Question about Microwave Ovens
My microwave made a pop sound and then stopped heating. It also had a bad smell when you opened the door.
    President:
  • Microwave Ovens Master
  • 1,922 Answers
Your windings on the hi-voltage transformer are shorted and beginning to arc, a new transformer $125-$175
Posted on Oct 13, 2009
Why does my microwave turntable turn when I open the door?
We recommend you have the microwave evaluated by an authorized service center.
Authorized service centers can be located in the below link.
www.panasonic.com/repair
May 01, 2014 | Panasonic NN-H965WF - Microwave Oven...
Our microwave has stopped working for the second time in two years. When you try to heat something, it hums but not quite like it is heating. There is also a funny smell.
SAFTY FIRST
UN -PLUG IT,,,,, THAT "FUNNY SMELL" SOUNDS LIKE IT IS SHORTING OUT
PERHAPS THE MEGATRON HAS GONE BAD, THE MEGATRON IS THE
HEART OF ANY MICROWAVE
AS A EX- FIREMAN, I KNOW FROM FIRST HAND EXPERIENCE THAT
"A FUNNY SMELL " OR " UN-USUALL SMELL COMING FROM AN ELECTRICAL
ITEM IS A SIGN OF DANGER
Feb 05, 2011 | GE Profile Spacemaker JVM1871 Microwave...
Making a new noise and smells of something electrical shorting out and does not heat what is placed in to it to heat.
The problem is in the magnetron it has stopped working, if you open the microwave oven door sometimes you can smell what can only be described as an ozone smell and signifies the part in question. It is best to buy new "cheaper" than have it repaired "more costly"
Jan 15, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Louder and not heating
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101'['[//'[
Apr 27, 2010 | Jenn-Air JMV8208A Microwave Oven
Microwave made a pop sound and stopped heating. It also had a smell of something burnt.
either the h.v diode,h.v capacitor or the mag tube is defective,chk diode first
Oct 06, 2009 | GE Profile Spacemaker Over-the-Range...
Russell hobbs combination microwave oven (HOB CJ/AL28).The plate inside my microwave no longer rotates and also the light has stopped working to, it is only a year old!Also when it gets to hot its turns...
This is usually caused by either a bad door switch or a loose door switch mount, which are pretty simple problems to fix.
It sounds like the switch is not activating properly, and the inside light, turntable and magnetron cooling fan are not coming on.
If the magnetron runs without the cooling fan, it will overheat and its thermostat will interrupt the power to the oven until it cools back down.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
Nov 30, 2008 | Microwave Ovens
Constant humming sound
the most common problem with ALL microwaves is the magnatron
Dec 29, 2007 | Samsung SMH7178STD Microwave Oven
Emerson Model MW8627W does not heat after changing fuse!
check the magnitron and capacitors one of this is bad
Sep 18, 2007 | Emerson MW8627W Microwave Oven
Microwave suddenly stopped working
Code F3 indicates an open / defective thermistor / temperature sensor. The first suspects when a microwave is not heating would be the door switches, bad connections on the magnetron terminal or bad connections on the control board. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Jun 25, 2007 | Kenmore 61652 Microwave Oven
Home Circuit Breaker Pops When Door Is Opened
It does sound odd for it to blow the breaker. It should blow the fuse, not the breaker. But looking at the exploded view diagram, I don't even see a fuse! Makes me wonder if this is some foreign model. *grin* In any event, you will need to replace all the door switches since they all have been stressed by the same overcurrent. Also be sure that all the switch mount and door latch parts are activating properly when you open and close the door. The switches (generic replacements) are widely available from local appliance parts stores. If you need any other parts, you can see an exploded view and parts list here: http://www.geappliances.com/shop/prts/
Dec 16, 2006 | GE JE2160 Microwave Oven
Microwave Ovens Logo
53 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
