HP Officejet G-85 won't print. Computer seems to communicate with printer (makes noises when I send), sometimes prints part of page, then stops. Won't delete from queue until printer turned off. Recently moved, but no damage to printer, hasn't worked since.
Also, scanner says "scanner or camera is in use.
Windows XP
can i upgrade memory in hp officejet g85, for some reason it has stopped printing pictures? It use...
(More)
can i upgrade memory in hp officejet g85, for some reason it has stopped printing pictures? It use to print great pictures & now it has quit. It prints about an inch of a picture & then spits our the paper. I am using vista 64, i have tried to print in kodak easyshare, photo gallery, hp print software & gimp? Any suggestions? **** I did just submit this same question, but forgot the g85? so see repeat question
can i upgrade memory in hp officejet. For some reason, my printer will now only print the first...
(More)
can i upgrade memory in hp officejet. For some reason, my printer will now only print the first inch of a picture & quits. So I was wondering if I was having a memory issue or who knows? It use to print pictures just fine. Suddenly its sick. Can you help
Have message on screen that says scanner failure. Followed troubleshooting steps all ok. I think...
(More)
Have message on screen that says scanner failure. Followed troubleshooting steps all ok. I think problem may be in the bulb or what ever the light source is. I was copying some pappers and had open the ink door for a problem and when reclosed it wouldn't work any more and showed this error
The following is my exact problem...can it be repaired? Hard to tell if piece is broken. "My...
(More)
The following is my exact problem...can it be repaired? Hard to tell if piece is broken. "My faxes are not printing. The error message says there is a paper mismatch and tells me to remove the transparency and press enter. Problem is, I'm not using transparencies, just normal paper. Problem started when I noticed a small, clear, rectangular plastic piece in my paper tray. I think this might be the problem, but I can't tell where to reinsert the piece. Help!" from 2008 on your site. Thanks!!
I have inserted a new ink cartridge and it will not dispense the ink. I have removed all tape from...
(More)
I have inserted a new ink cartridge and it will not dispense the ink. I have removed all tape from the cartridge.
