Question about Motorola Mobility RAZR V3i Cellular Phone
My cell restarts continuosly
My motorolla v 3 i keeps starting all the time till the battery runs out
  • Anonymous Dec 27, 2007
    me too i have the same problem then suddenly my my moto hang every time i write a text message
    Brigadier General:
  • 7,752 Answers
You may have to either have the phone's firmware reflash or have the mainboard replaced
Posted on Feb 12, 2008
Cant enter pin code but the numbers 123 and a symbol are displayed above the orange area
Try to install 'Netqin Anti-Virus' via PC. Inside-Outside the battery 3 or 4 times till Netqin answers.
Apr 14, 2013 | Nokia C5 Cell Phone
Sears lawnmower kills after mowing for 10 minutes doesn't restart till rested a long time. Repair man says nothing wrong with it.
That is the symptom of a failing ignition module. With the airbox cover and air filter removed run the unit till it fails. Immediately squirt a shot of carb cleaner into the carb and try to restart. If it restarts see if you can keep it running on the carb cleaner for a few seconds. If it wont restart or stay running then its likely an ignition module. If it does restart and keeps running on hte prime then you have a fuel issue.
Other things to check: spark plugs can fail when they get hot, checkt o make sure the engine stop cable is pulling the bail off ground sufficiently. If the cable has stretched it may not pull the bail completely off ground causing intermitent spark.
Nov 17, 2012 | Garden
Keeps cutting off after restart
SINCE CAR WONT CRANK. NOW IS THE TIME TO REPLACE THE IGNITION SWITCH KEY LOCK CYLINDER ITS BROKEN THAT WHY THE CAR KEYS WOULDNT TURN OFF CAR.DISCONNECTING BATTERY CABLES WITH CAR RUNNIMG WILL.SHORT OUT ALTERNATOR AND PCM.IF IN CASE YOU HAD TO REMOVE BATTERY CABLE REMOVE THE GROUND NEGATIVE CABLE FIRST.MAKE SURE ALL ELECTRICAL COMPONENTS OFF LIKE RADIO. AC SYSTEM OFF.THIS WILL PREVENT LARGE ELECTRICAL ARC FROM BATTERY THIS IS ONE TIME PROCEDURE IN CASE ENGINE WONT SHUT OFF ITS A GAMBLE BECAUSE IT WILL TAKE OUT ALTERNATOR AND PCM.REPLACE THE SWITCH AND KEY LOCK CYLINDER DONT KEEP STARTING CAR BY DISCONNECTING THE BATTERY CABLE YOU WILL DAMAGE IGNITION ELECTRICAL SYSTEM.
Jul 31, 2010 | 1997 Oldsmobile Achieva
I have windows 7. When I shut down and then restart later or the next day the clock shows the time of shut down and then run ok but I have to reset it or click on internet sync and that works. Then the...
If this is an older PC (3-5 years or more) then most likely the backup battery on the motherboard has become weak.
On many motherboards this is a coin cell, which can easily be replaced (on others it is soldered in, though), just have a look.
Mar 24, 2010 | Computers & Internet
When i try to open it it says it is open but i can't see it= And if i start it with Run, it starts opening till i restart the pc i even have problems with restarting it because the programe keeps opening...
Power drain would be a better solution in this case.
1.first shut down the comp
2.unplug the charger
3. remove the battery
and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer .
Oct 26, 2009 | Computers & Internet
My phone 7610 is not on & restart 3times & then off !
try *+3+green key+power together un-till formatting appear on the screen
May 06, 2009 | Nokia 7610
My motorolla cell phone keeps dying with a full battery sent it back to motorolla twice.
U just avoid using Screensavers N moving wallpapers n set ur backlight time for 10 or 15 secs....
Jul 19, 2008 | Cell Phones
Phone start up failed
if it is a series 60 phone than try holding the following keys together (1);-green key(calling key)
(2);- 3
(3);- *
(4);- on\off switch
keep holding them till it shows formatting the will take some time then it will restart ur battery must be charged for this process
May 23, 2008 | Nokia 6630 Cellular Phone
Can't load Windows, constant restarts.
There could be several issues, but random restarts can be difficult to debug. For now, I'd start with the easiest and that is a memory check.
Visit www.memtest86.com and download the free bootable floppy or CD (burn the ISO file with free ImgBurn utility if you have no ISO burning application).
Boot the problem system with the floppy or CD and the memory test should start automatically. Let it run over night and see if errors are reported.
Dec 19, 2007 | ASUS P5P800 SE Motherboard
Motorola Mobility RAZR V3i Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
D. E. Hev
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
