Question about Kenmore Ovens
F1 error code on 790 model range
Hi, I had the F1 code on my 790 range. Unplugged it. Now no code but no heat in bake or broil. The temp sensor RTD read about 1080 ohms at room temp.
  • 813 Answers
Electronic oven control fault
Posted on Dec 09, 2011
I have the same issue. Anyone want to chime in?
Posted on Nov 02, 2009
I have a Whirlpool drop in stove. I had food in the oven baking and all of a sudden the timer started going off. F-1 was displayed on the front of the stove. Can you tell mean what F-1 means?
F1 - Control Board Failure - Replace control board (clock).
F2 - Oven Temperature Is Too High - Check for welded contacts on bake and broil relays. ...
F3 - Open Oven Temperature Sensor (RTD) - Replace oven temperature sensor (RTD).
F4 - Shorted Oven Temperature Sensor (RTD) - Replace oven temperature sensor (RTD).
Whirlpool Google Search
Dec 15, 2016 | Whirlpool Ovens
Tip
Whirlpool oven, stove and range fault codes (ERC and EOC display errors).
Here a list of Whirpool oven fault codes. The codes had been collected from different service manuals. This was a memo that I wrote for my own use. I think this can be useful to owners and technicians.
WHIRLPOOL - most models
Range/Stove and Oven Fault Codes, Common error codes.
F1 - Analog control board Failure
Disconnect for one minute - if error comes back, replace control board
F1 - Shorted control keypad
Replace keypad
F3 - Oven temperature sensor open
Replace oven temperature probe
F2 - Oven temperature sensor shorted
F3 - Oven too hot
F3 - Clean temperature too hot
Replace oven probe
F5 - Door latch switch fault
Test and replace the door switch.
Whirlpool with 4 Digit Failure Code:
F1 - E1 - Electronic control (flip flop)
F2 - E0 - Shorted control keypad
Replace keypad
F3 - E0 - Oven temperature probe open
Replace temperature probe
F3 - E1 - Oven temperature probe shorted
F3 - E2 - Oven temp too high
F3 - E3 - Clean temp too hot
Replace temp. probe
F5 - E0 - Check door latch
F5 - E1 - Check door latch
Replace switch if defective
WHIRLPOOL Polara models 5 digit codes:
F1 F0 - EEPROM communication error
Replace ERC
F1 E1 - EEPROM checksum error
Replace ERC
F1 E2:7 - UL A/D errors
Replace ERC
F1 E4:2 - Model ID error
Reinsert keytail.
F1 E6:0 - Latch signal mismatch error
Replace ERC
F2 E0:4 - Shorted key error
Replace keypad assembly
F2 E1:3 Keytail unplugged
reinsert the keytail
F3 E0:5 Top oven sensor open
Test and replace top probe.
F3 E1:6 Top oven shorted
Test and replace temp probe
F3 E2:9 Bake range over temperature
F3 E3:8 Clean range over temperature
Test and replace temp probe.
F3 E4:10 Bottom oven sensor open
F3 E:15 Bottom oven sensor shorted
F5 E0:14 Door switch errot
Test and eventually replace door lock switch
F5 E1:16 Door latch not operating
Test and eventually replace door latch
F8 E0:17 Refrigeration error
Test the cooling module.
PF Power failure - Does not indicate a fault.
PF occurs when power is disconnected.
WHIRLPOOL
Models SF3, 30'' and 24"
F2 - Oven temperature above specifications
Check 8-pin connector from temp. probe to Electronic Oven Control
F3 - Open oven temperature probe failure
Check wiring, replace oven probe if necessary
F4 - Shorted oven temperature sensor failure
Check wiring harness, replace oven temperature probe if necessary
F5 - Push button stuck or faulty
Check for binding of pushbuttons and control panel glass. If OK, replace touch panel
F6 - Electronic control logic error (timing)
Replace Electronic Range Control (ERC)
F7 - Electronic control logic error (lock motor)
Replace ERC.
F8 - Electronic control logic error
Replace ERC.
on Jan 31, 2010 | Whirlpool RBS305PDS Electric Single Oven
Why kenmore oven code f-10 comes on when bake or broil is on
I would first pull your range out from the wall, unplug your range, then take off the back access panel and ohm your oven sensor.
It should ohm out at 1100 ohms at room temperature.
If that checks good, then your control board is the problem.
Here's the oven sensor probe for your model:
Part#316217001show?id=yo6223wzsty&bids=122738.613159039&type=10&subid=
yNjEzL0lDVy9zb3RvaHB0cmFwLw%3d%3d">
Here's your control board:
Part#316418208show?id=yo6223wzsty&bids=122738.582384825&type=10&subid=
0NjEzL0lDVy9zb3RvaHB0cmFwLw%3d%3d">
Aug 20, 2014 | Ovens
Whirlpool wall mount oven won't heat at all. Error code E3 F1
Technical sheet says all F1 codes to replace control
Jan 17, 2014 | Whirlpool Ovens
Ov en will not heat up. no broiler heat or bake heat model number 790.96614407
Your symptoms point to a failure in the electronic oven control board (that acts as the thermostat for the oven in this type of range). Unplug the range and remove the upper back panel to access this component. You will likely see to burn marks on the control board. The control board will need to be replaced in this situation.
Before installing the control board, I recommend that you check the bake and broil elements. Look for damage on both elements. Remove the lower back panel (with the range still unplugged ) and check the wiring connections on both elements. A damaged or shorted bake or broil element could have caused the problem with the control board.
Hope this helps.
Shane
Mar 01, 2011 | Kenmore Ovens
I have a magic chef range. I ran the self cleaning on the range. Now when trying to use the oven I get a F1 and a F3 code. I unplugged it for a while to reset and still have the same problem.
F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information. F3 or F4 Shorted or open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Nov 25, 2010 | Magic Chef Ovens
My oven when turned on goes to F1 and the heat is like broil...only the top burner comes on????
Hello,Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacement of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal check sum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Thanks
May 28, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore electric range - oven temp low and takes forever to heat
if lower element tests open with continuity meter then it for sure is bad. i would also check the wire ends that connect to the element and/or the control board, they could have loosened allowing a bad connection and low voltage to elementor burnt off.. most ovens do not use the broil element at all during the bake cycle, only during the broil cycle.. some however do utilize the broil element during baking, but at a lower wattage or something..
best of luck,
ttfn
Oct 25, 2009 | Kenmore 30169 Electric Single Oven
Kenmore oven model # C970-555331
Here's a simple explanation of what's going on and how to troubleshoot:
The F1 code indicates that:
a. The electronic range control (ERC) is sensing heat in the oven when in a time-of-day (i.e., not cooking) mode.
b. The ERC is receiving information to run multiple heat functions simultaneously.
Although different components (depending upon the model) could generate the code, simple and straightforward testing using your ohm meter is all you gotta do to test for it.
1. Check the oven temperature sensor. The oven sensor has to be within spec or it will cause the F1 code.
As an example of being out-of-spec, the ERC will generate an F1 fault code when the sensor shows 1650 ohms during a time-of-day mode.
This is equivalent to 350°F in the oven.
The resistance isn't high enough to generate an F2 code (runaway temp) or an F3 or F4 code (shorted/open sensor circuit).
The ERC monitors the sensor circuit after a heat cycle and expects the resistance to drop back to 1050-1100 ohms.
The fault code is generated when this doesn't happen. Checking the sensor circuit means also checking the harness,
harness connections and the sensor itself.
2. If the oven sensor circuit checks okay, then turn your inquisitive eyeballs to the touchpad.
If the range has a separate touchpad/keyboard, the keypad may have moisture that is shorting several circuits simultaneously.
If the F1 code is given immediately (instead of during or after a heat cycle),
remove the ribbon connector from the touchpad to the ERC after clearing the F1 code. If the F1 code does not return in five minutes,
then cast a suspicious gaze upon the touchpad/keyboard. Shorts may be caused by using an ammonia-based glass cleaner.
The touchpad surface will absorb ammonia-based cleaners that are sprayed directly on the glass surface. When heat is applied,
the surface material can break down causing shorts.
If you're gonna use ammonia-based cleaners on your control panel, then you should spray it on the rag and then wipe the touchpanel
-don't spray directly onto the surface of the touchpad.
3. On Amana ranges with a rotary temperature dial, be sure that the knob is in the OFF position when performing tests.
4. If these tests all check good, then replace the ERC.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 18, 2008 | Kenmore 47834 / 47832 / 47839 Electric...
Ovens Logo
406 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
