JPG defrost stat http://www.hotekalliance.com/UploadFiles/2008627111553382.jpg heaters http://www.applianceblog.com/archives/EvapMotor1018185.jpg evap fan. Hope this helps. If you have any other questions please feel free to comment again. If you decide to get a repair guy in should not cost you any more then $120 - $200 depending on make/model/problem Good luck & thanks for using fixya! Mike
Posted on Oct 06, 2009
Testimonial: "mgprice, you are a genius!!!! I have not yet fixed the problem, but you were right on. When i removed the panel there was one solid block of ice."
Freezer only gets down to around 18 degrees but fridge is fine. No frost on the freezer evaporator fan is running
Modern consumer refrigerators only have coils in the freezer. In the lower back of the freezer there is a small fan and possible a damper (flap that opens/closes) to push cold air from the freezer to the refrigerator. Given that the freezer is 18 deg, it's probably cold enough to keep the fridge area at typically 34 deg.
So the cooling system (compressor, coils, thermostat) are not working properly to keep the freezer at, typically 0 deg. Possible causes: partial loss of refrigerant gas, icing around evaporator coils (in freezer), compressor failing, dust clogging condenser coils (under fridge), condenser fan clogged or broken (under fridge), thermostat failure.
I'd start with condenser. Remove the slotted trim at the bottom front and look in with a flashlight. Are the coils clean? Pull out the fridge and remove the lower back cover (usually cardboard). You can now see the coils and fan. Clean and blow them out.
If it's icing, it probably means freezer door not closing tight. If auto-defrost not working properly it would probably get worse over the period of a few days so not likely.
Apr 21, 2016 | Frost Refrigerators
Igloo refrigerator's freezer: -16 deg. Fridge: 60 deg. No evap fan & duct from freezer to fridge. Cond coil clean. Discharge line warm. T/STAT@coldest temp. Fridge gasket seals. Condensate drain clear
freezer is working fine, refrigerator won't go above 60 degrees.
www.shopyourway.com > Manage My Life > Questions
Freezer is working fine but fridge won't go about 60 degrees. Cleaned out pass through from freezer to fridge, clean vents, and cleaned coils. All to no avail.Missing: gloo
Beckly Powerful Suction Cup Handle No Tools Necessary!
www.amazon.com > ... > Bathtub Appliques
Amazon.com, Inc.
Rating: 3.6 - ‎85 reviews
Just Turn 60 Degrees and place on any Flat Smooth surface. For Bath Safety and Cabinet Doors Also Fridge Accessory. Beautiful ... No tools, no glue! No need ...
[PDF]Operate Refrigerator In Room Warmer Than 60°F
Jan 03, 2016 | Refrigerators
Why is my upright fridge freezer bleeping constantly, both fridge and freezer cooling ok
Model number? Usually that is warning that something is wrong. Example defrost not working properly thermistors are defective, or door open. Need your model number to give you answers
Appliance 911 Sea Breeze
Oct 01, 2015 | Refrigerators
Fridge too warm
It is likely to be either the circulation fan in the freezer or the defrost element. The cold air is blown from the freezer into the fridge if the fan doesn't work then no cold in fridge( actually I think there are 2 fans in these, 1 horizontal 1 vertical) otherwise it could be a defrost problem, if the element doesn't work the rear fills up with ice and the air cant flow. Both are behind the rear panel of the freezer
Jul 08, 2013 | GE Energy Star PDS22SIS Stainless Steel...
I am having trouble getting new fridge cool enough in fridge. Should it get below 40 f in fridge on mid setting of both freezer and fridge section
fresh food tempt should be 38 deg ( this is good ) and 40 is close . as it will be 5 deg up and down freezer thempt should be around 5 to 15 deg or ice mker will not work . make sure the coils ore clean and fans are working or these tempt can not be obtained . mm feed back pls
Jan 01, 2011 | KitchenAid Architect Series II KSRG25FVMS...
Freezer section 26 deg f. refrigerator section 58 deg f with both dials set on 3. refrigerator section not cold even if dial is set to 4 or 5
when you open the freezer door do you hear the fan blowing,also is there any like snow or frost on the freezer wall inside the freezer,touch it and make sure or was the door left open?is there frozen water droplets on the food packages and on the racks,let me know what you find and send the model number,open the fridge door and look on the left side wall near the ceiling
Sep 07, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
2001 GE side by side refrigerator model TGX26KRDA WW Beginning about a month ago the refrigerator temperature rose to 60 deg. F. Freezer remained well below 0 deg F. Checked baffle which was open and...
Is the fan that moves the air from the freezer to fridge running If there is a switch in cabinet somewhere the freezer door would contract it, with door open push in switch hear the fan both are good. Don't hear fan check evaporator or freezer fan and that switch it may be a duel switch open light closed fan run. Tricky there are light switches, when out light on or when switch is in its lights out
Mar 17, 2017 | GE Refrigerators
Fridge side of American Fridge/ freezer not cooling down.
does the fridge have 2 motors or 1 if it have only 1 motor the gas level in the system are low. if it have 2 motors check if the fridge side motor runs
May 17, 2009 | Samsung Refrigerators
Kenmore 596-76512 fridge not cooling freezer seems to be working still
If the fan above the evaporator coils in back of the cover isn't running then no cold air will be blown up to the fridge area. That's a common failure item and very easy to replace yourself. And by the way... $200 bucks and 2 weeks out is about normal these days believe it or not. It's what we would charge ya! :) At least you did the troubleshooting and saved yourself a couple hundred bucks.
Jan 14, 2007 | Kenmore 71812 / 71814 / 71819 Bottom...
Refrigerators Logo
76 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
