Question about Hussmann Commercial Freezer DCCG-8-D
Need to replace my dipping cabinet flip lid on hussmann dc 8. where can I find one?
3 Suggested Answers
refritech08
  • 149 Answers
SOURCE: REPLACEMENT PARTS
heres the address and phone numbers to contact them
5 Cherry Blossom Rd. Unit 3
Cambridge ON, N3H 4R7
Phone: 519-653-9980
Fax: 519-653-1805
Toll Free: 1-866-764-0468
probably tech support could help you to find a parts distributor.
Posted on Apr 23, 2008
  • 5370 Answers
SOURCE: kelvinator dipping cabinet holds 8
Check the thermostat setting.It must be set on low cooling or its not functioning properly and not cooling complete unit.The thermostat is located on the server side of the cabinet, directly behind the service grill. It functions to control the temperature inside the cabinet.If you notice cooling problem, check thermostat setting, if its set ok, then its faulty thermostat. ---------- Also it can be the issue of low refrigerant in compressor or weak compressor. ---------- Also see if the condenser coils are got very dirty, if yes clean the coils with brush and dry cloth.
Periodic cleaning of the condenser can be easily accomplished by brushing the coils with a soft brush and/or using a vacuum cleaner with a brush attachment. Be sure that dirt, dust and collection of other debris do not build up to a point air circulation through the condenser is restricted.
---------- Also see if the storage compartment door is getting properly closed, if not then there will be cooling problems. ----------- This should be checked, to confirm the problem.Thanks.Helpmech.
Posted on May 23, 2011
Old (!) freezer needs to be cut up to be removed from basement
you need to call someone (hvac company) to recollect it legally. they'll need to install a pierce valve and **** it out to collect it. it's illegal to let it out yourself. 1800 junk might do it for a small fee.
Aug 05, 2009 | Hussmann Freezer Gelato Pan Rack (For 18...
Bed room door locked
Take a credit card and slide it around the door latch. Slightly pull on the door as your are doing this and it should release itself. Gently push the card and work it into the latch at a slight angle. Let me know if this works.
Feb 18, 2009 | Hussmann Freezer 12 Facing Straight Glass...
Low suction pressure high head pressure
That system has a restriction. Most common at TXV valve or capillary tube. Will need to be replaced by Refrigeration company. In this video I replaced TXV valve and filter drier due to the same issue You have. Its Ice Machine, Low side was at 5 PSI, High at 250PSI : 404A; should be around 55-65 Low; 250 -275 High. Replaced drier and TXV, machine works proper.
May 19, 2008 | Hussmann Freezer 12 Facing Straight Glass...
REPLACEMENT PARTS
Phone: 519-653-9980
Fax: 519-653-1805
Mar 19, 2008 | Hussmann Commercial Freezer DCCG-8-D
Bedroom door sticking
Did you install the doors or a contractor? Sounds like the doors are not fitting the opening properly
Oct 20, 2007 | Hussmann Freezer 12 Facing Straight Glass...
Hussmann Commercial Freezer DCCG-8-D Logo
88 people viewed this question
Top Hussmann Freezers Experts
Dennis Boxerman
jasbo
jasbo
John Tripp
John Tripp
Are you a Hussmann Freezer Expert? Answer questions, earn points and help others
