Question about Toshiba (HDD2181) (hdd2181-50pk) 30 GB Hard Drive
Smart is Tripped?
Smart is Tripped. The hard drive is detected in dos, is able to be formatted but unable to install an OS on it. Is there a way to save it?
4 Suggested Answers
  • 163 Answers
SOURCE: My western digital Passport 320Gb usb drive is not detected
U need to update windows XP , USB drivers will be installed
Posted on Dec 29, 2009
  • 69 Answers
SOURCE: Toshiba 500 GB External Hard drive cant be detected by windows xp
yes you could simply format the harddrive in Fat32 using your macos that would be the best solution but don`t forget to backup your data by copy pasting the files on your mac or something else and after that to move them on the external hdd again to be available on the windows machine
Posted on Mar 11, 2010
Testimonial: "It worked... I never thought it could be that easy... Thanks a lot!!!"
Biggdex35
  • 333 Answers
SOURCE: My Apollo 250GB USB hard drive can't be detected
It should be in My Computer after you plug it in. If not, then go to control panel and search for new hardware. Click on system in control panel it should be listed under usb. Maybee it needs a new driver.
Posted on May 17, 2010
Getting drive controller errors on dell optiplex 330 dt
First, check you hard drive as follows:
*Download Seatools For DOS (free) from my link; in the site screen, click "DOWNLOADS" tab, then "Seatools For DOS". Burn it to a CD. Reboot with it in your drive. In the screen that appears, first check that SMART has (or has not) been tripped. If it has been tripped, your drive is failing. Then click the upper left corner of the screen for the short test and let it run. It will notify you either Pass or Fail. This is from Seagate Corp. but will test all other drives, not just Seagate.
If your drive passes as good, the chances are that your motherboard is failing/failed. Try swapping your cables as you stated, but I don't think that will help. If you have an extra hard drive you can swap it to test, but if it is empty you will need some kind of operating system installation disk to see if you can load an OS on it. If so, then the hard drive is bad.
For more detailed and in-depth help, I hang out at www.suggest-a-fix.com computer help forum (free). Post in.
Mar 27, 2014 | Dell Precision Computers & Internet
1720- smart Hard Drive detects immiment (failing Attrs:05
Run CHKDSK/F straight away and back up your data.
Fit a new hard drive and format then install your OS on it. Install driver updates from hp.com and finally update windows.
Restore your data.
Feb 05, 2011 | HP Compaq Evo n800c Notebook
I have Fantom Drives Titanium 250GB i am not able
Connect it to a different computer. If it still is not detected, then there is a hardware problem. Exercise the warranty to get it repaired/replaced.
Oct 30, 2010 | Fantom Titanium 250GB External...
How to fix faulty hard drive?
Are you able to detect the hard drive in BIOS and windows? If yes format it and run scandisk/chkdsk to fix.
Jun 22, 2010 | Seagate U6 (ST340810A) 40 GB Hard Drive
I am not able to instal OS in my home PC. Asking me to install scsi drive. my hard disk seagate. where download this flopply disk bios drive software
hi
Checked the Bios Setting and check whether the Hard drive is recognizing or not -
Check the Boot sequence
Check Boot from the CD Drive
Format the Hard drive
it will work
Feb 23, 2010 | Seagate 500GB Maxtor Diamondmax21 SATA2...
How to format hard drive
To format any extended or external hard disk
Right Click the drive (example D:\ )and select the FORMAT Options
Click START to Format the Hard Drive. The time to format depends on size and the condition of the Hard Disk.
Feb 15, 2010 | Acer Aspire SA80 (ASA80UC4603) PC Desktop
I am unable to install win Xp. when trying to boot from a cd to install fresh win xp ser. 2. system reboot after copying few installation files. The Bios set up shows the Sata Hard Drive but unable to load...
your HDD may be bad. I have had a number of HDD that appear fine in the BIOS but won't format either via the install disk or separately via a Linux boot disc.(You can somtimes hear them clicking on and off [seeking])
If you are mad keen on the drive, then D/L 'Hirens Boot Disc' and boot into the DOS mode (it also has a Mini XP mode).and use the HDD format utlity 'killdisk'. This will remove anything on the drive, format it and set it up ready for a fresh install.
If Hirens Boot Disk can't see the SATA drive then its stuffed.. for sure..
Apr 16, 2009 | ASUS P5LD2-VM Motherboard
Hard drive reported at zero bytes
see after teh utility named Partition Magic, It will solve these typoe of errors. Another cheap option is to try to format it with a vintage computes BIOS, HDD Formattion option, Not available in newer BIOS.
Tyr aldo Fdisk /mbr in the DOS PROMPT , booting with D.O.S. Ver. 6.0 Anyone remember this Operating system?
And the last option is to format the drive undel LINUX and thern get it back to Windows XP.
Jan 01, 2009 | Seagate Computers & Internet
I cant install vista OS on this MBD , by sata HDD
You must enter setup at boot and select the CD/DVD as first boot. Then ensure that the BIOS settings have SATA enabled. When CD/DVD is first boot watch the screen for 'press any key to boot from cd' message is displayed. The boot screen will say how to enter setup. Typical buttons are F2, Delete, F1, F10 -you did not say which manufacturer. OEM trumps mobo maker with BIOS setup.
Oct 14, 2008 | Gigabyte GA-8KNXP Motherboard
Installation problem
Replace the hard drive with a new one. IT takes a standard IDE 2.6" laptop drive - I would try newegg.com they have pretty good prices probably about $100 for a 120gb drive.
The hard drive is under the 3x4" cover on the bottomn of the machine.
Dec 31, 2007 | HP Pavilion zd8000 Notebook
Toshiba (HDD2181) (hdd2181-50pk) 30 GB Hard Drive Logo
967 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
