Question about Car Audio & Video
Engine rotates but will not start, - Car Audio & Video
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 199 Answers
You mean cranks but doesnt start?
Check battery, fuel and spark.
Posted on Feb 12, 2008
MY 1998 CHRYSLER CONCORDE WANT START, WHEN TRYING TO CRANK IT UP, IT MAKES CLICKING NOISES, IVE BROUGHT A STARTER AND NEW BATTERY, BUT ITS STILL DOING THE SAME THING..PLEASE HELP ME
Assuming that the new starter and battery are not defective (one easily could be), the next thing to check for would be to verify that the engine is not seized up. Get a breaker bar wrench and fix it to a socket that is the size of the crankshaft pulley nut. Place the socket over the nut, and, facing the engine, attempt to rotate the crankshaft in a clock wise direction. If it turns, then the engine is not seized. If it won't turn at all, then next, remove all spark plugs and try to rotate the engine again. If it still won't rotate, you have serious internal engine issues. If it does rotate after removing the plugs, you may have had hydrolock, where gasoline fills the cylinders and won't allow the engine to rotate. If it rotates, then try to use the starter again briefly with the plug removed. Obviously it won't start, but if it rotates, you can put the plugs back in and try again, hopefully with success. If the engine is seized, unless the car itself is in mint condition, you're better off getting a new car than trying to repair this one just based on age.
Nov 14, 2016 | Chrysler Cars & Trucks
2005 chevy malibu when trying to start car smoke comes from coolant resivor wont start smells like exaust fumes. As the enine rotates smoke comes out same pattern as rotation of engine.No water mixed with...
white smoke could be head gasket leak. but white smoke will come with warm engine. If engine is first start cold. IT's only water in exhaust system
Sep 23, 2013 | 1992 Chevrolet Cavalier
Cant remember how to start my g100 wacker. Can pull the starter cord but forget where the little knobs need to be turned to
I am not familiar with your model but general rules are as follows. 1 - make sure that the gas'oil mixture is the right ratio and that the fuel is not stale. 2 - Depress the little rubber primer bulb 4-6 times, or until yor see little bubbles through the bulb. 3 - Rotate the choke lever to Full and pull the starter cord until the engine tries to start. 4 - Rotate the chole lever to Half and pull the starter cord until the engine starts.5 - After the engine warms up, rotate the choke lever to Run or Open so that the engine runs smoothly.
Jul 01, 2011 | Garden
Clicking when i turn the key
Clicking instead of starting? The clicking is usually the starter solenoid being pushed out to the flywheel. If your engine isn't turning then it means that either your battery is too weak to turn the engine or your starter has malfunctioned or maybe engine that your engine has locked up.
Recommend you either jump start the car or use a battery charger with the start function to see if it is the battery or starter/engine lock up. If the engine still does not turn over. Take off your serpetine belt and try to rotate your engine with a large socket. If the engine rotated, then it is most likely your starter/solenoid that is bad. If the engine would not rotate by hand then something inside the engine has malfunctioned and it will take some serious work to get it operational again.
Jun 27, 2011 | 1999 Chevrolet Cavalier
We got stuck in high water the other nite, the van died and we couldnt get it to start so we had to be pulled home, now the van wont start, we took the starter and had it tested, and they said its good,...
If the starter was tested outside the car's engine and it worked , thn problem now could be the engine is not free and thus not rotating and the starter therefore can't rotate it too.
Try to rotate the engine by using a box spanner at the front crankshaft pulley and see if it's rotating (the motor).
Oct 31, 2009 | 2000 Dodge Caravan
Mazda 3 will not start. Sounds like starter is spinning, but it will not fire?
i need more detailscheck if engine rotate wen attemting 2 start if not rotate check starter pinion or flyweel teeth worn or broken . remove the fly weel/driver plate access cover and inspect---------- ENGINE ROTATES BUT WILL NOT START fuel tank empty,fuel filterplugged or fuel line restricted,fuel pump faulty. check those points good luck
Oct 04, 2009 | 2007 Mazda 3
1995 dodge neon Rotates but will not start...engine code 55
Check to see if you have pulled on the crankshaft sensor and it has come away at the plug.And do the same at the coil pack.
Jul 28, 2009 | 1995 Dodge Neon
Does the engine rotate at all when trying to start, or won't rotate at all? Clicking sound?
Blown fuse somewhere?
hope this works or clarify some more.
Jun 17, 2009 | 1991 Chevrolet Lumina
My engine locked up in my siloutte
Using a socket and a ratchet/ breaker bar (socket size to get crankshaft pulley) Try rotating engine it should rotate, try to rotate 360 degrees a few times if it does the ENGINE IS NOT SEIZED. Contact if you need more help, Thanks for using FIX YA
Jan 16, 2009 | 1997 Oldsmobile Silhouette
Car Audio & Video Logo
66 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
