Paper got caught in printer. I pulled it out but it keeps telling me it's stuck in the printer and it won't print.
  • Bill Schilz
    Bill Schilz May 11, 2010
    Have you turned your printer on and off? When you pulled the paper out, is there a chance that a corner stuck in the feed assembly and you didn't get it all?
  • 76 Answers
Unplug your printer and plug it in again,or your sencor in printer is broken or actuator is stuck
Posted on Oct 06, 2009
Paper won't come out paper light blinks
I have a similar printer. Sometimes the bottom paper tray gets stuck or caught. Make sure the printer is on a flat surface.
1. Turn off the printer.
2. Pull the paper tray all the way out.
3. Take out all the paper and then place the tray back in.
4. Turn the machine on and let it try to print without paper.
5. When the light comes on add paper hit the button and you should be good to go.
Jul 26, 2011 | Brother HL 2140 Laser Printer
Paper gets stuck pulling through the top nornam
That is Fuser problem.
Check if the exit sensor actuator is
defective.
• Check if the actuator exit is
deformed (Check if the lever part
is deformed in shape).
• Check whether burrs occur in the
assembly part of the actuator exit
or not and if the actuator is
smoothly operated.
• Check if foreign matter and wire
get caught in the actuator exit's
operation.
Oct 02, 2010 | Samsung ML-2851NDR Laser Printer
Paper feed problem
Hi
This is happening due to paper jam on the gear or roller of the paper feed mechanism. Check for any small bits of paper or sheet stuck. To check lift up the top plastic lid of the Canon printer. Check to see if a jammed sheet of paper is visible inside the printer. Remove the cartridges and check for any small paper bits stuck under the print head. Pull the paper out gently through the bottom end of the printer(if any). Close the top plastic lid. Power On the printer and check.
If it doesn't work then power off the printer, wait 10 seconds and power it back on. try once again to print. If it doesn't work then Open the Canon printer software. Click "Options" and then select the "Clean Print Heads" button.
Daniel Scott
Jun 14, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
Trying to fax out something and it keeps telling me jammed
Open up the cover over the adf feed. Make sure there's no paper caught in the mechanism. If I recall correctly (don't have one in front of me), the rollers can be lifted out of this one. Try this and make sure you didn't miss anything. DO NOT FORCE IT. If the rollers don't snap out with only a little pressure, seek another way to pull them out, or perhaops I was incorrect.
If there's no paper, you probably have a stuck or broken sensor flag. The feeds use these flags to detect the presence of paper, so if it's stuck, it's detecting paper when there isn't supposed to be, so the printer thinks you're jammed. If you see the flag and it appears to be stuck, use a stretched paper clip to get it back in place. Again, DO NOT FORCE IT, or you could bereak the flag or the sensor.
If the flag appears to be broken, then you will have to call HP if the unit is in warranty. They do not allow ASPs to work on inkjet printers in warranty and you have to return the unit to them. Often, they will cross-ship you a replacement. Call 1-800-HP-INVENT
Jun 25, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Paper jam
You have a piece of paper stuck in one of the switches that tells the machine you have a paper jam. One of the worst things to cause these are printing peel off labels as they sometimes peel off while printing and get caught in the mechanim. You have a jam it's just not a full size piece.
Jun 01, 2009 | HP LaserJet 3030 All-In-One Printer
HP 3210 getting paper jam because label stuck on roller.
I ran heavy card stock through printer several times, it caught the label and pulled it out on the paper eventually.
Feb 04, 2009 | HP Photosmart 3210 All-In-One InkJet...
Paper jam
Pull out power cable and, disconnect priter from power outlet, put cable back in.
If you still have led on after this, open all doors and check again fo intrusion. Pull out paper tray and check that there isnt a paper sheet stuck underneat the printer.
Open front door, pull out toner and chech under toner, put toner back , restart and try.
Open back door and check if there is a second paper sheet stuck inside
regards.
Mar 21, 2008 | Samsung ML-2550 Laser Printer
R265 chewing paper
Suggest a small piece of paper or dirt is stuck in the print path near the print heads. Use vacuum tube to **** out any dirt
Mar 19, 2008 | Epson Stylus R265 InkJet Photo Printer
Paper jam 580
You know what I would try, look in the fuser unit and see if any paper ripped off and got stuck in there. Wait until it's cooled down, but usually if you have to pull paper of of there, little pieces can get caught in there. Also, you may have a full sheet in there, I've had people leave and entire sheet in the fuser all scrunched up and the machine print fine for another 100 prints and then have an error and the paper coming out looking like it almost caught fire.
That's where I would look first if there isn't anything in the print path under the toners, etc.
Oct 27, 2007 | OKI C5100n Laser Printer
Printer errror!
From looking at the online manual, http://pdf.textfiles.com/manuals/FAXMACHINES/Brother%20Printers%20Intellifax-5750%2033.6%20Plain%20Paper%20Fax.pdfthis seems to indicate that there may be something stuck in the printer paper path somewhere. It mentions a paper clip... A small piece of paper, any foreign object could be caught . Another possibility is that a sensor is either defective, or, if a mechanical (like a switch) the lever which activates the switch might be either jammed, bent, broken, making the system sense an error, when actually there isn't one. You should take a very careful look inside the printer, using a good light to help look in the paper path for some abnormality. Maybe you will get lucky and find!
May 24, 2007 | Brother MFC 8300 Laser Printer
24 people viewed this question
jasbo
jasbo
