Question about Panasonic Lumix DMC-FX3 Digital Camera
Camera is "jammed"?
None of the keys on the back of the camera are working. I can view the last picture and no others. It won't take a picture.
  • 641 Answers
SOURCE: Copy pictures back to camera for TV display
Thanks for the information.
Posted on Sep 10, 2007
  • 172 Answers
SOURCE: Panasonic TZ3 - buttons wont work
Cable connecting the back panel buttons to main board processor may be internittent. You can buy a service/repair manual from ebay that shows how to dis/assembly.
Barring this, let it drop about 4 inches to a hard service covered with two paper towels on its bottom. Doesn't have to land exactly flat. This is equivalent to giving it a rap with a semi-hard(wood/plastic) rod.
Also try pressing ******* shell around the buttons, not the button itself, while pressing button as normal.
I know this sounds a little hoakie, but this sort of treatment can cause a connection to make contact, or make a contact temporarily, indicating a connection problem of some sort.,
Posted on Apr 02, 2008
SOURCE: SCREEN AND VIEW FINDER BLANK
Is the battery dead? Try taking it out and charging it, then put it back into the camera.
Also, you can try using another battery of the same type.
Posted on Jul 18, 2008
  • 848 Answers
SOURCE: viewing pictures on camera
you might have changed some settings in your camera .......just check whether the settings are proper ......
Posted on Aug 09, 2008
SOURCE: non of the buttons/controls work. The camera turns
a ribbon inside the camera had oxidised because i had left the batteries in the camera when it was not been used. This ribbon was changed and now it works.
Posted on Oct 15, 2009
When I turn my camera on to view pictures, the red light on the camera in the bottom right corner stays on and I'm not able to view my pictures on my memory card. Can you help me identify the problem?
If one card works and the other doesn't then it sounds like you have a defective SD card. Nothing you can do about this but buy another one and toss it.
This is why you should backup all your photos off the camera and onto permanent storage media.
Sep 29, 2014 | Canon EOS Rebel XSi Digital Camera
I have a problem, trying to download pictures from the computer, and I put them in the same folder as the camera pictures, but it still won't show them, on the camera. What can I do. For now, I am...
Camera software can be set to download pictures from the camera and then delete them from the camera. Whilst this process is easy to do, the reverse is not so easy.
Most cameras connect to your computer and are treated like a drive on your computer. You can click on the photos you want copied back to the camera, right click on them and choose Send To. The last drive letter is usually your camera. If you have a built in card reader you will need to work out what the drive letter is for the card and send to that instead.
Use Windows key combinations to select multiples like holding down Ctrl and clicking to select in batches and shift click to select a whole range from the first to the last.
Jul 26, 2011 | Mustek Cameras
Hello, i have a sony cybershot DSC-S650. Expert, my problem is that when i turn my Sony Cybershot on the lens won't look at nothing, it's ust a blackscreen. Can you please help me. Thank you, My...
Make sure that the batteries in the camera are good and turn it on. Is there a light that comes on to let you know that the camera has power and is ready when you press the power button? Does that light come on and what color is it?
If the light ends up green, then you know the batteries are good and the camera is functioning properly and is ready to take a picture. If this is the case, then after you turn it on - look on the back of the camera for the focus zoom in and out buttons. Sometimes they look like a switch that you can rock right or left. Press the switch and look through the lens. Does press the switch or arrows in either direction clear up your view and allow you to see anything? Are you looking through the lens hole or are you using a small screen to view on the back of the camera? If you are looking at a screen on the back of the camera and that screen is black - it means that you dont have the exterior view option turned on in the cameras settings. Sometimes there is a button labeled "view" on the back of the camera to alternate from the exterior view screen on the back of the camera and using the lens hole view at the top. Press that key to make the view screen turn on. If this option is not turned on yet, press the menu key on the camera and use the arrow keys to scroll through the option choices until you find the image preview choices and turn this option on. Then save this choice and close the menu features to see if it comes on.
If you are not getting a power indicator light when you turn the camera on, then replace the batteries. If the light comes on and its something other then green and steady - (like red and flashing) check your camera manual to see what this indicator means. Some cameras show a red light that is flashing when you turn them on to indicate that the memory card is full. Some camera have a red light that is steady to indicate that the battiers are almost out of power and they will show a picture on the digital to indicate how much power you have left before they shut down. Each model camera is different according to the options it came with.
Jul 06, 2011 | Sony Cyber-shot DSC-W80 Digital Camera
My Panasonic DMC-LZ3 camera appears to have locked up
Make sure the scene mode dial is correctly "clicked" into a choice. You could also try this...remove the card and battery...press all the buttons...leave it alone for 20 minutes...insert the card and then the battery...turn it on.
May 24, 2010 | Panasonic Lumix DMC-LZ3 Digital Camera
Pictures say they are there but are not viewable.
Something SIMILAR happened with my Samsung S85. Your situation sounds different in that you say you can view a limited number of images (on the camera?).
I my case it had pictures on the camera, that I had deleted after down loading, from the computer interface window. They did not show up on the computer interface window when I downloaded other pictures. Eventually the camera filled up with pictures but there were none on the computer interface window.
I had to go back and delete the pictures from the camera itself - one by one.
Oct 25, 2009 | Samsung S85 Digital Camera
Canon PowerShot G2 buttons don't work
You have a bad button board . This is a single board with a series of small button switches that control all these functions. Most repair shop will charge around 75.00 to fix.
Jul 01, 2009 | Canon PowerShot G2 Digital Camera
Button don't work
One of the buttons is constant presset in.
Under the button is a metal membrame, sometimes it happens by to mutch force the membrame is defect, it doesn't popup again.
Try to find out witch button doesn feal good anymore, can you work without it ?(for example left macro), open camera and remove membrame.
LKet it repait by fuiji ? a least € 100,-.more than new....
Nov 12, 2007 | Fuji FinePix A310 Digital Camera
I can view pictures that were taken on my camera but when I go to take pictures the screen is black
Does the screen deliver anything such as menu. Or can you see ghost images if looked at from the side? If you see nothing then this is a connector issue of a circuit board failure. If you see ghost images then it a back light failure. Either way this is a return to HP situation. If under warranty via the seller if not under warranty contact HP customer support. If they are quoting money- you may find it more economic to write it off and get a new camera.
Jul 27, 2007 | HP Photosmart 635 Digital Camera
View screen sticks on view mode when switch to take picture mode
This is a button/firmware problem Canon Customer support will advise on your next move -depending on the age of the camera
Jun 28, 2007 | Canon PowerShot A75 Digital Camera
Panasonic Lumix  DMC-FX3 Digital Camera Logo
23 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
