Question about Air Tools & Compressors
Need to know what compressor oil to use for 185 ingersoll rand compressor
  • 37 Answers
I use NAPA's hydraulic/transmission oil part # 85 405 which is a 20 weight oil in my Ingersoll Rand 185.
Posted on Feb 17, 2014
  • 54 Answers
Use Ingersoll Rand Pro-Tec fluid only. It hold 3 gallons. If you have a sight glass on the receiver tank do not fill it over 1/2 way up.
Posted on Nov 19, 2009
  • 6,826 Answers
The parts store,napa sells a air compressor oil that is compatible,It is called simply,air compressor oil.It is made just for compressors.
Posted on Oct 06, 2009
2 Suggested Answers
  • 104 Answers
SOURCE: compressor oil
PLease contact IR http://www.irtools.com/serviceandsupport/techpubs.aspx
and direct this question to them. You do not want to make a mistake here as it will cost you a compressor. I would only accept what IR says is acceptable
good luck
Posted on Mar 17, 2009
What level does the coolant need to be in the sight glass?
About 31,000 results (0.83 seconds) Search Results
    [PDF]IRM-G-8780 2-25hp US - Ingersoll Rand Air Compressor
    www.ingersollrandproducts.com/...
    Ingersoll Rand Industrial TechnologiesIngersoll Rand compressors are not designed, intended or approved for breathing ...does not approve specialized equipment for breathing air applications and ... unmatched service to meet your needs. ... drain, and low-oil-level .... Oil Sight Glass ... Value Package (5, 7.5, 10 & 15hp) An economical choice in a dependable ...
    [PDF]Owner's Manual - Air Compressors Direct
    www.aircompressorsdirect.com/.../irmanual2340_2475_2545_7100_15t...
    installation, operation and maintenance of your Ingersoll-Rand air ... An air-cooled aftercooler, low oil level ... for Models 2340, 2475, 2545, 7100, 15T & 3000 ... Ifcooling of the discharge air is required, .... motor does not have this button and the unit does not have a ..... l Drain compressor oil and clean oil sight glass.
    [PDF]XF 7.5 - 15 EP 7.5 - 15 HP 7.5 - 15 XP 7.5 - 15
    diagramasde.com/.../Manual%20comp%20ingersollrand%20SSR-15.pdf
    EP 7.5 - 15. HP 7.5 - 15. XP 7.5 - 15 ... The Ingersoll-Rand Company Rotary Screw Air Compressor that has been filled prior to its ... after shall have its AIREND warranted for twenty four (24) months from the ... comes first, when using ULTRA COOLANT.Coolant ...... check coolant level in the sight glass on the separator tank.
    Ingersoll Rand Air Compressors - About Air Compressors
    www.about-air-compressors.com/Ingersoll-Rand-air-compressors.html
Feb 08, 2016 | Ingersoll Rand 15 Horsepower Rotary Screw...
Where is oil cooler
Hi not totally familiar with this compressor but the oil cooler will be in front of the air intake vents with the cooling fan behind it
Mar 07, 2014 | Ingersoll Rand P185WJD Platinum Series Air...
Fire in coalescer filter
high airend discharge temp oil level to low or no cooling taking place
Mar 03, 2014 | Ingersoll Rand Rotary Screw Compressor ...
Throwing out oil at ingersollrand air compressor
Need more info . Where does oil appear to be coming from. what's the model and serial #.
Nov 17, 2011 | Ingersoll Rand Rotary Screw Compressor ...
What type of oil for ingersoll rand model 2475 air compressor could not find specs at Rand website
Ingersoll Rand likes you to buy their all season select oil for their air compressors, most piston air compressors use an R+O 100 oil it is equivalent to n SAE 30 wt oil.
May 10, 2010 | Ingersoll Rand - Rand Type - 30...
I have a Ingersoll Rand P185 WJD air compressor and I need to know the type and quantity of oil to use.
Do not use 30 wt oil. It will wreak the oil/air seperator filter. Use Ingersoll Rand Pro-Tec fluid. It will hold approx 3 gallons.
Nov 03, 2009 | Ingersoll Rand Air Compressor Maintenance...
My rotary screw air compressor model SSREP100H
It's just too hot. Blow out the radiator weekly. There is an oil temp switch that might need replaced but the radiator is the most common problem with screw compressors. You can check the settings in the control panel, where you turn it on and off. It should be set for a high temp of 185°.
Aug 08, 2009 | Ingersoll Rand - Rand Type - 30...
Compressor oil
good luck
Mar 06, 2009 | Air Tools & Compressors
Air Tools & Compressors Logo
1,276 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
