Question about KitchenAid KHMS155LSS 1000 Watts Microwave Oven
F3 CODE GE MICROWAVE BEEPING
  • KitchenAid Master
  • 9,047 Answers
F3 on a GE / Hotpoint microwave means you have a shorted membrane keypad.
If and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.
So until it is repaired, please leave it unplugged or leave the door open when it's not in use, and please do not leave it running unattended.
FixYa is currently not notifying us when my Clarification Requests are answered, so please contact me directly with your full model number from the tag on / in the unit so we can help you with free do-it-yourself tips and/or an estimate.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Oct 06, 2009
My GE Microwave JES1344SK is showing the code -F3- on the digital screen and it beep three times every 30 second, the microwave won't start and any of the fuctions is working I need some help on t
An F3 code means that the touch pad has a short. The touch pad needs to be replaced. If you purchased the microwave new, get your receipt and the unit serial number and contact GE for the repair (1-800-GE-CARES). See http://repair.geappliances.com/ to find a repair center near you. There is a one-year parts and labor warranty on this part. You will need to get the unit to the GE Repair center at your own expense. (I'm assuming that the unit wasn't shorted by a lightning strike or other disaster.)
I hope this helps.
Jan 02, 2012 | GE JES1344SK Microwave Oven
F3 and beeping on my GE spacemaker 1800 microwave oven...what causes this?
F3 is the code for a failed membrane keypad.
On most of these GE models, the keypad is not available as a separate part.
So you'd have to order so you would have to order the control panel frame assembly which comes with a new keypad.
In this case, you simply move your circuit board into the new frame.
That is a simple do-it-yourself job.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you unplug the keypad (as per the photo below) and move the circuit board into your frame.
Some connectors on the relays have a lock:
Nov 27, 2011 | GE Microwave Ovens
The microwave is beeping at intervals and is flashing an F-3 Last night the vent was running full force and the beeping was going on too - I unplugged it but it didn't fix the problem
The error code of F3 on the GE microwave oven indicates a shorted keypanel/keypad.
Most likely the keypad will have to be replaced to fix your problem.
Mar 10, 2011 | GE JVM3670 Microwave Oven
Ge psacemaker microwave oven no working it started with a sensor error and the message change to F3 and beeping. I unplug and plug its still same error.Model JVM1750. What does F3 message stands for?
F3
Key panel (touch pad) shorted This code will occur if a shorted key panel is detected
continuously over 60 seconds. Replace key panel (also called touch
pad).
Dec 19, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave display flashing & beeping.
You have a failed membrane keypad.
On this model, GE doesn't make any parts available except the tray and the roller.
If it's in warranty, they will exchange or repair it.
It it's out of warranty, you're out of luck.
I'd advise you to contact GE Customer Service in case they may be able to help you.
Jul 25, 2010 | GE JES1036PWF 1100 Watts Microwave Oven
My ge spacemaker XLl800 starts beeping and then shows F3 code
possible magnetron failure, check for short in high voltage and remove mag and inspect
Feb 04, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
The unit is beeping and has a code showing F3
Is it difficult to change a touch pad on my ge profile eterna spacemaker microwave. F3 Error, Bought it new in 2006. Touchpad Part No# WB07X10959 Twinsinger asked.
Feb 03, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Spacemaker beeping loud and f3 message driving us crazy
The error code F3 indicates an oven sensor problem. The oven sensor is most likely the failed part. The oven sensor probe must have the correct resistance readings at specific temperatures. When the electronic range control (ERC) cannot identify the correct resistance of the oven sensor or the resistance is way out of specs F3 will display.
I recommend calling a service technician to diagnose and repair your oven.
Dec 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
F3 Message and Beeping
On a GE/Hotpoint, F3 means you have a failed keypad.
If you or someone you know might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
It's at http://www.microwavedisplay.com/keypad_replacement.pdf
If you'd rather have us fix it for you, we do that for $39.95 plus parts and you can visit us via our link here on Fixya http://tinyurl.com/yzjozk
Please feel free to contact me directly if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
May 16, 2008 | GE Advantium 120 Convection/Microwave Oven
KitchenAid KHMS155LSS 1000 Watts Microwave Oven Logo
93 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Stu Ungar
Darial Jr Lasaria
Darial Jr Lasaria
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
