Question about Concord Camera 3346z Digital Camera
How can i fix a memory error?it wont let me take pictures
I had this camera for a couple months and it currently contains a 16gb memory card with a few pictures on there. my camera is a vivicam f536 and when i start it up an i fix this?it says storage error and...
did you try taking the memory card out of the camera and putting it directly into your PC to download the pictures?
The other problem could be, is that the memory card was never formatted correctly. Once you get the pictures off, if possible, reinsert the memory card into your camera, and search thru the menu for formatting the memory card. I do believe that could solve your problem.
Aug 20, 2011 | Nikon D7000 Digital Camera
One of the pictures has got a file error. it doesn't allow me to delet it and once that file error happens it makes all the pictures have a file error too. so i am unable to upload pictures becuase as...
FIRST OF ALL CONNECT TO YOUR PC UPDATE YOUR VIRUS DEFINATION AND SCAN THE MEMORY TO RULE OUT ANY VIRUS.AFTER BACKING UP ALL YOUR PHOTOS FORMAT THE PHONE MEMORY AND THE MEMORY CARD AS WELL. THIS WILL SOLVE THE ISSUE.
REGARDS.
PLZ. RATE THIS
Jul 02, 2011 | Sony Cyber-shot DSC-S730 Digital Camera
Error code 0x80010108 wont allow me to view pics
This error is generally faced with Windows Live Photo Gallery when viewing pictures from external devices such as cameras or memory cards. There are different known causes to this error, among which, one is an installation problem of Windows Live, but the uninstalling and reinstalling does not seem to fix this issue.
However the solution is quite simple. You have to import your pictures from your device onto your computer through Windows Live Photo Gallery (you will have this option when device is connected in the autorun menu).
Once the pictures imported, you will be able to view them. Be careful to keep the original photos on your device in case this solution does not fix this issue.
If problem persists, I recommend opting for another picture viewer program.
May 14, 2011 | Microsoft Windows Live Photo Gallery
Memory card has a problem after taking important pictures.. displays reinsert memory stick error and wont read on computer either... any idea if photos can be recovered?
Make sure the memory contacts show up a visible clarity. If there is no detection in any of the card readers, inthe camera and inthe PC, it seems likely that your card has some errors on it,
If the card is detecting the memory but is not showing any pictures, the use a file search in the search mode with the drive selected for pictures/images.
If not it will be best to have it checked with a photo studio to concur the findings since you have important images on it.
Sep 23, 2010 | Sony 4GB Memory Stick PRO Duo Memory Card
MicroSD card has "fatal errors"
hi i have a 4GB microSD memory card in my blackbery and it started not reading properly not it says the memory card cannot be accessed due to fatal errors i now cant access nither pictures oe music on it can someone please help me
Jan 08, 2010 | SanDisk 8GB microSDHC Memory Card with...
How do u fix the memory card? it wont save videos
format the memory card and make sure you have your phone set to save pictures to the card and not the phone.
Jul 30, 2009 | Nokia E63 Cell Phone
Memory card error
Take the card out of the camera, and re-insert it. See if you get the same error. If so, it has likely been corrupted. Reformatting it may correct the error, but you will lose whatever was on it, unfortunately.
(Also, if you have another reader, like what most PC's have on the front of them, give it a shot - there's a chance it's the camera, and not the card.
Cheers
Nov 02, 2008 | Kingston flash memory card - 256 MB -...
Memory card error
try formating.
but u may lose the data
also see that u format through sd utility available on sd.com
if still a issue than get free replacement by kingston as it has 5 yrs warranty
Jun 21, 2008 | Kingston flash memory card - 256 MB -...
Memory Error
I had the same problem but fixed it by following the camera's directions to re-format the SD memory. You will lose all pictures on the memory card so remember to first save your pictures to your computer. Good luck.
Nov 16, 2006 | Vivitar ViviCam 3785 Digital Camera
Concord Camera 3346z Digital Camera Logo
22 people viewed this question
Top Concord Cameras Experts
Ron Dufek
Ron Dufek
Robert McCord
Robert McCord
Are you a Concord Camera Expert? Answer questions, earn points and help others
