Question about Electronics - Others
2002 coleman utah wiring diagram pop up black/red wire shorted to ground
fridgetech
  • 473 Answers
SOURCE: Jenn-Air JED8430 Electric wiring confusion
On Cooktop From Box
Black to Black
Red to Black w/red stripe
White to Ground
Green to Cooktop frame
Posted on Nov 16, 2007
SOURCE: Wiring diagram needed RV rooftop coleman
Motor1258,
Thanks for the response, to be more specific, the nine pin connector was damaged, but I was able to connect the wires back to main unit panel. I am ready to hook to the hunter thermostat and do not know which wires to connect to. This is my problem and I do not want to short something out. Hope this helps, I want to get it installed again. Thanks again for caring....Jerry
Posted on Aug 16, 2008
  • 360 Answers
SOURCE: Install a single pole light dimmer
House wires are for a 3 way switch, you will need a different switch
Posted on Jan 31, 2009
  • 8 Answers
SOURCE: pool motor wiring
First and foremost, you need to check the Motor's voltage requirements, and match it to the voltage of the GFI you have connected to the House current.
The best way to do this is to use a volt meter at the GFI receptacle. Although it's likely the voltage at your GFI receptacle is 120Volts AC, you shouldn't guess on this. If you know what circuit breaker this GFI is using to get power.... you may be able to determine the GFI's voltage if you know how to distinquish between a single pole breaker and a two pole breaker (120Volts is derived from a sigle pole breaker, 240volts from a two pole breaker-which is twice the size of a single pole breaker).
Now the Motor: Most common Pool Motors are dual winding motors, on which, the voltage requirement could be changed to match the voltage supplied. On such a motor, there's a compartment where the cord is attached. Within this compartment, there's a configuration of screws or terminal points, and a related schematic which depicts the proper connections for each of the voltage options. By following these schematics, you will know how to connect the motor based on the available voltage supplied by your GFI protected receptacle.
Posted on Mar 23, 2009
  • 5 Answers
SOURCE: Palomar 150watt bi-linear amplifier for c.b. radio-SHORTED
turner dm 7800 base mic wires came away from the ciciut board where do they go? black and white can you help.
also wiring for astatic d104-m6b mic to lincoln can you help please
Posted on Aug 04, 2009
2002 nissan sentry xe radio wiring color code
2002 Nissan Sentra Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Pink
Car Radio Switched 12v+ Wire: Blue
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Red/Green
Car Stereo Dimmer Wire: Red/Yellow
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Blue
Right Front Speaker Positive Wire (+): White
Right Front Speaker Negative Wire (-): Black
Left Rear Speaker Positive Wire (+): Light Green
Left Rear Speaker Negative Wire (-): Violet
Right Rear Speaker Positive Wire (+): Blue
Right Rear Speaker Negative Wire (-): Pink
Oct 18, 2016 | 2002 Nissan Sentra
Need diagram on wiring harness for 2002 ford f150 showing ground wires and wiring for starter/celanoid can you help?
If you need it for the truck car radio then some of these sites will help you. http://www.fordf150.net/forums/viewtopic.php?t=68020 http://www.modifiedlife.com/2002-ford-f150-truck-car-radio-wiring-diagram/ And from what i understand this is the wiring: Car Radio Battery Constant 12v+ Wire: Light Green/Pink
Car Radio Accessory Switched 12v+ Wire: Black/Violet
Car Radio ground wire: Black/Green
Car Radio Illumination Wire: Light Blue/Red
car stereo Antenna Trigger: Blue
Left Front Speaker Positive Wire (+): Gray/Light Blue
Left Front Speaker Negative Wire (-): Tan/Yellow
Right Front Speaker Positive Wire (+): White/Light Green
Right Front Speaker Negative Wire (-): Dark Green/Orange
Left Rear Speaker Positive Wire (+): Orange/Light Green
Left
Rear Speaker Negative Wire (-): Light Blue/White
Right Rear Speaker Positive Wire (+): Orange/Red
Right Rear Speaker Negative Wire (-): Brown/Pink
I put a lot of work into this answer so i hope it helps. If it doesnt then contact me and i will get it right for you but this should be the correct diagram.
Jun 29, 2011 | Ford F-150 Cars & Trucks
2002 mercury cougar stereo wiring schematic
http://www.modifiedlife.com/2002-mercury-cougar-factory-radio-wiring-diagram/
2002 Mercury Cougar Factory Radio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Orange/Black
Car Radio Accessory Switched 12v+ Wire: Yellow/Green
Car Radio Ground Wire: Black/Green
Car Radio Illumination Wire: Blue/Black
Car Stereo Dimmer Wire: White/Green
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): White/Black
Left Front Speaker Negative Wire (-): Gray/Black
Right Front Speaker Positive Wire (+): White/Red
Right Front Speaker Negative Wire (-): Gray/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): White/Violet
Left Rear Speaker Negative Wire (-): Gray/White
Right Rear Speaker Positive Wire (+): White
Right Rear Speaker Negative Wire (-): Gray
Hope this helps
Ray
Mar 14, 2011 | Car Audio & Video
Need wiring diagram for 2002 dodge ram radio/cassette player What color is hot and ground wire
2002 Dodge Ram 1500 Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Red
Car Radio Accessory Switched 12v+ Wire: Red/White
Car Radio Ground Wire: Black/Dark Green
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: Orange/White
Car Stereo Antenna Trigger Wire: Yellow
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
Jan 03, 2010 | Car Audio & Video
Need wiring diagram for a 2002 mustang Mach 1 radio. radio is hooked up and working but not the bottom door speakers . need to know what color the bottom door speakers are left and right and + & -
2002 Ford Mustang Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Purple/Light Blue
Radio Switched 12V+ Wire: Black/Pink
Radio Ground Wire: Black/Light Green, Black
Radio Illumination Dimmer Wire: Light Blue/Red
Radio Antenna Trigger Wire: Orange/Light Blue
Left Front Speaker Wire (+): Orange/Light Green
Left Front Speaker Wire (-): Light Blue/White
Right Front Speaker Wire (+): White/Light Green
Right Front Speaker Wire (-): Green/Orange
Left Rear Speaker Wire (+): Gray/Light Blue
Left Rear Speaker Wire (-): Tan/Yellow
Right Rear Speaker Wire (+): Orange/Red
Right Rear Speaker Wire (-): Brown/Pink
Nov 25, 2009 | 2002 Ford Mustang
Coleman Patio Heater wiring
This must be a top secret heater design. Coleman is dwfinately of no help. The whites go to the ignitors or the output of the spark generator. The black is generaly a ground. Good luck.
May 30, 2009 | Coleman 5040-761 Open Flame Patio Heater
Installing FUH cealing heater used 10-3 wire
If you use the white wire as a hot wire, you must identify the wire as being a hot wire at the breaker panel and the unit. The white
wire must be marked about 6 inches back from the terminal
connections with black paint or wrapped with black insulation tape.
It would be easier to use the red wire, since most electricians would identify it as being a hot wire
Jan 09, 2009 | Fahrenheat Ceiling-Mount Industrial Heater...
Motor1258,
Jun 17, 2008 | Coleman Mach III Air Conditioner
Wire codes
Usually power is the wire that is solid colour. The ground or NEG- wire has a trace on it
Feb 18, 2008 | Car Audio & Video
Electronics - Others Logo
373 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
