Question about Dynex DX-E401 Router
For some reason when I hook the Router up I can not get onliine on any computer that I have the router for. I just moved and it worked fine at the last place. But the system light blinks. I forget if that blinked at the old place?
  • 344 Answers
Blinking shows activity, Double check how you have it hooked up....If you are using Internet connection sharing you should have your modem hooked throught your pc and your pc hooked to the #1 slot on the router...If you have your router connected to the modem its self make sure that you have it connected to the internet port of the router......If this is all set up properly hit the main reset (little black button on the back of the router) hold it for 30 seconds. Another possibility is firewall conflicts. Get back with me and let me know if this worked out for you...If not there are alternate directions we can take to solve this issue as it can be a number of things
Posted on Oct 07, 2009
I recently moved from Cable ISP to DSL ISP service. For the DSL service, I was asked to configure my Router to use PPPoE with Dynamic IP addressing. I also provided the router with my username and password...
The reason you have no internet is because the router is specifically for cable. your description contains errors what i think you mean is that you have gone from cable dsl to an adsl, correct me if i am wrong. Basically your modem connected to your router via an ethernet cable and then the router fed the wireless signal to your wireless devices or via ethernet through the 4 ports in the back. With adsl you have a feed from your phone line to an adsl modem so the only way for you to get the dsl router working is to have two ethernet leads connecting to your pc, one from the modem to the pc and one from the pc to the router. You would also need to setup internet sharing on the pc thats connected to both devices.
Either do it that way or buy an adsl router
Nov 10, 2010 | D-Link DI-624M Router (DI624MRE)
I do not know how to hook the router up I lost information when I moved
Are you trying to set up router ?
You can set up your router manually, without the CD.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
Sep 24, 2010 | Linksys WRT120N Wireless Router
Running install disc, says does not support operating system
Mar 03, 2010 | NetGear WGR614 Wireless Router
D-link connection to xbox live . works fine on computers
We had a problem with our Xbox doing this, take a cable from one of the comptuers and then try to hook it up. If that don't work, look at the MTC or the username and password information for the router which you might need on the router. Do you need a username and pass for the router? If not then you can connect directly without putting the pass into xbox. This may help, but that was what the problem was on ours and Idk if it will work for yours.
Apr 09, 2009 | Computers & Internet
Automatic installation failure
unless you were switching from DSL to cable Broadband, there usually wouldnt be much reason to rerun the software just because you got a new computer. when you ran the software the first time on the other computer, it was the router you were setting up, not the computer.
if the new computer is not getting internet when hooked to the router, try this.
1.turn off computer and unplug electricity from router and cable modem.
2. connect all ethernet cable to the right location. ethernet from modem to router goes in the non-numbered port, ethernet from your computer to router goes in numbered port.
3. plug in cable modem electricity first, wait for all its lights to come on like normal.(this part is important). the ethernet light on the modem (it might be labeled ethernet, link, pc link, or something similar) will not be lit, this is normal until you get to the next step
4. plug in the router electricity, give the router 2-3 minutes to get connected to the modem.
5. start up the computer, wait for everything to fully load and check internet again.
hope this helps.
Mar 21, 2009 | Siemens SpeedStream 2624 (SS2624) Wireless...
ATT/SBC gateway router....
Take the ethernet cable from modem to PC and hook it into the router(modem to router)...run another ethernet cable from the router back to that PC(router to PC). All you machines should be fine then.
Jan 25, 2009 | 2wire 2700HG-B Router (2700HGB)
Linksys WRT300N router issue
you have to power down all three items , turn on the computer then the modem then the route if this fails hit the reset button on the modem this shoul work for ya
Dec 25, 2008 | Linksys WRT300N Wireless Router
WRT150N looses wireless connectivity
filasian, there is a strong possibility that the switch part of your router is defective because there is no light on number 2 even if there is a computer plugged into it, this can be the factor that affects the wireless operation of the unit.
the best move you may do at this point is to contact Linksys to perform a firmware flash on your router or discuss the warranty of the unit.
their toll free number is 1-800-326-7114
or refer to the site below to to see the contacts for linksys.
Linksys- Contact Us.
good luck
Jul 29, 2008 | Linksys Wireless-N WRT150N Router
Linsky password
If you're after the default userR/password to log in to the admin-intaserface on the router it's usually ussername=root and password=admin
If it's the wep-key it's asking for there are software that can fetch this from your computer, but it's probably just as quick and easy to change the wep-key in the router and set up your writeless computers with that key.
Nov 27, 2007 | Linksys Wireless-G Broadband Router
Computers & Internet Logo
73 people viewed this question
Top Dynex Computers & Internet Experts
Prashant M
Prashant M
micky dee
Are you a Dynex Computer and Internet Expert? Answer questions, earn points and help others
